Updated 7/13: Droning or Howling Noise (Drivetrain? Rear End?) Video
Discussion in '3rd Gen. Tacomas (2016-2023)' started by smitty99, Jul 1, 2016.
  1. Jul 17, 2016 at 7:24 PM
    #161
    MasterPenguins
    MasterPenguins Well-Known Member
    Indiana
    2016 Quicksand Tacoma TRD Off Road 4x4, DCSB
    I am taking my second one back Tuesday afternoon. I am expecting them to say that something probably isn't right, but that they aren't sure what. Probably open a case with Toyota and tell me to hold tight. I agree with you though, I feel like there is no way they will tell me it is normal after they spent ~$3k to "fix" it once before. I will update you all Tuesday night.
    smitty99[QUOTED][OP] likes this.
  2. Jul 17, 2016 at 7:25 PM
    #162
    The hammer
    The hammer Who’s the Wrench?
    '16 Tacoma SR5 4X4 DCLB TSS Pkg 17X8" BSW-Cooper DIscoverer AT3 4s P265/65/17
    Underworld Flex trifold, tinted, TRDPRO grill, TRDPRO shift knob, etc,etc
    If the job is done properly it should have no comeback on that same issue.
    Trouble is, not everyone is comfortable or competent with that type repair as proper backlash and pinion bearing pre-load needs to be performed.
    In other words, the comeback is not on you...This time! HAHA!
    Hope that helps
    Cheers!
  3. Jul 17, 2016 at 7:29 PM
    #163
    smitty99
    smitty99 [OP] I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Actually there's probably more to it. Could be something like driveline angle. So yea the job could have been done correctly to replace the parts. But the parts (differential) might not be the Root issue. Also the diff assembly comes pre-assembled. Gear work not needing to be done. It's remove & replace
    The hammer[QUOTED] likes this.
  4. Jul 17, 2016 at 7:39 PM
    #164
    The hammer
    It used to be a dealer only replaced the broken piece under warranty, maybe this is different now or it's Toyota thing, either way IDK in this case, but I would think pinion bearing pre-load would still need to be checked or adjusted.
    Drive angle I don't see as a problem if your truck is stock like the rest of us. Unless you're constantly going at weird angles, even so, Toyotas are made for that. Whatever the issue is, I hope they find and fix.
    Best of luck!
    Cheers!
  5. Jul 17, 2016 at 7:40 PM
    #165
    smitty99
    Scottsdale
    Or toyota dropped the ball on design somewhere for this particular set up
  6. Jul 17, 2016 at 7:42 PM
    #166
    The hammer
    If that's the case they'd be a chit load of similar TRD problems. I'm leaning to improper installation
    Cheers!
  7. Jul 17, 2016 at 7:46 PM
    #167
    smitty99
    Scottsdale
    Well if 9 or 10 of us have the problem here imagine how many must have the same problem who never even look at forums.
  8. Jul 17, 2016 at 7:51 PM
    #168
    The hammer
    Besides you I only know about the bulldog. But I believe there is a TSB on loose rear differential cover bolts as a culprit for leak. I don't think that TSB would applies to you though.
    Cheers!
  9. Jul 17, 2016 at 8:45 PM
    #169
    Yzkiley
    Yzkiley Well-Known Member
    British Columbia, Canada
    2016 MGM Tacoma Sport DCSB MT
    rain guards, hood deflector, oem tonneau, BFG ko2's, led lightbar behind grill, highlift jack mount side rail, husky Xact front & rear mats, bedrug, AFE cold air intake with scoop, TB spacer, Spec U exhaust, Hikari - lumileds Led's, any time backup cam and gps, OV tune 103B, TRD pro grille, Cali raised pod fog lights, ECGS needle bearing, Bilstein 5100's, Low range offroad 3-1 level kit, SPC light racing ctrl arms, spidertraxx 1.25in spacers, Ride right airbags, clazzio seat covers, carrier bearing spacer, diff drop spacer.....
    Aero90
    Chirping high pressure fuel pump is an easy fix. Just get some Lucas upper cylinder lube fuel treatment and put 200ml in on next fill up. Not saying it will fix them all but it worked on mine. Put it in a week ago and the chirping stopped and hasn't come back...
  10. Jul 18, 2016 at 7:51 AM
    #170
    Z50king
    Z50king DCLBOR4X4FTW
    Eric
    Southern California
    2016 DCLB Off Road 4x4 Super White
    Stock and loving it
    I am interested in this
    MasterPenguins likes this.
  11. Jul 18, 2016 at 8:16 AM
    #171
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    I have the whining noise from the rear end when I feather the gas at around 55mph. It's getting louder, I can often hear it over the radio. I was planning to bring this up at my first 5K service in a few weeks. Will having done the rear differential breather mod cause me any hassles with warranty work on this? Should I revert it to stock before I go in?
  12. Jul 18, 2016 at 8:17 AM
    #172
    smitty99
    Scottsdale
    I'd play it safe and revert. Sure you could argue all you want but why risk the hassle?
  13. Jul 18, 2016 at 8:22 AM
    #173
    MasterPenguins
    Indiana
    Something that I have noticed is that a vast majority (not all though) of the people having this issue have TRD Off Roads...
    Mace587 and smitty99[OP] like this.
  14. Jul 18, 2016 at 9:15 AM
    #174
    aero90
    aero90 Well-Known Member
    2016 TRD OR 4x4 M/T - Sold
    I wonder how much of it has to do with the fact that I can hear everything going on outside of the truck too. I'm serious, in this truck I can hear a chain rattling or suspension squeaking on a car/truck two lanes over coming up behind me on the freeway. The amount of odd noises that make it into the cabin in this truck amazes me. Seems like certain noises just blast right past any sort of soundproofing they have.
    Looks like I'll wait longer to bring it up. No sense in going through all the hassle if it is just going to come back. Plus I really want that driveline fix (hopefully) to come out first. Hopefully it doesn't get much louder for you smitty.
  15. Jul 18, 2016 at 10:14 AM
    #175
    Mace587
    Mace587 Well-Known Member
    North Carolina
    2016 DCSB TRD OR 4x4
    Well there goes any hope I had for them actually having figured out a fix. Mine is still at the dealership waiting on parts. Asked the service guy today about having the transmission TSB done while it was there and was told that they couldn't perform any other warranty work while they had an open RO for a separate warranty claim - which Corporate told me was not true. These guys just make no sense to me at this point.
  16. Jul 18, 2016 at 10:18 AM
    #176
    fdbyrne
    fdbyrne Well-Known Member
    Missouri
    2016 Tacoma TRD Off Road (Manual), 2004 4RUNNER V6 4x4
    Yes, but some are automatics and some are manuals which is important to note because they have different differentials. I don't mean just different ratios, I mean different designs. The autos have the carryover 8" rear and the manuals use the new-for-Tacomas 8.75" rear.
  17. Jul 18, 2016 at 10:19 AM
    #177
    Mace587
    North Carolina
    The second dealership I took mine to told me that they thought it was something that was probably unique to the locking diff., and they wouldn't drive another model to compare to. They wanted me to come back this week and drive an OR they were supposed to have on the lot.
  18. Jul 18, 2016 at 10:21 AM
    #178
    smitty99
    Scottsdale
    Thought the TRD OR Auto uses the 8.75"
  19. Jul 18, 2016 at 10:25 AM
    #179
    Z50king
    Eric
    Southern California
    Stock and loving it
    I will be checking this
  20. Jul 18, 2016 at 10:56 AM
    #180
    aero90
    Yeah, I didn't notice mine until after a couple thousand miles.
    smitty99[OP] likes this.
