UPDATE: Rear Icon 2.0 remote resi question (recharge)
Discussion in '2nd Gen. Tacomas (2005-2015)' started by josh0351, Jun 6, 2014.
  1. Jun 6, 2014 at 6:02 PM
    josh0351
    josh0351 [OP] Californication
    Josh
    VA
    Supercharged '13 TRD OR | '96 4X4 Reg Cab (RIP)
    Some stuff...
    Embarked on the installation of my Dakars and Icon 2.0 remote resi rear shocks this afternoon but ran into a potential issue. The driver side shock remote resi tube loosened when I was tightening the top-hat screw (it was wedged against the shock mount). I heard a very faint "pop" or "hiss" for a about a millisecond.
    I re-tightened the remote resi hose to the shock body, but am wondering now if I need to have that shock re-charged? :confused:
    Just got back from having the Icon looked at - it's good and up to pressure. He even checked the other shock and both are nuts on for PSI. So not sure what happened above, but all is well.
  2. Jun 6, 2014 at 6:14 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I would say, Yes. They don't hold a large volume of gas, so a split second can evacuate all the charge.
  3. Jun 6, 2014 at 6:26 PM
    josh0351
    Josh
    VA
    Some stuff...
    That's what I figured, I'll get it in Monday or Tuesday for a re-charge. It should be good temporarily until I can get it recharged, right?
  4. Jun 6, 2014 at 6:28 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Define "good". I don't think it will loose any more charge.
  5. Jun 10, 2014 at 2:55 PM
    vanhornsky
    vanhornsky Active Member
    I would charge them. Mine are set at 110lbs. If you drive them is might mess up the floating pistons in the reservoirs.
  6. Jun 10, 2014 at 4:51 PM
    josh0351
    Josh
    VA
    Some stuff...
    10-4, I'm meeting with a cat here in the area tomorrow who is gonna check the pressure and recharge (for $20) if needed. It's not leaking oil, and has been driven minimally, so less than a 100 miles.
    Fortunately, I have a work rig. :D
    [​IMG][​IMG]
