Update: they checked tranny fluid. 2016 w/ tow package...One quart low.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by BMunster, Mar 10, 2016.
  1. Mar 18, 2016 at 6:44 AM
    #201
    16TacomaSport
    16TacomaSport Well-Known Member
    Jon
    Pittsburgh PA
    2022 Camaro SS 1LE 6spd
    But he was already taking it in to do the fluid check he just happen to notice the issue taking it in for that. They didnt give me any hassle about having it checked like alot of people seem to be running into.
    I might call corporate and see what they can do for me. Someone said toyota replaced their trans for 1/2qt low and some slipping. Mine was 2qt low and noticed the issue from R-D. so I wonder if they will give me an extended warranty to 100,000 on my trans
  2. Mar 18, 2016 at 6:48 AM
    #202
    The Dude 80
    The Dude 80 Well-Known Member
    OHIO
    2016 DCLB Sport 4X4
    After reading all of the transmission threads here you guys made me paranoid. :spy: I took my truck into Voss Toyota (Beavercreek, OH) and told them to check my transmission fluid and all my other fluids. They were fantastic to deal with and didn't hassle me at all about wanting to check the transmission fluid on a truck with 3,600 miles. Turns out I was "over a quart low" according to my service advisor! :eek: He said his service manager had his monthly conference call with Toyota on Monday and was informed about the 2016 Tacos and low transmission fluid. So it appears Toyota is now getting the hint! If you have the tow package I would definitely get it checked. Also my rear differential was .5 quarts low...:facepalm:
    Two questions:
    1. How much damage was done to my transmission by being "over a quart low" for 3,600 miles? I have only done city and highway driving...no towing or off-roading.
    2. I'm pissed that Toyota can't figure out how to put the correct amount of transmission fluid in their vehicles. I am definitely going to call corporate and see if I can get an extended warranty on my transmission since they screwed up. I realize I'm probably screwed, but it doesn't hurt to try. Has anyone had any luck trying to get something out of Toyota?
    smitty99 likes this.
  3. Mar 18, 2016 at 6:51 AM
    #203
    Thirdgentacoman
    Thirdgentacoman Well-Known Member
    I think you're talking about me. Mine was half a qrt low and they replaced it. The tech retested after topping off and issues still persisted. Again, repeating the issue for the tech is the key.
  4. Mar 18, 2016 at 6:52 AM
    #204
    16TacomaSport
    Jon
    Pittsburgh PA
    hmm I still get a lag from R-D when its cold. Wonder if I should take it back or just call toyota first
  5. Mar 18, 2016 at 6:55 AM
    #205
    BlkTaco47
    BlkTaco47 Unhinged
    2018 TRD PRO Midnight Black Metallic
    Were you having any issues at all or was the check just for
    your peace of mind?
  6. Mar 18, 2016 at 6:57 AM
    #206
    The Dude 80
    OHIO
    2016 DCLB Sport 4X4
    I was having the surge when going from "R" to "D". Now that I have the right amount of fluid the transmission seems to have smoothed out.
  7. Mar 18, 2016 at 6:57 AM
    #207
    Thirdgentacoman
    To be clear mine was more for hard shifting whole driving, r to d delay doesn't seem to be a cause for concern.
  8. Mar 18, 2016 at 7:22 AM
    #208
    PaulHarke
    PaulHarke Member
    Paul
    Goodyear, AZ
    2005 Tacoma Prerunner
    There is also a known issue (tsb) for 2016 tacomas with 2tr 4 cyl engines that have issues when shifting from 2-3. ecu reflash is the fix!
  9. Mar 18, 2016 at 7:44 AM
    #209
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    At least 3% of the trucks sold are going to have transmissions replaced prematurely at this point. The real concern should be how many are not being replaced because Toyota has not done the homework to explore this issue and root it out completely.
    gearcruncher likes this.
  10. Mar 18, 2016 at 7:48 AM
    #210
    Thirdgentacoman
    80% of all statistics are 112% completely made up.
    Even then 3% is better than second gen tacos and 4runners.Guess third gen is an improvement.
    Still on the sauce huh? Get it!
