Updated in Post 20: AAL - Single Leaf or 3-Leaf Progressive?
Discussion in 'Suspension' started by Badwin45, Oct 18, 2016.
  1. Oct 18, 2016 at 8:22 AM
    Badwin45
    Badwin45 [OP] Well-Known Member
    OKC
    '10 DC 4x4 & '00 Pre-Runner
    Aries 4" Oval step tubes, Brute Force Fab rear bumper, Weathertech digifit floor liners.
    I have a stock 2010 DCSB with Bilstein 5100 (0.95" Setting) and the recall rear leaf springs to which I've added a Leer 100R topper.
    I want to restore a bit of ride-height as well as add some load capacity without dramatically affecting ride quality.
    This is a daily driver and I don't haul much often. I also occasionally tow a 6'x12' enclosed trailer maybe once a year or so. I "wheel" (if you can call it that) once a month driving pastures and dirt roads at my family's farm.
    I'm looking at one of these to options: OR Any advice on which one to go with and why would be much appreciated.
  2. Oct 18, 2016 at 8:25 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Honestly I would recommend their Dakar leaf pack. In time the AAL will have to be replaced as it will start to sag. Especially with a shell on there, the AAL might go a little quicker. Dakars give about 3 inches of height in the rear. I know its a little more money, but its one and done. I know a few who have the pack and it works well.
    Coot
    Badwin45[OP] likes this.
  3. Oct 18, 2016 at 8:29 AM
    Badwin45
    OKC
    Thank you Coot. The Dakars are out of budget and I don't really want 3" of lift. I'm going to try to keep it fairly close to stock but don't mind moving the 5100's up a notch to keep it level.
  4. Oct 18, 2016 at 8:33 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    I got you, so Im guessing about 1 inch in ride height is what you are looking for? I should check but maybe you might benefit from a Baja leaf pack? I think my Baja comes stock about 1 inch higher in the rear than your standard Tacoma...also Im swapping out my rear end in a few weeks.
    Coot
  5. Oct 18, 2016 at 8:46 AM
    Badwin45
    OKC
    That's the AllPro Baja leaf pack, correct?
  6. Oct 18, 2016 at 8:47 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Ah nevermind, it seems the Baja leaf pack only gives you about another 10mm (.4 inch) on your current leaf height.
    Coot
  7. Oct 18, 2016 at 8:47 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Sorry Im referring to my stock TRD BAJA leafs. Im sure the AP would be a nice choice if he had a budget for it.
    Coot
  8. Oct 18, 2016 at 8:51 AM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Single leaf AAL is stronger for weight carrying.
    3 leaf is not as strong but will give a marginally better unloaded (no towing weight, no hauling weight) ride.
    If you carry a regular load (tools, shell/tonneau) of 200 lbs or more I would not get the 3 leaf but a full replacement leaf pack instead. I have Dakars, myself, and they replaced a 3 leaf AAL when I got a shell. My 3 leaf couldn't handle the 220 lbs in the bed, I lost all lift.
    Bear in mind also that the lift heights are all quoted for stock trucks. No extra weight in sliders, bumpers, toolboxes, bed covers, etc. Lift height will decrease as weight goes up.
  9. Oct 18, 2016 at 8:52 AM
    T4RFTMFW
    RideRite bags are another option.
  10. Oct 18, 2016 at 9:07 AM
    jakebray
    jakebray Well-Known Member
    jake
    SoCal
    13 PreRunner
    Locked DCLB with Kings and crap
    I have a progressive leaf pack with a shell and I think it works out pretty good, tow a boat as well.
    I think that it's all pro but can't remember
  11. Oct 18, 2016 at 9:08 AM
    Coot83
    Scottsdale, Az
    2012 Baja TX
    Im guessing the All Pro Expos? Those are a solid leaf pack, especially if you tend to tow stuff a lot. Im actually rolling with some deavers on my set up when I get it installed in about 3 weeks!
    Coot
  12. Oct 18, 2016 at 9:14 AM
    jakebray
    jake
    SoCal
    13 PreRunner
    No the progressive pack, 3 leaf aal
  13. Oct 18, 2016 at 3:20 PM
    Badwin45
    OKC
    Thanks for the advice guys. I decided to go with the 3-Leaf set for the difference in ride quality since it's my DD. If it sucks, I'll go for broke and completely replace the rear leaf springs.
    I might even be able to sell the OEMs and the AAL to offset the cost. If not, I'll forge 'em into cutting tools.
  14. Oct 18, 2016 at 3:26 PM
    DriverSound
    DriverSound Señor Member
    Oregon
    2015 DCSB OR 4x4
    Too few to list.
    Sumo springs might be another option for you. I've had both single AAL and progressive. The Progressive is a bit stiffer than stock but not much but I've never had a shell on with it. The single AAL is stiff but rode better with a shell. I like the single better. Had it for 4 years with no sag and I towed with it.
    wake100 likes this.
  15. Oct 20, 2016 at 8:21 AM
    Badwin45
    OKC
    Since I'm going to be in there anyway, I'm going to replace the rear shocks. Will Bilstein 5100 rear shocks work with the 3-leaf AAL? Bilstein's site lists them for up to 1" but I'm not sure what I'm going to ultimately wind up with after installing the AAL.
  16. Oct 20, 2016 at 8:50 AM
    jakebray
    jake
    SoCal
    13 PreRunner
    They make one for larger lifts also. I just have the regular ones for the one inch. My leaf pack only lifted 1.5 inches with the progressive aal
  17. Oct 21, 2016 at 10:19 AM
    TRlPPlN
    TRlPPlN Pavement Cruiser
    Bay Area, CA South SF to be precise
    MGM DCSB 09 DC TRD Sport 4x4 - Family Hauler
    if you go with 3 leaf progressive, keep the overload on. also you can with a combination of a single AAL + sumosprings. i myself will find out soon enough how my recall leaf pack + hs progressive is going to hold up with a shell. i'll be planning on getting sumosprings to prevent future sagging.
  18. Oct 22, 2016 at 11:22 AM
    dirtnsmores
    dirtnsmores A camping truck
    Southern California
    06 DCLB Prerunner
    OME885/5100, DAKAR MED-DUTY, SOFTOPPER
    can you explain to me how the sumo springs work? I another another half inch or one inch to my aal setup. Not carrying much weight.
  19. Oct 22, 2016 at 11:38 PM
    TRlPPlN
    it's basically an extended bumpstop that replaces the OEM one and adds weight carrying \ hauling support to the suspension with out having to buy a new leaf pack or airbags. Pretty good video below.
    https://www.etrailer.com/Vehicle-Suspension/Toyota/Tacoma/2009/SSR-610-40.html
    dirtnsmores[QUOTED] likes this.
  20. Nov 7, 2016 at 8:44 AM
    Badwin45
    OKC
    I installed the Wheeler's 3-Leaf AAL and Bilstein 5100's last Friday and went out to the farm over the weekend to do some work. I gained the advertised 1.5" and it rides very well. I drove it with 320# of weight in the back and without, and handling/ride quality were much improved over factory. Would do it again in a heartbeat.
    YotaDan likes this.
