Updated pics of rcd lift,limiting straps,aal
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Kdawwwg, Oct 31, 2010.
  1. Oct 31, 2010 at 2:54 PM
    Kdawwwg
    Kdawwwg [OP] Well-Known Member
    Ken
    Draper,Utah
    2010 Magnetic Grey DC Long Bed TRD Sport 4x4
    RCD 4.5" Lift ,Moded to 5.5",1.5 inch Toytec AAL Light Raceing UCA's, 285/70/17 Duratracks, Procomp 7028 Wheels 17X8.5x4.75, Leer XQ Shell,Keyless Entry,Bedrug, Kartec Front End Limiting Straps.
    pics 1 an 2 show limiting straps installed,as the light racing uca has no stops ,the ball joint was hitting spring at full droop,problem solved
    pics 3 an 4 show a little flex,as i was testing to see if the emergency parking brake cable had enough length[just barely]
    pic 3, 4, an 5 has the 1 1/2 inch add a leaf installed on non tsb springs, this got me evened up around 42 1/2 inch fender to ground,on all fours
  2. Oct 31, 2010 at 3:06 PM
    0wrx2
    0wrx2 Well-Known Member
    north nj / upstate ny
    '10 trd sport 4x4. dbl cab. shrt bed.
    ever play on that hill across the street? looks inviting :D
  3. Oct 31, 2010 at 3:16 PM
    kinkrider101
    kinkrider101 Well-Known Member
    santa barbara
    2007 cummins/2007 tacoma
    wheels and tires
    wow dude yours has so much more flex than mine
  4. Oct 31, 2010 at 3:24 PM
    TexasIslandBoy
    TexasIslandBoy THE RED DRAGON!!
    Andrew
    South Texas. SPI
    07' trd offroad 4X4 (For Sale)
    pro comp 6inch lift 35'' tires moto 950's radfo coilovers magnaflow exhaust 5/16" front skidplate usa spec ipod interface tree pin strip mod dry drop in filter full size BFG KM2 spare
    where did you order your straps from ?
  5. Oct 31, 2010 at 3:27 PM
    nighthawk87
    nighthawk87 Well-Known Member
    what do the straps do, other than the obvious...
  6. Oct 31, 2010 at 3:37 PM
    Kdawwwg
    Ken
    Draper,Utah
    that hill is the old widomaker hill climb ,if your old like me you will remember watching it as a kid on ABC wide world of sports,an yes we climb the back side to get up top an launch our para-gliders
    http://www.kartek.com/
  7. Oct 31, 2010 at 3:38 PM
    Carson
    Carson Well-Known Member
    Carson
    Modesto, California
    05 TRD Sport 4x4 SR5 V6
    Garage Fabbed +2 LT, FOA 2.5 RR w/ Comp Adj, 35 XMTs on Level 8s, 50T Spring Under w/ 13" Shackles, Elite Front Bumper, AP Rear, Retrofitted, Wicked Flow, Custom Roof Rack, Custom Sliders, Custom Scratches, 12" JL and an Audiopipe amp.
    They limit the travel of the suspension so that it doesn't travel too far and rub/damage items.
    Nice truck btw.
  8. Oct 31, 2010 at 3:47 PM
    Kdawwwg
    Ken
    Draper,Utah
    limits down travel ,aftermarket uca i have don't stop down travel, i was getting ball joint damage on spring, an CV boot damage off of lower control arm
    now i can adjust were i want it to stop
    now some shocks stop down travel, the rcd 4.5 kit shocks do not
    plus its not good on the shock
    i regularly get the truck on 2 or 3 wheels when 4x4ing, safest way to save parts i could come up with,was straps
  9. Oct 31, 2010 at 3:57 PM
    Kdawwwg
    Ken
    Draper,Utah
    if i had stock upper arms ,or a upper arm that has stops,then i wouldn't have to have straps,but i like my light racing arms,
    from were I'm welded to frame to center of lower shock bolt is 1 1/2 inch's of travel
    at the wheel that gives me a little over 2 5/8 inch's of wheel travel down from riding position
    the strap is 12in ,for every 12in of strap there is 1inch of stretch,
    so there is only 1/2inch of slop in the strap[just looks tight, its not]
