UPDATE 10/20/2024: STILL AVAILABLE-Compass Temp Homelink Mirrors for 2009-2015 Tacomas & more
Discussion in '2nd Gen Tacoma Parts Marketplace (2005-2015)' started by RJP869, Mar 16, 2015.
  1. May 26, 2015 at 9:41 PM
    Square
    Square Well-Known Member
    Brian
    Mission Viejo, CA
    '14 DCSB SR5 4WD MGM
    The third wire is going to be your ground.
    Edit: The two 12v wires are likely going to be a "Constant ON" and the other is likely a "Switched ON."
    Second Edit: I'm waiting for Bob to get a mirror in so I can do this mod. When I get it in, I'll look further into what exactly each wire is. Or, you can look further into this site. I'm 95% certain it has been covered here before.
    FJ to Taco likes this.
  2. May 27, 2015 at 11:49 AM
    TacomaDarth
    TacomaDarth Well-Known Member
    Randy
    Northern Michigan
    2015 TRD Off Road in it's infancy
    C-Clamp Theft Deterrent System (with bonus heat shrink protection), FJ Trail Team Wheels with Duratracs, WeatherTechs. TRD Exhaust, Access Limited Tonneau Cover, Rear Diff Mod to Taillight
    No expert here by any means, but I was under the impression that the temp sensor you're seeing is the air intake temp sensor. Others correct me if i'm wrong. If you have a scan gauge II you can read temps from that but it'll give you close outdoor temps at highway speeds only. I installed the new sensor for the mirror underneath that one you're referring to. When and if you order from Bob he will ask you how many wires you have so he can give you the correct harness for an easy install. This mod was fun to do, but again, the biggest pain in the rear was getting through the firewall. I don't recommend trying to pass through with the large bundle of wires.
  3. May 27, 2015 at 2:33 PM
    AfrknMgk
    AfrknMgk Member
    2014 Spruce Mica Toyota Tacoma TRD Off-Road
    Flowmaster Super 44 Muffler Westin Chrome Bull Bar KC Spotlights Gentex-453 Thermometer/Compass/Homelink Mirror
    You very well could be right on that. Good luck on your install.
    I'm glad to hear you have the same sensor I do, and used the new sensor Bob sent you as well. I just don't want to have most of everything I need already in place, and not even use it.
    As for passing wires through the firewall. You may already be doing this, but I have found it easiest to use a single piece of thick wire (I believe I had about a 2 ft. piece of 12ga. wire.), bend one end into a hook, bend the wires being pulled over this hook, and tape over the hook so it does not get caught or let the wires fall off. When I installed my spotlights I actually went through the rubber boot around the bundle of wires going through the firewall. I simply pushed a knife through the rubber boot (careful not to cut a wire), and shoved the un-hooked side of the thick wire through until I saw it on the other side, then simply pulled it the rest of the way. Like I said, you very well may already be doing this, but I just thought I would put it out there.
    TacomaDarth[QUOTED] likes this.
  4. Aug 16, 2015 at 8:39 PM
    AfrknMgk
    AfrknMgk Member
    Installed my mirror and temperature sensor I got from Bob, and everything is working great. The install went smooth, and I have had several comments from different people telling me it looks factory.
    Kolter45 and Tyson like this.
  5. Aug 19, 2015 at 2:21 AM
    adio
    adio Well-Known Member
    HI
    2015 INFERNO TRD PRO
    Does he carry any mirrors that has that cool white led back lit, instead of green.
  6. Aug 27, 2015 at 7:23 AM
    RJP869
    RJP869 [OP] Owner of Bob's Automotive Mirrors & More LLC
    Bob
    La Porte, Indiana
    I don't have a Tacoma, but lots of mirrors!
    We do...these have white compass display, white backlit buttons, and a small white LED on the bottom of the mirror (not a maplight, just some mood light or whatever it's referred to, lol!). These are autodim/Homelink/compass (compass temp not available in white display). Mirror kits are $269 - email me at rearviewmirrors@csinet.net if you'd like to order.
  7. Aug 27, 2015 at 7:28 AM
    RJP869
    Bob
    La Porte, Indiana
    UPDATE on the GNTX-453 series of autodim-compass-temp-Homelink mirrors. We have located a supply of brand new mirrors if anyone is interested in them. They're quite a bit higher than the original price, but at least there are some new ones available if anyone is interested. Price on a kit with a brand new mirror is $399 including shipping, plus sales tax if you're in Michigan or plus $15 shipping if you're in Canada. Email me at rearviewmirrors@csinet.net if you would like to purchase one. When emailing me, let me know the year of your Tacoma. If you have a 2015, you'll need to determine if your truck has the 14 pin plug in place and whether it's got 2 wires or 3 wires in the harness, or has no mirror wiring whatsoever. All 2014's have the wiring in place. If you need the mirror for a 2009-2013 Tacoma, it should still work, but some of those trucks are missing the constant hot wire in the plug...so if you have one of these I can help you determine if yours has the constant hot wire in place. Thank you!!
    Square likes this.
