UPDATED:am i the only one with this issue? media system restarting without reason
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 2016TacomaTRD, Oct 22, 2015.
  1. Dec 11, 2015 at 5:46 PM
    #41
    skier
    skier Well-Known Member
    Keith
    SW Colorado
    2016 red Tacoma DBSB TRD Sport manual
    Yep, 4,000 miles now and replacement HU has been perfect. Use Bluetooth, bluetooth music and/or USB tunes nearly every day with Android phone
  2. Dec 12, 2015 at 12:54 AM
    #42
    B.Richards
    B.Richards Well-Known Member
    Brett
    Redlands, California
    2016 Toyota Tacoma DC LB 4x4, White, Black Leather Interior, Tech Pack.
    5100's w/Dobinsons Springs Front 2 inch rear. 285/70/17 BFG KO2 Tires. Snugtop Hi-Liner Cap w/ Frontrunner Cross Bars and Cab Roof Rack
    Mine (JBL) would do this but more often then you are experiencing and sometimes I would have no more volume after re-boot. They replaced the whole head unit.
  3. Dec 17, 2015 at 5:32 AM
    #43
    broders
    broders Well-Known Member
    NC
    2016 Toyota Tacoma TRD Sport DCLB
    Mine did this once about a month ago and then nothing until this morning. On my drive to work which is about 45 min, it restart three different times. I called my dealership this morning, just waiting for a callback. This is BS
  4. Dec 17, 2015 at 7:35 AM
    #44
    broders
    NC
    Just got off the phone with my dealership. They are well aware of this issue and he thinks that the firmware needs updated. He said when the truck was built if it didn't have the latest version of firmware installed then that could be causing the unit to shutdown randomly. I have an appointment on 12/28 for them to check the firmware and if it isn't that they said they would have to open a "tech case" to see about getting me a new unit. I'm keeping my fingers crossed it's just the firmware. He said the appointment should only take about 60-90 minutes. I'll report back after my appointment on 12/28.
  5. Dec 17, 2015 at 7:42 AM
    #45
    bullaculla
    bullaculla IKA fabrications
    Da big big island!
    2013 MGM DCSB Tacoma 4X4 TRD Off Road
    All pro 3 link SAS kit, Diamond axle, kings on 37" MTR/K
    My 16 4Runner does it once in awhile. Just listening to normal radio. Sucks...
  6. Dec 30, 2015 at 11:57 AM
    #46
    rddakota
    rddakota Member
    RD
    CO
    14 TRD
    My 2014 does likes to reboot about once a week while I'm just listening to the radio. Hopefully Toyota will develop a simple solution so we do not have to go to the dealer.
  7. Dec 30, 2015 at 12:03 PM
    #47
    toryt
    toryt Active Member
    tory
    Layton Ut
    2014 silver tacoma
    Bilsteins 6112's and rear Dakar leaf springs, BMAF rocker guards, Relentless bed rails
    My 2014 does it about once a week and will sometimes just freeze up and not reboot. I have to turn off the truck to get it to reset. The dealer did a software update about 6 mos ago which made it better but it still does it.
  8. Jan 15, 2016 at 1:22 AM
    #48
    2016TacomaTRD
    2016TacomaTRD [OP] Part time Ninja
    2016 Tacoma TRD Sport
    Update 2: 01/15/16
    After 3 months of talking to my dealer and corporate customer service. I finally had my Head unit replaced. BUT... the same thing is happening. I have videos of it shutting of 2x in my 2 hour drive. I will post it when i find the time. I know now that this is happening to a lot of people and even in other Toyota models.. but... It's just not something I'm willing to just let go.. It's a brand new truck and it is annoying...
    Has anybody had better luck than me? I just don't have the time to keep bringing my truck to the dealer so that they can experiment on it and just tell me that they can't replicate the issue, so there is no issue.
  9. Jan 15, 2016 at 8:24 AM
    #49
    Wraith600
    Wraith600 Well-Known Member
    2016 AC TRD OR Quicksand
    At this point I would look at what actually supplies power to the unit. For example, is a connection in the back of the fuse loose?
  10. Jan 15, 2016 at 10:15 AM
    #50
    eazyrider711
    eazyrider711 Well-Known Member
    Jay
    Northern, CO
    Black DCSB T|X Baja
  11. Jan 22, 2016 at 9:39 PM
    #51
    77Chargers
    77Chargers Member
    Happened to me also. Was playing the xm radio and just shuts down and turns back on. Thought I was just getting a bad signal, so switched to playing music from the iPod. Same thing happened. About 2 or 3 times during a 2. Hour span. Will take back to the dealer.
