update to 'It can pull......can it launch a boat?'
Discussion in '3rd Gen. Tacomas (2016-2023)' started by clint51, Sep 16, 2019.
  1. Sep 16, 2019 at 3:45 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    I have pictures of an engine someone did this with.
    The pieces are bolted to a display board as a warning to others. :laughing:
  2. Sep 16, 2019 at 3:47 PM
    Scott17818
    Scott17818 Well-Known Member
    Scott
    Midcoast Maine
    2016 Tacoma DCSB OR
    methodMR305NV, 265/70/17duratracs, ARB RTT, DITCH Lights
    if it trailered fine, and you felt no loss of power... put it in 4wd lo range, and you should be fine. just be smart about how deep you go.. just enough to float it...
  3. Sep 16, 2019 at 5:11 PM
    PuntaGunta
    PuntaGunta Member
    2018 TRD Off-Road
    Good call on getting electric brakes for those thats aren't familiar, normal surge brakes don't work in reverse. So much more likely to get pulled in the water. I'd say if you have a well maintained (not mossy and slippery) shallow ramp, you should be good during a high tide. Seems like every day you see a new video of a truck getting pulled in and I've noticed its not mostly smaller trucks. Once you hit the algae slippery stuff a heavier rig is gonna go down too.
  4. Sep 16, 2019 at 5:13 PM
    Bishop84
    Bishop84 Well-Known Member
    Another piece of advice from a Toyota tech.
    Let the axle cool before placing it in water. 2+ hours of hauling then shoving it into water is bad. It causes rapid cooling and water to enter the axle. 15 minutes goes a long way.
    FritoBandito likes this.
  5. Sep 16, 2019 at 5:20 PM
    Boss hoss
    Boss hoss Well-Known Member
    Richard
    Silverton Oregon
    2021 TRD OR premium access cab.
    Carpet bed liner and Matt, fuel wheels KO 2 tires. Bilstein 6112,5160 frt. lift .white with black leather seats.
    My VW Touareg TDI was rated to pull 7700 lbs. i alway towed a lighter trailer . Last one was 6000 loaded with everything for a week. I never liked the tail wagging the dog so to speck. It takes lots of traction and grunt to pull a boat out of the water and up a steep ramp. I think the Tacoma would do it but 6000 is a big load for it. All depends on how comfortable you are towing it.
