Updated w/fix! Supercharger coolant leak on the reservoir
Discussion in 'Performance and Tuning' started by novanut21, Feb 15, 2015.
  1. Feb 15, 2015 at 5:09 PM
    novanut21
    novanut21 [OP] Well-Known Member
    Brent
    North Central,WV
    2009 TRD SPORT
    AFE CAI, Magnaflow cat-back, TRD S/C, TRD Quickshifter, URD Fuel Pump Kit, Wet Okoles Front&Rear, WeatherTech Mats, Sockmonkey Decals, Satoshi grille, JBA "shorty" headers, URD Y-Pipe, TTC Oil Catch Can, Lotek Dual Apillar gauge pod w/ Autometer Phantom II AFR & Vac/Boost, URD Pulley, HID Retrofit.
    I have found a coolant leak on the bottom outlet on the coolant reservoir. It is only a small leak, it is leaking past the hose clamp and dripping on the inner fender. I have removed the lower hose and trimmed off as much as possible and tried 3 different hose clamps and nothing has worked. I did notice that the hose does not fit snug to the outlet, I feel the hose is slightly too large for the outlet. Has anyone had this issue? Also, does anyone know of a possible aftermarket reservoir?
    Not my photo I pulled it from here, the outlet in question is in the red box.
    Update
    Today I gathered all the parts and fixed this pesky leak.
    1. New coolant reservoir (ended up not using old reservoir wasn't cracked)
    2. 6" piece of 5/8" heater hose
    3. 4 new hose clamps 2 for 5/8" hose 2 for 3/4" hose
    4. 1 Brass Coolant Hose Connector 5/8" x 3/4"
    The 5/8" hose fits MUCH better on the coolant reservoir it was so snug I had to add a drop of soap on reservoir to slide it on. I snipped about 1 1/2" off the 6" piece 5/8" hose and about 3" off the original 3/4" hose. Then spliced them together with the brass connector tightened down hose clamps and refilled the reservoir and took it for a spin and rechecked everything and NO MORE LEAKS! :yay:
    henryp, jamesepoop, bowhun2r and 2 others like this.
  2. Feb 15, 2015 at 9:28 PM
    Super Werty
    Super Werty Sleeper 4x4
    Arizona
    07 TRD Tacoma
    air and fuel
    happens to all of them. Only solution is to get it tight and then put some "get it right" black sealant and seal the hose to the outlet. I did this and it worked for years
    do not over tighten the clamp...it can crack the reservoir and it's a pita to find a new one.
    Biscuits likes this.
  3. Feb 16, 2015 at 10:12 AM
    novanut21
    Brent
    North Central,WV
    2009 TRD SPORT
    Well thats disappointing, I guess I'll RTV the crap out of it then. Thanks Werty!
    Also, Im gonna leave these links here for future reference. Second link is for a new supercharger coolant reservoir I believe there is no photo to verify but based on the part number, description and make and model matches it looks to be the correct part.
    http://trdparts4u.toyotaofdallas.com/scripts/prodList.asp?idCategory=-72
    http://trdparts4u.toyotaofdallas.com/scripts/prodView.asp?idproduct=-9186
  4. Feb 16, 2015 at 11:49 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Mr. Gasket 1 Minute gasket maker, in a grey bottle, work very well as well. :thumbsup: Just another option.
  5. Feb 24, 2015 at 6:01 PM
    novanut21
    Brent
    North Central,WV
    2009 TRD SPORT
    I went ahead and ordered a new coolant reservoir. I tried to RTV it and it is still leaking I believe I may have cracked the reservoir from over tightening the hose clamp. I'm going to take the new one to the parts store and see if I can get a better fitting hose that will also fit over the coolant pump. Or option 2 would be to fit a smaller hose onto the outlet of the coolant reservoir then add in a one way barb to go back to the orginial hose. I don't think that small reduction at the outlet would effect the volume of coolant being moved.
  6. Mar 1, 2015 at 3:52 AM
    SabMotocross
    SabMotocross Well-Known Member
    Bobby
    Santa Fe, Texas
    2014 Tacoma PreRunner SR5 DCSB V6 TRD S/C
    TRD BAJA Suspension...Rims and tires, blackout badging, TRD oil filler cap, front skid plate, N-Fab step bars, GrillCraft custom upper and lower grills. K&N air filter, TRD Supercharger.
    Let me know how that works for you!
    I've actually noticed a little coolant seepage from the screw-on cap. Not much, but still......