  12. Jan 23, 2016 at 1:26 AM
    #52
    2016TacomaTRD
    If you have much time to spend at the dealer, they can actually attempt to diagnose and find out what's wrong but other members here have left their truck only to be told that they could not "replicate" the issue and stuck with waiting for a software update which has no ETA.
    I have a video of it shutting off and expressed my frustrations to the dealer until replaced my Head Unit. It still does the exact same thing. So I am not even going back to the dealer for now. I have a case open with Toyota corporate but they are not even helpful.
    I found out though that if I set my destination and actually use the GPS, it will never shut off! So I have set my destination in that 2 hour drive as Home and set the other destination as my #1 saved location. I tried this about 3x already. It doesn't shut off while the Navigation is in use. Just set a destination every time you do a long drive, if you do it regularly like I do.
    The problem with previous year models was that it shuts off when overloaded (E.G. Navigation is in use, and you're phone is connected, and you are using your XM radio). They probably overdid something trying to fix it. Now it is shutting off when the Navigation is not in use.
  13. Jan 30, 2016 at 8:11 PM
    #53
    Tanz
    Tanz Member
    Houston,TX
    2021 Tacoma TRD Off Road
    I got my Tacoma in December and this has started to happen mine as well. I've had it happen about 4 times since mid December and it did it again today on my way into work. It's rare when but it gets annoying since like you said...its a brand new truck.
    I totally intend on taking it in and see what, if anything they can do.
  14. Jan 31, 2016 at 5:54 AM
    #54
    qnyla
    qnyla Well-Known Member
    NM
    2006 & 2016 DCSB TRD Off Road 6-Speed
    Not sure this is your issue, but just FYI. This happened to me after I swapped in an old larger 27F battery to my 2016 to see if it fit (I wanted to see if I could fit that size in because it is better for winching, etc.). I drove around with the old battery for a day and had many many restarts on the media system. Replaced the old battery with a new one and back to normal with zero restarts. Might want to have your battery tested and check connections.
  15. Feb 16, 2016 at 12:24 PM
    #55
    DesertRatAZ
    DesertRatAZ Member
    Arizona
    2016 2WD 4 Door TRD Super White Tacoma
    RevTek lift, T265/75/R16 BFG TA KO2 Tires, tinted windows all the way around, dashmat from Covercraft, UVS100 Custom Sunscreen from Covercraft. More planned. WeatherTech wind reflectors are almost ready.
    I was having the issue when both my Plantronics Bluetooth headset and the Entune were connected to my phone at the same time. When I would get a notification, the Entune system would reboot. Now when I get in the truck, I turn the Plantronics headset off and let the Entune system do everything. No more reboots!!!
  16. May 11, 2016 at 6:14 PM
    #56
    Mike429
    Mike429 New Member
    2016 trd tundra
    I have a 2016 trd tundra have this problem went back hundred times with videos finally reset it after 3 months just rebooted on start up first time
  17. May 12, 2016 at 1:28 PM
    #57
    jsinnard
    jsinnard Well-Known Member
    J
    Virginia
    16 QS DCLB OR 4X4
    Have a 2016 OR no tech package with an Android phone paired and a USB connected to listen to my music library. My Entune/HU has yet to reset during any drives and the truck is just under 5k miles on it.
  18. May 12, 2016 at 8:42 PM
    #58
    hendo808
    hendo808 Well-Known Member
    2016 TRD OR Access Cab Barcelona Red
    Interior Phillips LEDs Diodedynamics LED reverse lights HIDs for lows and fogs VLED's V3 Tritons front and rear TEQ TRD Bedside Decal 35% Tint
    I have a TRDOR AC and mine restarts for no reason. No phone connected just turn the truck on and drive. I've only got 1600 miles on it. I've heard there was an update for it to be downloaded but I haven't done it yet.
  19. May 13, 2016 at 5:11 AM
    #59
    Rapidfire1
    Rapidfire1 Well-Known Member
    Shaun
    York Pa
    2016 Black TRD Sport DCSB MT
    I only have problems if I connect my Iphone(work phone) through USB or blue tooth, I have zero problems using my android phone.
  20. May 14, 2016 at 5:08 PM
    #60
    Shellshock
    Iowa
    Just had this happen to me today for the first time with 15829 on the truck. Looks like I'm gonna have every known issue with mine at the rate I'm going.
    Just driving along and the head unit locked up and there was screeching from the speakers until it rebooted. After it restarted everything was fine again.
