UPDATE 10/20/2024: STILL AVAILABLE-Compass Temp Homelink Mirrors for 2009-2015 Tacomas & more
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by RJP869, Mar 16, 2015.
  1. Aug 13, 2020 at 9:02 AM
    #181
    tamer
    tamer hamerworx.com
    NorCal
    2015 TRD OR AC, MGM, 4x4, 6spd MT
    Installed a "used" GNTX-455 from Bob! Looks brand new! Finally have a compass and temp in my '15! Calibration and install was very simple. Thanks @RJP869 !!
    super_white and Cativelense like this.
  2. Aug 13, 2020 at 10:13 AM
    #182
    RJP869
    RJP869 [OP] Owner of Bob's Automotive Mirrors & More LLC
    Bob
    La Porte, Indiana
    I don't have a Tacoma, but lots of mirrors!
    You are very welcome!! Mirror looks great in your truck!! Thank you again for your order - I greatly appreciate it!!!
    Cativelense and tamer[QUOTED] like this.
  3. Aug 13, 2020 at 6:17 PM
    #183
    fatfurious2
    David
    Ashburn, VA
    2010 TRD OR Access Cab
    i need one of these! Compass, temp. But, no backup camera, no homelink.
    I already have the temp sensor and the compass wiring
  4. Aug 15, 2020 at 2:42 PM
    #184
    RJP869
    Bob
    La Porte, Indiana
    We can get you set up with the mirror - email me at info@bobsmirrors.com
    But...you cannot, and I must strongly stress >cannot< use the factory temp sensor in any way. Doing so will cause two things to happen...the mirror will send 5 volts into your truck's computer and the computer will send a similar voltage into the mirror. 5 volts may not harm a fly, but it will make your local Toyota dealer happy as this will quickly fry the computer and they'll be charging well north of a grand to fix it and it will also destroy the temperature section of the mirror if not the whole mirror, which means you'd have to buy a replacement mirror too. The kits we sell come with their own sensor as these mirrors require a dedicated temperature sensor, so other than plugging into the white 14 pin connector tucked away above your truck's overhead console, there is no other wiring that ties into anything in the truck...the temp sensor is completely separate from any of the truck's wiring
    fatfurious2[QUOTED] likes this.
  5. Aug 15, 2020 at 3:25 PM
    #185
    fatfurious2
    David
    Ashburn, VA
    Ahhh thank you for that! What about the compass? I think i need to verify which plug is on the back of my current mirror
  6. Aug 15, 2020 at 3:35 PM
    #186
    looking
    looking Well-Known Member
    Doug
    Lancaster, Ohio
    2014 Sport DCLB 4x4 Barcelona Red
    I put the Homelink mirror with temperature and compass in my 2014 Sport last October. While I have done very few mods, the mirror is easily
    my favorite mod.
    Thanks Bob!
    RJP869[OP] and 2ndGenOffRoad like this.
  7. Aug 16, 2020 at 3:54 PM
    #187
    RJP869
    Bob
    La Porte, Indiana
    Does your truck currently have the factory auto dim compass Homelink mirror? If so, the 14 pin / 3 wire plug is connected to the mirror under a plastic cover attached to the mirror bracket.
    As for the compass, it's self-contained within the mirror, so nothing extra needs to be done to make the compass work, it'll operate whenever the ignition is on.
  8. Aug 16, 2020 at 4:11 PM
    #188
    fatfurious2
    David
    Ashburn, VA
    I have an auto dim with the backup camera screen in the left side, no homelink.
    I used to have the compass and temperature in my overhead console, but i wanted to move it to the mirror, and move the backup camera to the head unit.
  9. Aug 16, 2020 at 4:25 PM
    #189
    RJP869
    Bob
    La Porte, Indiana
    Ok...it's possible to put one of the compass temp mirrors in your truck, but because your mirror is what supplies 6 volt (yes...6 volt!) power to your truck's OEM backup camera, if you replace the mirror, there goes the power for the backup camera. But...we've been down this road with a few Tacoma owners who wanted to do the exact same thing, so we can make you up a custom harness that will have provisions in place to power the backup camera, and also include an RCA cable with reverse trigger wire long enough to reach your head unit (assuming you're going with an aftermarket unit?). So it would still have the same Gentex compass temp mirror & dedicated temp sensor & everything else like our regular kit, with the additional mods needed to accomplish what you would like for it to do. And in case you're wondering...you can't use the temp sensor signal from your overhead console with these mirrors...the signal in your console is a digital signal running on 1 wire; the mirror requires a dedicated analog two wire sensor, so you'll still be needing to install the sensor, same as what gets done in the 2014-2015 trucks. Send me an email at info@bobsmirrors.com and I'll get back to you tomorrow with more details & pricing on the custom kit.
  10. Aug 19, 2020 at 3:21 PM
    #190
    super_white
    super_white Well-Known Member
    Harry
    Connecticut
    2012 Tacoma 4X4
    I'm looking for this same mirror. I have a 2012 base model, so my truck didn't come with anything.