  8. Aug 27, 2015 at 1:48 PM
    Rusty15Tacoma
    Rusty15Tacoma Well-Known Member
    Rusty
    San Diego
    2015 MGM TRD Offroad
    Bilstein 5100 w/ OME 886, Built Right UCA's, Dirt King LCA's, 5125 2"-2.5" lift rear shocks, Alcan HD 8pack rear, Level 8 Guardian 16" wheels, blacked out badges, 285/75R16 Hercules Trail Digger, 20% tint, BHLM Retrofit.
    Is there a mirror that has the above mentioned options as well as backup camera?
  9. Aug 28, 2015 at 12:09 AM
    imom
    imom Well-Known Member
    CAL
    2014 Regular Cab
    I have basic regular cab without any wires I believe in the headliner. If I wanted to install a frameless mirror with homelink... what wires do I need to run? I assume the homelink garage door function is built in to the mirror. Do you sell that cable?
  10. Aug 28, 2015 at 6:28 AM
    RJP869
    Bob
    La Porte, Indiana
    Yes there is...we have kits that are based on the GENK3350 mirror, which has autodim, compass, temp, homelink & 3.3" backup camera display. We have these available for the 2012-2013 Tacoma's that are prewired for the camera option, cost on these kits is $599; for the 2014 and newer trucks or for non-prewired 2009-2013 trucks, you'll need the regular GENK3350S kit as you'll have some wiring to do, and the cost on the regular kit is $659 (for the 2014-2015 trucks, if they have the factory mirror connector in place, we can customize the GENK3350S harness for no extra charge and add the factory 14 pin mirror connector to it so that the ignition & ground or ignition/battery/ground connections would be plug & play, so it will save you from doing some of the wiring on your own).
    Biscuits likes this.
  11. Aug 28, 2015 at 6:30 AM
    RJP869
    Bob
    La Porte, Indiana
    Hi - for these mirrors, you'll need three connections: ignition, battery & ground & everything is self-contained within the mirror. The frameless mirror kits we have for sale include the wiring harnesses with the mirrors for trucks that do not have the wiring in place. Here's a link to one of the messages we posted on the forum regarding the frameless mirrors: https://www.tacomaworld.com/threads...w-availalable-for-the-2009-15-tacomas.352783/
  12. Aug 28, 2015 at 3:13 PM
    imom
    CAL
    2014 Regular Cab
    Hi Bob,
    Just to clarify, since I have a regular cab and no wiring at all...your price included long harness to route through the A column and then into the headliner? I was on the fence about getting it...but the full wiring kit is provided...would be worth it. I don't care for compass as most NAV systems will have it and I don't want annoying LEDs distracting me. So please let me know how long is the wiring kit? Thanks!
  13. Aug 28, 2015 at 3:30 PM
    PATHFINDER
    PATHFINDER Well-Known Member
    Dan
    Oxnard, CA
    2014 MGM TRD OR DCSB V6 4x4
    Leer XQ100, Toyota Skid Plate, Weather Tech Vent Shades, Firestone 2407 Airbags
    Bob put me on the list. Just waiting to hear my mirror is in...
  14. Aug 28, 2015 at 8:49 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Looks good!
    AfrknMgk[QUOTED] likes this.
  15. Aug 28, 2015 at 8:53 PM
    #35
    shakerhood
    Southern Ohio
    My truck has that Green wire also but it was terminated prior to the plug and just taped to the bundle.
  16. Aug 30, 2015 at 11:51 AM
    #36
    RJP869
    Bob
    La Porte, Indiana
    The wiring kits with these mirrors are right around 9 feet long, which is plenty long enough to reach the bottom of the dash on just about any vehicle.
  17. Aug 30, 2015 at 10:40 PM
    #37
    dooododoo
    dooododoo Active Member
    Northbrook, IL
    2015 TRD Sport
    I left everything alone and the mirror works fine with the stock harness as is.
  18. Aug 30, 2015 at 11:12 PM
    #38
    shakerhood
    Southern Ohio
    I also left everything alone with the harness and the mirror works fine.
  19. Sep 2, 2015 at 12:22 PM
    #39
    FJ to Taco
    FJ to Taco Well-Known Member
    Tony
    Lacey, Wa
    2015 DCSB 4x4 TRD Off Road,Snugtop Rebel
    Bilstein 5100's all around, OME 885's and OME Dakar CS047R Leaf Packs. Snugtop Rebel, pet screens,front slider drop down window. WeatherTech mats. Interior LEDS
    I just got my GNTX-313 from Bob. I want to thank Bob for everything. He is great to do bussiness with. The packing and shipping were perfect.
    I will be installing this this weekend.
    Installed and looks and works great..
    Thank's Bob!
    Bob it is a pleasure to do business with!
  20. Sep 15, 2015 at 6:37 AM
    #40
    TRDProBuddy
    TRDProBuddy Well-Known Member
    MD (Kent Island)
    2015 TRD Pro (Inferno)
    Hi Bob, I would like to add my name to the list for one of the new mirrors with comp, temp, auto dim, and home link. I have a 2015 DC. I read that you need to know what connector I have. Do you have install instructions describing what has to be done to gain access to the connector to see what I have