  11. Mar 18, 2016 at 7:49 AM
    #211
    smitty99
    Scottsdale
    So do you work for Toyota Marketing or are you just a huge fanboy? Only 50 posts....hmmmmmmmm
  12. Mar 18, 2016 at 7:50 AM
    #212
    Thirdgentacoman
    Clearly.
    Disagree with the almighty smitty99 and you must be a marketer!
    My transmission was replaced from this issue. I must be the world's shittiest marketer.
    I had another account before with a few hundred posts just don't know the login. Came back here to update folks on the transmission issue since mine was replaced I figured I could help clear up some confusion since I've been through every stage of this process. Too many here like yourself don't know what they are talking about and are spreading misinformation that is making the issue worse.
  13. Mar 18, 2016 at 8:02 AM
    #213
    smitty99
    Scottsdale
    Ok Chief so you had your transmission replaced and now you're the resident Reliability, Availability, and Maintainability expert for all of corporate Toyota and their manufacturing processes? Oh you're also a master statistician...thanks boss. :thumbsup:
  14. Mar 18, 2016 at 8:04 AM
    #214
    Thirdgentacoman
    Once again I never said any of that.
    But thanks to trolls like yourself it's impossible to provide useful information for people who are actually having issues. I went through this entire process... Started with low fluid and ended with a replaced transmission, so yes I feel I can offer insights to those experiencing the same issues and hopefully help them come out with a satisfactory resolution as I did. Congrats tho, you win. I'll stop trying to help and enjoy my new transmission in peace.
    People like yourself ruin forums like this. Instead of trying to help people you sit behind your keyboard making stuff up without a clue as to what you're talking about but with the sole intent of causing others harm.
    Bottoms up buddy, time for a refill I bet.
    I'm out, good luck folks.
  15. Mar 18, 2016 at 8:07 AM
    #215
    BlkTaco47
    BlkTaco47 Unhinged
    :der:
    Relationship section ------>>> :D
  16. Mar 18, 2016 at 8:11 AM
    #216
    Thirdgentacoman
    Reference to his drunken posts ;)
  17. Mar 20, 2016 at 5:04 AM
    #217
    gearcruncher
    Canadain bumper technician
    Grasping at straws here my friend or should I say frustrated to the point where " WE " as the owners of these trucks need to force Toyota to release a tsb .
    Dealing with this issue for 4 years as a member of this site and admin at many others
    Subbed to all the low fluid posts on Tacoma World . Subbed to all transmission related posts at Tacoma World
    Got my fingers crossed we see a TSB by June of this year .
    Old School likes this.
  18. Mar 20, 2016 at 5:19 AM
    #218
    gearcruncher
    At this point in time , I am going to agree with what Smitty is preaching .
    We saw the problems associated with low fluid in the 2nd gen transmissions but there were far less complaints for low fluid in the 2nd gen in comparison to the 3rd gen .
    Thousands of torque converters failed in the 2nd gen transmission . Why ? its by far the hottest point within the transmission and was trying to operate properly with low transmission fluid . Inadequate cooling and loss of oil pressure .
    For the lucky members and guests who read about low fluid issues with the 3rd gen transmission , this is your chance to get the transmission filled correctly before damage is done .Hopefully a tsb is released soon
    Toyota will not be calling you on the phone to say " Hey , we didnt fill your transmission properly "
    For the owners of new Tacoma trucks that dont get to read these posts , get ready for a storm of transmission failures .
    smitty99[QUOTED] likes this.
  19. Mar 20, 2016 at 5:20 AM
    #219
    SigSense
    SigSense Well-Known Member
    13 TRD Sport DCLB 4X4
    Ultimately to vehicle manufacturers it is about one thing: money. They have lawyers and actuaries that calculate what these actions will cost. Remember the frame-rot issue with Tacos? Then there was the leaf spring recall. Seems that they could corrode, snap off, and move enough to puncture the fuel tank or sever the rear brake line.
    Another recent example is the Takata airbag issue (not Toyota's fault). Takata was aware of dangerous defects with its airbags years before the company filed paperwork with federal regulators.
    Bottom line in it all is saving dollars. If enough owners complain and annotate issues (especially safety) then manufacturers study those problems and put it through the cost/benefit matrix......
  20. Mar 20, 2016 at 5:21 AM
    #220
    Old School
    Old School You are ignoring covfefe by this member.
