Updated 7/13: Droning or Howling Noise (Drivetrain? Rear End?) Video
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 1, 2016.
  1. Jul 5, 2016 at 5:01 PM
    #41
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    nah it won't. If it makes you feel better, i had a legitimate problem with my last truck's diff (pinion bearing). It started to sound like a power drill turned on in the back (it went from howling to eventually whirring) and then developed such a bad vibration that my rear view mirror went completely blurry at certain speeds. You'll be safe.
  2. Jul 5, 2016 at 5:04 PM
    #42
    aero90
    Man triple post here, but...
    It really surprises me that auto manufacturers have different requirements for new differentials than if you were to get a diff re-geared or overhauled. The places that do the work will void your warranty if you dont follow a break-in procedure similar to Toyota's, but ALSO don't change the fluid after the first 500 miles.
    Makes me wonder....
    smitty99[OP] likes this.
  3. Jul 5, 2016 at 7:20 PM
    #43
    smitty99
    smitty99 [OP] I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Picked up truck. Still making the howl noise. Waiting for rear end parts to arrive, they're on order. Rear leaf springs (Problem #2) already squeaking again by time I got home. Hey at least they checked the floor mat :bananadead::facepalm::smash:
    TRDinOhio and jeff_taco_4x4 like this.
  4. Jul 5, 2016 at 7:32 PM
    #44
    jeff_taco_4x4
    jeff_taco_4x4 Well-Known Member
    jeff
    16' 4x4 Sport DCSB w JBL, MGM
    I'll keep my fingers crossed for ya Smitty99. The new diff gear fixed my howl, perhaps it will you for you too....now, not sure what a new rear end means (more than just diff gears?) but just hope it works out.
  5. Jul 5, 2016 at 7:32 PM
    #45
    smitty99
    Scottsdale
    Admitting they have a problem is more than half the battle. Now if I can squeeze corporate for an extended warranty I'll be happier.
    jeff_taco_4x4 likes this.
  6. Jul 5, 2016 at 7:34 PM
    #46
    smitty99
    Scottsdale
  7. Jul 5, 2016 at 7:49 PM
    #47
    gearcruncher
    Canadain bumper technician
    Not much I can add . Use to replace pinion bearings on the Tacoma,s all the time . Managed to change the pinion bearings for the customer without having to replace the complete diff assembly .
    Its extremely difficult to set the pre load and backlash on a used set of gears that already have a pattern established .
    Hopefully Toyota will do a ring and pinion gear set to start .
    Judging from your video , it sure sounds like an issue with the rear diff
  8. Jul 5, 2016 at 8:14 PM
    #48
    jeff_taco_4x4
    jeff
    my step son in law is a certified Toyota mechanic, I'm going to "run this by him" next time I see him. I'll let you know his opinion (if that means anything) of what's going on.
  9. Jul 5, 2016 at 8:14 PM
    #49
    Judicar
    Judicar Well-Known Member
    2016 Tacoma TRD OR DCSB
    This is all very unfortunate. I was planning on replacing the tires with a set of 285s and I also have this howl. I feel Toyota may try to blame the larger tires and OME suspension on a failed diff if it were to come to that and try to stick me with the bill.
    All that being said, would re-gearing the rear diff essentially solve my problems should my diff be in fact bad or faulty in some way as described in this thread? I plan on re-gearing once I get the larger tires on and I find a reputable manufacturer of aftermarket gears for the '16 TRD ORs.
  10. Jul 5, 2016 at 8:18 PM
    #50
    smitty99
    Scottsdale
    You know I'm not really sure. One of the things I take issue with is there is no real root cause analysis or diagnosis being specified. So they are throwing parts at the problem. Which means there's a risk that they aren't solving the root cause and a new diff could be fucked up again.
  11. Jul 5, 2016 at 8:20 PM
    #51
    Judicar
    Seems like a valid point.
  12. Jul 5, 2016 at 8:23 PM
    #52
    12TRDTacoma
    Rob
    Concordia
    Boosted
    As for the leaf springs, I actually agree with the not greasing it mentality. I just had to replace the center pin bolt on one of my leaf packs and did the other side as good insurance measure as well and I reassembled them dry when I put them back together. I have been up and down the road and all over the place with the truck since then and not once has it squeaked.
  13. Jul 5, 2016 at 8:24 PM
    #53
    jeff_taco_4x4
    jeff
    careful, let's not assume. The new sized diff gears did fix my howl...and I've put another 7000 miles on it since the repair. no problems:fingerscrossed:
    by the way, did Toyota say the new rear end would include new different sized diff gears?
  14. Jul 5, 2016 at 8:28 PM
    #54
    smitty99
    Scottsdale
    They didn't say they would be any different. I did not notice the noise until closer to 10k mi. There's a chance I may be at 22k+ before I would hear it acting up again if the root cause was not remedied. I know they didn't root cause it because they told me they don't really know what's causing the noise. So they're the ones assuming it needs to be replaced.
  15. Jul 5, 2016 at 8:36 PM
    #55
    jeff_taco_4x4
    jeff
    I see. again, I hope it all works out.
  16. Jul 5, 2016 at 8:37 PM
    #56
    smitty99
    Scottsdale
    Gracias amigo. Appreciate your inputs and sharing your experiences
  17. Jul 5, 2016 at 8:38 PM
    #57
    bulldog
    bulldog Well-Known Member
    SW MO
    2023 Pro
    Umm…it’s a Pro Retired 4/29/2023 Dobinsons MRR Dobinsons UCA Dobinsons C59-314 Front Springs Dobinsons I59-110 Rear Springs 4.88 Yukon Gears CMC MobTown Sliders Line-Xed RCI Aluminum Skid BAMF Recessed Grille WARFAB Rear tube bumper SSO Full Plate Hybrid (sitting in the garage still) TTD Carbon Fiber Steering Wheel Clazzio Dark Gray Seat Covers 35% Tint Vinyl Tailgate Letters Undercover Elite Tonneau Apex Stealth Cali LED 31.5" w/upgrade OPT 7 harness and MicTuning Switch V5 Gemtech Homelink 265/75 16 Mickey Thompson Baja Boss A/T Volk Gloss Black 16” 17' Pro Rigid Fog Lights 17' Pro Tail Lights Complete sound proofing
    I've had mine replaced at about 450 miles. Mine was for super howl due to being low on diff oil, like maybe a cup in there from the factory the service manager said, lol.
  18. Jul 5, 2016 at 8:44 PM
    #58
    aero90
    Hmmm new carrier bearing assembly. Does that mean they are doing the job there? I thought it would be an actual whole new assembly.
  19. Jul 5, 2016 at 9:10 PM
    #59
    smitty99
    Scottsdale
    No idea man. I asked them if they did the work there or outsourced he said "we have a guy"
  20. Jul 5, 2016 at 9:14 PM
    #60
    aero90
    Oh god, best of luck
    smitty99[QUOTED][OP] likes this.