  7. Mar 2, 2015 at 10:11 AM
    Blasphemous
    Blasphemous Well-Known Member
    San Fernando Valley, CA
    2012 TRD Sport DC 4x4
    TRD SC, Stealth Pulley, DTLT Headers, URD MK3 Catback Exhaust, AFE II Intake
    I'm having this same problem, but on both sides of the coolant reservoir.
    Is that normal as well?
  8. Mar 2, 2015 at 10:36 AM
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    not sure why I didnt think of just adding RTV or the like to this.. :facepalm: ive had a small slow leak as well. ill fix that!
  9. Mar 3, 2015 at 1:57 AM
    novanut21
    Brent
    North Central,WV
    2009 TRD SPORT
    Is it leaking on the inlet and the outlet? Or the reservoir itself is leaking? It seems they all leak at the outlet apparently but I do not know of any other places there have been issues.
  10. Mar 3, 2015 at 5:02 AM
    Conumdrum
    Conumdrum Well-Known Member
    Las Vegas
    2014 Tacoma
    2WD Sport Nav SC V-6 Mall crawler Home Depot truck
    My top inlet has a minor leak. Pink around the hose, nor drip etc. Will be addressed when I take it in for the 1 year oil change. Yea, don't think they did to well on the design of the reservoir. Made fully formed plastic, the hoses are probably a bit too big and possibly flashing on the fittings make for easy leaks. My res has dropped less than .5" in 3 months, it helps I only have 1000 or less miles since the SC install. Early April I'll take it in, see what they do........ I will ask for the leftover coolant or make sure the dozen donuts I give to the service guy makes that happen........
  11. Mar 3, 2015 at 7:49 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Mr. Gasket 1 Minute gasket maker. Rated for coolant, and cures really quickly.
  12. Mar 3, 2015 at 7:51 AM
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    perfect :thumbsup:
  13. Mar 3, 2015 at 12:06 PM
    Blasphemous
    My inlet and outlet is leaking on the reservoir. I'll give Mr.Gasket a shot.
    I've inspected before and the reservoir itself is fine. Just seems that the hoses are too stiff to properly seal around the outlet/inlet.
  14. Mar 12, 2015 at 9:16 PM
    novanut21
    Brent
    North Central,WV
    2009 TRD SPORT
    Updated w/fix!
  15. Mar 13, 2015 at 6:13 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Well done. :thumbsup:
  16. Jan 5, 2017 at 1:56 PM
    Camby
    Camby Well-Known Member
    Brian
    Denver
    2006 Tacoma TRD Off-Road
    Magnuson Supercharger TRD CAI Catch Can After market dual exhaust Heated Mirror Kit Install Aftermarket Head and Tail lights Several accessory Mods
    Just finished installing the SC last weekend, and having a drip problem at the reservoir as well. Was planning on adding a second worm clamp toward the end of nipple of the reservoir. Hopefully blocking any coolant that is getting in between the nipple and hose.
  17. Feb 24, 2017 at 11:46 AM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    Just noticed mine is doing the same thing. Gonna throw some tape on it and deal with it later. But probably do the hose fix mentioned above. Thanks @novanut21 for coming up with this.
    novanut21[OP] likes this.
  18. Feb 24, 2017 at 11:55 AM
    Camby
    Brian
    Denver
    I ended up using a non solid gasket sealer, and two worm clamps (one up near the reservoir, one towards the end of the nipple). Probably over kill. BUT, no more leaks.
  19. Dec 5, 2017 at 7:16 AM
    Harry
    Harry Science, Bitches
    Santa Fe NM
    15 TRD Off Road DCSB
    Found a couple drips under my truck this morning :annoyed:
    Glad I'm not the only one and found this fix :thumbsup:
  20. Jan 3, 2018 at 7:18 PM
    White lightning boosted
    White lightning boosted Well-Known Member
    Jesse
    Poulsbo
    15' DCSB OR S/C
    Lift, pedal commander, led foglights, led interior lights, led back ups, led under lighting, urd tcai, led headlights, methanol injection, 76mm tb, hood struts, dif breather mod, ratiotek trans kit, x-series gauges, true cool trans cooler, belt wrap mod, 2.8 pulley
    I'm curious if an aftermarket aluminum tank is an option. Or if an aluminum pipe section with a heat sink would be advantageous for temp reduction? Or am I over thinking shit and opening up a situation for problems. Feedback welcomed.