    Just paid for the mirror. Cant wait for it to ship :)
  11. Nov 16, 2020 at 9:48 AM
    #191
    DiscoYaker
    DiscoYaker Well-Known Member
    SE USA and Alaska
    2015 Tacoma 4WD SR5 AC MT, 1995 Tacoma 2wd ext. cab auto
    Stock for now.. maybe
    Anyone have a comparison picture between the regular stock no frills mirror and the homelink?
    I imagine the upgraded one is bigger but how much? Just curious
  12. Nov 16, 2020 at 2:27 PM
    #192
    2ndGenOffRoad
    2ndGenOffRoad Well-Known Member
    Los Angeles, CA
    '14 SBDC OffRoad 4x4 '84 4Runner 22RE
    Schmell Fab Sliders ATH Fab Rear Bumper Icon Stage 3 Suspension Front Runner Outfitters Roof Rack Softopper Bed Cover 285/70/17 KM3's on T4R Pro Wheels
    Here are some. On the after picture of it installed i used a mirror risor with an attachment to add a phone mount. The new mirror does not give you the rise and phone mount like I have pictured.
    RJP869[OP] likes this.
  13. Dec 9, 2020 at 3:43 PM
    #193
    drknsurfur
    drknsurfur Well-Known Member
    Nick
    Port angeles, Wa
    2008 Silver TRD Sport S/C
    Is there another thread for mirrors you sell for 08s? Or is it not possible?
  14. Dec 9, 2020 at 3:54 PM
    #194
    RJP869
    Bob
    La Porte, Indiana
  15. Dec 9, 2020 at 3:55 PM
    #195
    ramonortiz55
    ramonortiz55 Not A Well-Known Member
    Ramon
    Texas
    2015 DCSB Offroad 4x4
    stock
    reading thru this tomorrow
  16. Dec 14, 2020 at 8:35 AM
    #196
    StinkyTRD
    StinkyTRD Member
    2014 White Tacoma TRD OR
    Just wanted to say the Homelink 4 blue compass (no temp) mirror I ordered from Bob back in January of 2019 for my 2014 has been hands down the best mod I have ever done to this truck. Too easy to deal with him and installation couldn’t have been more straight forward. If you are even slightly considering getting one....do it.
  17. Dec 29, 2020 at 10:31 AM
    #197
    Bong Kong
    Bong Kong New Member
    2015 Sr5 Tacoma
    Vegan
    Got my Gentex 453 from Bob in less than 5 days despite the hectic mailing season. It came with everything you need except for tapes and elbow grease. The instruction was very helpful and understandable (in correct English). The instruction was elaborate and you can modify it as you see fit to suit your comfort level. I was able to install it in less than 1.5 hours. This was my first mod project so it may faster install for the seasoned installer. The quality of the product is superb. It looks like brand new! Everything works: the Homelink, temp., autodim and compass. There are many lower priced aftermarket mirror out there. I chose Bob's Mirror because of the many positive feedback from TW. I'm glad I chose Bob's Mirror.
    StinkyTRD and RJP869[OP] like this.
  18. Dec 29, 2020 at 12:25 PM
    #198
    ACEkraut
    ACEkraut Well-Known Member
    Aaron
    Durham, Maine
    2014 DCSB TRD Off Road
    @RJP869
    Just a quick question since you run in these circles. I have considered swapping out my mirror on my 2014 Offroad in order to be able to have an outside temp gauge in the truck but it is a lot of work and expense for just the ability to tell the outside temp. Do you have any ideas of any type of an aftermarket temp gauge that actually looks halfway decent? Is it possible to buy an old mirror that has the temp gauge built in that might not be in good enough condition to sell as a mirror but one I might be able to explore if I can cannibalize the temp part of it to see if I could make something that would display just the temp in an aesthetically pleasing set up? I would be willing to buy the mirror for parts if you had something like that hanging around. Thanks in advance for any help or guidance you can offer.
  19. Dec 29, 2020 at 5:22 PM
    #199
    RJP869
    Bob
    La Porte, Indiana
    Thank you so much for the kind words! Can't tell you how much I appreciate them!! And thank YOU for buying the mirror kit!
  20. Dec 29, 2020 at 5:29 PM
    #200
    RJP869
    Bob
    La Porte, Indiana
    Well...in terms of a standalone temp gauge...I have been looking for something decent (for over 5 years, lol!) for my snowmobile. I actually went so far as to cannibalize a crappy mirror to see if it is possible. Though it might be, I can tell you that I've given up on the project...here are my reasons: you would have to install the mirror's circuit board some place where it's not too shielded by the vehicle's sheetmetal (this would affect the compass sensor), figure out how to bypass the ambient light sensor (otherwise if you mount the circuit board in a dark location, the display will always be very dim), with the internal circuit board being roughly 3" x 10", finding a space to hide it is going to be a challenge...then for the display, the circuit board for the display is roughly 3"x3", even though the LCD display panel is only around 1"x1.5". So wherever you'd mount this would also need to be large enough to accommodate the circuit board. Though I've dealt with these things for over 20 years and have quite a bit of experience in electronics, I soon realized that this project was not worth the time & effort.
    ACEkraut[QUOTED] likes this.
