Update 3/13 - Found it: Front end noise thats driving me crazy... any advice appreciated!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ImpulsedComa, Mar 3, 2017.
  1. Mar 3, 2017 at 7:41 AM
    ImpulsedComa
    ImpulsedComa [OP] Well-Known Member
    NJ
    05 Double Cab 4x4 SR5 V6
    2005 DCSB with 884's up front and spc control arms. Frame replaced 1.5 yrs ago with new components up front.
    Just started to here this annoying click or clank (metal to metal sound) and I cannot find where it is coming from. Basically I pull past my driveway and put it in reverse to back in. As I am at almost full lock and going in reverse i here a metal to metal sound sometimes as a clicking and multiple times and sometimes just once little bang. I can replicate it by going forward also and turning the wheel usually when i pull the truck slowly into an incline or decline.
    I replaced the body mounts under the radiator because they were shot. Ive tightened all the nuts I could under the truck to eliminate something loose and I took off my sway bar to eliminate that in case it was hitting the coils. The lower control arm bushings are tightened to spec and are brand new. Nothing has worked. I have access to a lift and im out of options and need some help.
  2. Mar 3, 2017 at 7:47 AM
    Pigpen
    Dan
    Northwest Montana
    Tighten your UCA and LCA hardware. It should go away. While under there, it would be a good idea to pull the LCA bolts one at a time and cover them with anti seize. Don't forget to mark the cam tabs so you don't lose alignment.
    outlawtacoma and DrFunker like this.
  3. Mar 3, 2017 at 7:51 AM
    10MGM
    10MGM Well-Known Member
    2010 AC MGM 4x4
    Check your cv joints
  4. Mar 3, 2017 at 8:15 AM
    ImpulsedComa
    NJ
    The lca's are good but I will check the uppers. Thanks for the advice
  5. Mar 3, 2017 at 8:17 AM
    ImpulsedComa
    NJ
    Have not done this, I'll do it as soon as i can. Trying not to sound like an idiot, but how do i do this? Lol
  6. Mar 3, 2017 at 11:04 AM
    ImpulsedComa
    NJ
    another question about the cv's.... I can replicate the sound sometimes when not moving and just turning the wheel back and forth. The noise in that case is just once and then goes away. Wouldnt the truck have to be moving for the cv to be the culprit of the noise?
  7. Mar 3, 2017 at 12:48 PM
    excorcist
    excorcist Well-Known Member
    Reno, NV
    '06 dcsb, '86 pickup, '89 runner
    Not necessarily, there will still be movement in the CVs when you are turning the wheel.
  8. Mar 3, 2017 at 12:55 PM
    10MGM
    2010 AC MGM 4x4
    The noise you are hearing is indicative of worn cv joints. One test is to listen for clicking at full lock under power. Another is to support frame on stands with suspension at full droop, steering at full lock and engine off. Rotate each tire and listen.
    ImpulsedComa[OP] likes this.
  9. Mar 3, 2017 at 3:42 PM
    ImpulsedComa
    NJ
    Thanks, just tested it a little while ago and all i have to do is have the truck standing still with one wheel on lower ground than the other. When i turn the wheel and the truck flexes because of the incline, i can get it to click and clank. Makes me think it has to do with the flexing of the truck as apposed to something else. Is this still indicative of the cv?
  10. Mar 3, 2017 at 5:37 PM
    10MGM
    2010 AC MGM 4x4
    Tires rotate when steering wheel is turned. Cv joints rotate when tires rotate. You mention you have access to a lift. Get the wheels off the ground and poke around turn things.
  11. Mar 3, 2017 at 5:43 PM
    AR15xAR10
    08 SR5 4x4 V6 IndigoInkPearl ACLBFTMFW
    It is the steering stops on the back of the spindles hitting the bumpers on the LCAs. Totally normal.
  12. Mar 3, 2017 at 6:41 PM
    ImpulsedComa
    NJ
    I'll try that and report back, thanks
  13. Mar 3, 2017 at 6:43 PM
    ImpulsedComa
    NJ
    The noise happens prior to full lock. If i get it right, i can stopped and turn the wheel and when i get the spot right, i can go left and right and make it click a few times before it goes away and i have to reposition the truck again...
  14. Mar 3, 2017 at 6:46 PM
    anthony250f
    anthony250f Well-Known Member
    Anthony
    San Diego, CA
    2008 dcsb trd offroad 4wd
    Take your wheels off and tighten every bolt...could be the lca bushings...torque them to 100
  15. Mar 3, 2017 at 7:38 PM
    ImpulsedComa
    NJ
    good idea, im sure the lca's are to spec, but i wil be tightening everything else again in there when i take the wheel off. Thanks
  16. Mar 3, 2017 at 7:40 PM
    ImpulsedComa
    NJ
    Just really weird cause ive had multiple people under there and nobody can pinpoint where the noise is coming from.
  17. Mar 3, 2017 at 7:47 PM
    Specalt
    Specalt Well-Known Member
    Phoenix
    2001 TRD 4x4
    @Seabass had the same problem. It turned out to be his stearing rack. It had come just a little lose and started to click when he backed down a kerb.
  18. Mar 4, 2017 at 6:12 AM
    ImpulsedComa
    NJ
    Thank you, steering rack hadn't occurred to me.... Would love to hear from you @Seabass Maybe message me with the specifics of what happened to you and if you think my situation is the same.
  19. Mar 4, 2017 at 6:20 AM
    Specalt
    Phoenix
    2001 TRD 4x4
    I know that he replaced the entire front of his truck, new lower control arms new spindles new stearing rack... all of his stuff was just warn out. Then it developed a klunk as you have described. He went in for an alignment hopping it would go away and the tech there informed him his sterling rack was loose.
    Tightened it back up and the klunk went away.. the klunk is now back and again the rack was loose again. We are fixing it today with a bit of thread lock. It is just held on with 2 bolts.
  20. Mar 4, 2017 at 9:51 AM
    ImpulsedComa
    NJ
    Much appreciated! Hopefully that's the problem with mine and just became loose after the frame replacement. If you could post a picture of the two bolts in question that would be great. Im working the next 4 days and will be examining it all on Wednesday.
