UPDATED - Now with Twin cases and triple sticks "El Taco Diablo" 4x4 swap and B.S.
Discussion in '1st Gen. Tacomas (1995-2004)' started by El Taco Diablo, Aug 7, 2018.
  1. Jan 26, 2023 at 12:03 PM
    #401
    El Taco Diablo
    El Taco Diablo [OP] Professional Pinstriper
    Matt - KN6DZP
    Hughson, CA
    Impulse Red DC, 5vz-fe, 4wd swap, LT, dual case, F/R locked
    Just 3 tons of fun!!!
    I figure I don't want that coupler to move, at all.
    Like you said... If it ever needs to come off, it'll probably be a muther fucker. But hopefully it never needs to come off :fingerscrossed:
  2. Jan 26, 2023 at 12:06 PM
    #402
    theesotericone
    theesotericone Well-Known Member
    Bishop CA
    That was my thinking.
  3. Jan 26, 2023 at 12:08 PM
    #403
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    A little bit of heat directly on that coupler would solve the problem. If it ever came to that.
  4. Jan 26, 2023 at 12:25 PM
    #404
    betterbuckleup
    betterbuckleup Well-Known Member
    Ian
    Concord, CA
    2000 Tacoma SC 2.7 4x4 5spd
    Fwiw I put RTV on all mating surfaces, even where it's allegedly supposed to be a "dry fit". Might as well since you're in there.
    Heard too many stories about peoples' setups leaking in places it shouldn't be leaking.
  5. Jan 26, 2023 at 8:15 PM
    #405
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Mated the cases again and got all the shifting to work properly.
    Shifter bench test ✔️
    jubei and Yetimetchkangmi like this.
  6. Jan 28, 2023 at 5:30 PM
    #406
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    That was a bitch
    Littles and essjay like this.
  7. Jan 29, 2023 at 3:59 PM
    #407
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    That was a bigger bitch
    foxrcing07 and essjay like this.
  8. Jan 29, 2023 at 5:56 PM
    #408
    foxrcing07
    foxrcing07 KO7FOX
    Morgan
    Modesto, CA
    2019 Raptard 2001 TJ
    Dirt
    Yea that part sucked!!!
    I don’t remember can the heims and rod be in boarded?
  9. Jan 29, 2023 at 6:21 PM
    #409
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    No... the heims are too big to get the bolt through them and through the arm on the back tcase base. (back of the rod)
    Also, if you put the heim on the inside it puts the bolt too close to the middle shifter. (front of the rod)
  10. Jan 29, 2023 at 7:06 PM
    #410
    02hilux
    Planet: EARTH
    o_O
  11. Jan 29, 2023 at 7:16 PM
    #411
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    The back of the rod, at the adapter plate on top of the jshift. Green lines. You can't put the heim on the inside because the heim is too big. The bottom of the heim hits the aluminum plate, before the hole lines up with the hole on the arm that the heim bolts to.
    The front of the rod... blue line. If you put the heim inside, the bolt head hits the middle shifter when you move the middle or left shifter.
  12. Jan 29, 2023 at 7:19 PM
    #412
    02hilux
    Planet: EARTH
    It's not designed for inboard. That's why I suggested a few months ago to check with Dave's OR. His designed is better IMO.
  13. Jan 29, 2023 at 7:23 PM
    #413
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    I was answering a question about whether they could be inboarded... and stating the reasons why it can't.
    Your suggestion was made after these were already ordered.
    Lmao... the sticks pictured look pretty much just like these did before I hacked them up to make them fit in the stock shifter location
    I don't have three transfer cases.
  14. Jan 29, 2023 at 7:53 PM
    #414
    02hilux
    Planet: EARTH
    I see
  15. Jan 29, 2023 at 8:18 PM
    #415
    Yetimetchkangmi
    Yetimetchkangmi Well-Known Member
    Benjamin
    Newcastle, WA
    03 Tacoma 4x4 The Yeti
    ARB front locker, Custom high clearance rear bumper, Custom plate front bumper, mile marker winch PE8, safari snorkel, Deck Plate Mod Fox 2.5 rr DSC, Camburg UCA, squeaky Dakar leafs, 5125 10" and custom 7.5" shackles, thee finest PNW pinstripes, MT-R, Nissan crew cab roof rack??? wtf is that about??? Allpro skids, Rigid duallys President McKinley CB with PA Recaro SRD with Wedge Engineering Morimoto retrofits Champion Rad - Failed Tundra brakes
    Great Progress! Keep it up and continue with photos and updates.
    You got this!
  16. Jan 29, 2023 at 8:32 PM
    #416
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Thanks bro... I'm really starting to get burned out. I'm taking tomorrow off of work, hoping I can make a big push to get this thing wrapped up.
    Lots of big projects this winter, taking a toll on me. I'm running close to solo on all this.
  17. Feb 1, 2023 at 6:28 PM
    #417
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Well, yesterday was big progress.
    Played hooky from work yesterday...
    Got the cases final torque
    Filled the Tcases
    Installed drivelines
    Swapped out the 16 in coils for some 18 inch coils
    Fixed the alignment
    Adjusted the front brakes
    Got the shifter linkages adjusted and tightened.
    Finished the patch in the floor board.
    My son had the day off today, so he put the interior (mostly) back together. I just finished splicing the wires back in for the seats.
  18. Feb 2, 2023 at 5:36 PM
    #418
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Road tested = no issues
  19. Feb 3, 2023 at 9:04 AM
    #419
    El Taco Diablo
    Matt - KN6DZP
    Hughson, CA
    Drove it to work today (around 35 miles)
    No issues, no leaks, no wierd sounds or smells. I'd say we're good to go. Now I just need to get the skids back on and repack the tools the way they should be, and she should be ready for a trip to Hammers.
    Lfaub03, Ricardo13x, essjay and 3 others like this.
  20. Feb 3, 2023 at 9:12 AM
    #420
    Littles
    Littles Stupid is as stupid does.
    Bryan
    Elizabeth, CO
    3 tons of fun
    Been enjoying watching all your hard work since December. You've put a lot of hours in that garage. Glad to see it all come together. Badass rig. :thumbsup:
