UPDATED - Now with Twin cases and triple sticks "El Taco Diablo" 4x4 swap and B.S.
Discussion in '1st Gen. Tacomas (1995-2004)' started by El Taco Diablo, Aug 7, 2018.
  1. Feb 18, 2019 at 7:48 AM
    #221
    El Taco Diablo
    El Taco Diablo [OP] Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    I'll take a picture of the 2 VSS that I have and post them later today.
    Not going out to work on it quite yet. Too f'n cold.
    And I'm a little annoyed at Modesto Toyota right now. We went to mount the T-case last night and found out their shit for brains parts guy gave me the wrong bolts. So now we have to go over to @foxrcing07 and snag one off his and see if we can find the right ones at the hardware store.
    But I'm definitely going to have to drink more coffee before I do anything... This project is wearin me out!
  2. Feb 18, 2019 at 8:26 AM
    #222
    v5ensx
    v5ensx CARB legal is not CALI legal
    Curious about this. Where in the pill shape like detent located and why it need to be remove?
  3. Feb 18, 2019 at 8:35 AM
    #223
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    It's located in the T-case cover. You can see it in the hole here.
    Removing it (and cutting the ear off the shift rail) allows 2 Hi - 2 Low and 4 Hi - 4 Low to be independent of each other.
    unstpible and TrentonTDG like this.
  4. Feb 18, 2019 at 8:52 AM
    #224
    v5ensx
    Tcase had to be torn apart to remove the detent?
  5. Feb 18, 2019 at 8:56 AM
    #225
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    The cover just had to be removed.
    TrentonTDG likes this.
  6. Feb 18, 2019 at 9:06 AM
    #226
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Ok, here's what we've got
    Left = the VSS from the trans that was removed from the truck.
    Right = the VSS from the T-case that is going in to the truck.
    @BartMaster1234 @mechanicjon @foxrcing07 @Tour991
    @anyone who may have ran into this is their conversion.
    :help:
    unstpible, TrentonTDG and Pella like this.
  7. Feb 18, 2019 at 9:33 AM
    #227
    mjhenks
    mjhenks Well-Known Member
    So.Cal
    04 Jade Green TRD V6 DC
    I think you need one of these to convert the mechanical to electrical VSS.
    http://www.lowrangeoffroad.com/toyo...cal-speedometer-vss-adapter-301447-1-kit.html
    - Why did you change your lights to blue? Just looks or another reason?
    - Any tips or thing you would have done different in R&R for the trans?
    - How bad was replacing the rear main seal on the engine and did you have to drain the oil?
    Thank you. You are about 2 months ahead of me so i am soaking it all in.
    unstpible likes this.
  8. Feb 18, 2019 at 9:58 AM
    #228
    Miguel_prerunner7
    Miguel_prerunner7 Well-Known Member
    Miguel
    Downey Ca
    Sold 2001 tacoma prerunner 4x4 conversation 09 taco
    Snorkel
    : suspiciousgarage.com/collections/drivetrain/products/marlin-crawler-vss-vehicle-speed-sensor
    worked out for me
    goodluck
  9. Feb 18, 2019 at 10:47 AM
    #229
    BartMaster1234
    Tyler
    Pittsburgh, Pennsylvania
    Flux Capacitor
    Well that’s just bizarre. That’s either a broken electrical VSS, or a cable driven VSS meaning it came from a 1995-1997 truck.
  10. Feb 18, 2019 at 11:54 AM
    #230
    04Pre_Runner
    Andrew
    2004 DC Tacoma SR5 4WD V6
    I didn't have the sensor on the right at all from my 1996 4Runner transfer case. I had a plug sitting in the VSS hole. So I bought a sensor on eBay that is identical to your right one but with an electrical plug installed. Besides the missing mounting bracket on yours to bolt it up.
