Updated - Dorman (junk) vs pioneer (don’t recommend either) crankshaft pulley
Discussion in '1st Gen. Tacomas (1995-2004)' started by Kristi with a K, Apr 9, 2025.
  1. Apr 10, 2025 at 4:33 PM
    that_one_1999_tacoma
    that_one_1999_tacoma Well-Known Member
    1999 Toyota Tacoma pre runner xtracab
    bbs wheels, 2001-04 guage cluster, coolant system refresh, new headlights, full 9,000 dollar repaint, grille lights, smoked bumper blinkers, valve cover gasket replacement, and new oem rear bumper
  2. Apr 10, 2025 at 6:13 PM
    MadNachos
    MadNachos Well-Known Member
    2000 Tacoma 4WD Base - no low gas warning light but it has AC!
    I would probably just keep running it. Unless you run an ultra low weight flywheel it should be fine.
  3. Apr 11, 2025 at 7:42 AM
    CrippledOldMan
    CrippledOldMan Well-Known Member
    David
    Salisbury North Carolina
    2003 TRD Crew Cab
    None
    Kristi with a K, I think by now you should have your master mechanic certificate from Toyota for all the work you've done on this Truck. Keep up the good work.
  4. Apr 13, 2025 at 10:45 AM
    Kristi with a K
    Kristi with a K [OP] Well-Known Member
    Western MA
    01' Black (was Maroon, then red) Tacoma 4x4 SR5 ACab 3.4L AT
    G-Men sticker, driver's side "backseat" window - cracked driver's side headlight cover complete with hazy look - DIY 30 footer paint lift in Bedliner Black
    Soooo….
    After installing the pioneer, yet not reassembling, I sat on it for a bit. Then it occurred to me that with that extra metal, it possibly, probably, most likely, weighs more…. So, I just removed it, which by the way, is a major PITA when the red loctite (edit - I have never used it before & thought I was screwing up by not using it. Guess I was doing it correctly all along) is fresh & cured, or at least I’m guessing that’s why.
    Anyway, the pioneer weighs in at 11.2lbs. The crankshaft is balanced for 10.1. Maybe this isn’t a big deal? But just like the lightweight pulley can have negative affects, so can one that’s too heavy.
  5. Apr 13, 2025 at 10:54 AM
    Clearwater Bill
    Billy
    Largo Florida
    Red loctite?
    Yikes!
  6. Apr 13, 2025 at 11:17 AM
    Kristi with a K
    Western MA
    Funny you say that because I have never used it before & I thought I was screwing up by not doing it. I just looked it up & no, do not use…. Live & learn…. Besides all the while as I fought to get the bolt off I’m saying to myself, I’m never using this again!
    Black97v6MT likes this.
  7. Apr 13, 2025 at 11:29 AM
    Kristi with a K
    Western MA
    Where the heck did I get that from?!?! It’s bugging me. I typically look stuff up if I’m unsure. I’m seeing to even use anti seize!
  8. Apr 13, 2025 at 12:11 PM
    Clearwater Bill
    Billy
    Largo Florida
    I've always used a new crank bolt, a little blue locktite and a torque wrench
    You are really fortunate to have been able to remove it with the red in place. Normally it takes a good bit of heat and an impact gun.
  9. Apr 13, 2025 at 12:52 PM
    Kristi with a K
    Western MA
    :muscleflexing:
    ControlCar and Black97v6MT like this.
  10. Apr 13, 2025 at 12:53 PM
    Kristi with a K
    Western MA
    Just hopin what’s left inside the crank shaft is going to be ok.
  11. Apr 13, 2025 at 12:58 PM
    Black97v6MT
    Black97v6MT 365k on the 0D0 ... 5VZFE R150F 4WD
    iMA0
    tacoLand USA
    28 years of livin' Gen1 TacoLife...
    Pics!?
  12. Apr 13, 2025 at 2:40 PM
    Kristi with a K
    Western MA
    I got it. The bolt was definitely not happy when I threaded it in. I used a small wire brush on the wanna be Dremel tool & that seemed to take care of it.
    & Phew! As much of a PITB as this whole thing has been, something going horribly wrong because of my numbnuts move woulda just done me in! Well, until I mopped myself up off the floor & got to it….
  13. Apr 13, 2025 at 8:52 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Whatever K!!!!
    Good to know others(besides me)
    Realize their mistakes and have to do work Twice !!!
    interesting Q about the weight difference
    LCE says 2.5lbs
    OE/AM (lets just average here) 10.7lbs
    IMO
    dropping 8lbs….maybe an issue
    Dropping 1.1lbs….not so much…think yur good
    hell, maybe reason OE so expensive they trademarked the weight? lol
  14. Apr 15, 2025 at 12:54 PM
    Kristi with a K
    Western MA
    The pioneer would actually add weight. Or maybe I misunderstood you.
    ControlCar[QUOTED] likes this.
  15. Apr 15, 2025 at 4:49 PM
    #35
    ControlCar
    Steven
    Sugar Land TX
    Yeah sorry
    Was thinking a ratio kinda thing
  16. Apr 16, 2025 at 6:11 AM
    #36
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Sorry to hijack this thread, but there seem to be a bunch of knowledgeable folks here:
    I'll be replacing the 3RZ in a 95.5 I just bought and I keep reading about replacing the harmonic balancer. Why not just re-use the old OEM one? Is it 'cause the front main seal rides on the HB and should have a new sealing surface?
    Thx in advance for the wisdom.
  17. Apr 16, 2025 at 7:00 AM
    #37
    Black97v6MT
    iMA0
    tacoLand USA
    The 3rz and 5vz balancers are constructed differently :notsure:
  18. Apr 16, 2025 at 7:20 AM
    #38
    DesertRatliff
    Mt. Hood, OR
    Mas Tacos Por Favor
    Definitely! I see in both cases, though, mechanics replacing the HB. What's the reasoning? Sealing surface?