    My whole VSS was less than the electrical plug conversions that Low Range and Marlin Crawler sell but I'm not 100% sure what longevity will be on my eBay VSS versus an OEM Toyota VSS. Time will tell I guess. Then I just extended my harness to reach back to my transfer case.
    The plastic gear my sensor came with was 33 teeth and was way off for my 4:10 gear ratio. A couple 4WD conversions on Tacoma World involved a guy buying multiple gears from a Toyota yard and sending back what didn't work. I found the 30 tooth gear to be the most accurate gear for 4:10 and it's only thrown off .5mph by my slightly larger 265/75/16 tires. But since you have a gear from your transfer case you might be good to go already there.
    Here is the full sensor on eBay that I'm running.
  11. Feb 18, 2019 at 12:55 PM
    #231
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    That is SLICK!!!
    I was having to review in my mental rolodex where that indicator came from until I read the description in detail.
    Very nice!
  12. Feb 18, 2019 at 1:01 PM
    #232
    BartMaster1234
    Tyler
    Flux Capacitor
    Thank you! Figured the stock 4WD symbol was too generic for me, so I wanted to take it a step up. I scanned the original lens in Photoshop and recreated it with several layers of Projector Transperancies glued together.
    unstpible and POSTacoMike like this.
  13. Feb 18, 2019 at 8:18 PM
    #233
    kuntry09
    kuntry09 Well-Known Member
    Cam
    Douglas, Georgia
    '99 extended cab Tacoma 4x4 converted Prerunner
    You swapped pans from your A340E to your A340F? Is that correct? When I compared pans on mine, the A340E pan did not have the same capacity as the A340F.
  14. Feb 18, 2019 at 8:21 PM
    #234
    BartMaster1234
    Tyler
    Flux Capacitor
    Correct. They do not. The A340E has a different capacity than the A340F, thus I don't recommend re-using the original pan. The ATF capacity difference is very negligible. The Torque Converter holds a few more quarts, all-in-all I think my truck took 17 Quarts of ATF.
  15. Feb 18, 2019 at 8:25 PM
    #235
    04Pre_Runner
    Andrew
    Only thing I changed was my output shaft. Figured it wouldn't make a difference either way but I might be wrong. I still have the A340F sitting in pieces in my storage shed.
  16. Feb 18, 2019 at 8:26 PM
    #236
    BartMaster1234
    Tyler
    Flux Capacitor
    I really have no idea why there is a difference in fluid capacity. Could be the capacity of the torque converter, since they are different (stall speed) between the E and F.
    Lfaub03 and 04Pre_Runner[QUOTED] like this.
  17. Feb 18, 2019 at 11:47 PM
    #237
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    My pans are exactly the same capacity. At least the dimensions of the pans are the same.
    Area51Runner and TrentonTDG like this.
  18. Feb 19, 2019 at 5:00 AM
    #238
    kuntry09
    Cam
    Douglas, Georgia
    Interesting....for my 99, the pan on the A340E was obviously not as deep as the pan I ended up having to order for the A340F, because of an issue with the dipstick. Glad it worked out easier for you than it did for me! :thumbsup:
  19. Feb 19, 2019 at 6:39 AM
    #239
    mjhenks
    So.Cal
    Regarding oil pan capacity I think it depends on what year. My original 04 2WD and my replacement 04 4WD tranny's have the same oil pan and same dip stick tube. It seems that somewhere before 03 the pans were not the same as was the dip stick tube. I measured every aspect of my two and they are the same in every way.
    Just FYI.
    Area51Runner and kuntry09 like this.
  20. Feb 19, 2019 at 11:13 AM
    #240
    Lfaub03
    Lfaub03 4wd wannabe
    Logan
    Flagstaff, AZ
    2003 Prerunner TRD
    4wd conversion
    When I swapped to my A340F I ended up using my A340E pan because the F was pretty busted from the previous owner. I also swapped in my E’s torque converter and valve body though, so I think it’s pretty negligible at that point
    Area51Runner and 04Pre_Runner like this.
