Updated with install pics - Will drilling into pinch weld void warranty?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by pdxrado, May 31, 2019.
  1. May 31, 2019 at 9:40 AM
    pdxrado
    pdxrado [OP] Well-Known Member
    Portland, OR
    Black 19 DCSB Sport
    Question for the group. I prefer the look of hoop steps to nerf bars or running boards so I ordered some to install onto my truck so my wife and kids can climb into it better.
    https://www.amazon.com/gp/product/B001DME528/ref=ppx_yo_dt_b_asin_title_o01_s00?ie=UTF8&psc=1
    In order to properly install them I will need to drill one small hole for each one into the frame of the truck. I am somewhat concerned this could void the warranty based on some research I've done. Does anyone have experience with this? I called the service department of the dealer that I purchased the vehicle from and all they would tell me is that it probably wouldn't but it "could". I got the sense this was somewhat of a subjective decision.
    My questions for the group:
    -Any experience with drilling holes into frame and whether it can or will void the warranty?
    -Is anyone aware of hoop steps that do not require drilling? Or is the location of the preexisting bolt holes prohibitive to any hoop step being able to use them?
    -Any service department managers happen to be on this forum and can provide advice?
    My truck is a week old so it would be pretty damn stupid to risk voiding the warranty.
    Thank you!
  2. May 31, 2019 at 9:45 AM
    Clearwater Bill
    Billy
    Largo Florida
    The only thing that can be voided is the altered part itself (the frame), or if they can prove the altered part affected whatever part is in for warranty work at the time.
    For example, your AC goes out, your diff leaks or your CPS fails. Your work has nothing to do with any of those.
    And no, they cannot void the entire vehicle warranty. See the magnuson-moss warranty act.
    I'd say you have no risk at all.
    Inferno! likes this.
  3. May 31, 2019 at 9:56 AM
    Freegolf
    Freegolf Well-Known Member
    Denver
    2016 offroad, manual tran
    Ever drill a hole into a frame? That is just too much work for a step. They make steps that go into the prefabed holes. I would go that route if I were you. Completely unneccessary drilling into the frame considering the market is seemingly flooded with nerf bars, tube steps, running boards etc. where no drilling is required.
  4. May 31, 2019 at 10:00 AM
    vuTron
    vuTron Well-Known Member
    SF Bay Area
    2016 Quicksand TRD O/R DCSB AT
    +1
    SilverBulletII and Sgt.Tee like this.
  5. May 31, 2019 at 10:02 AM
    TailHook
    TailHook You just gotta keep livin' man, L-I-V-I-N
    Alan
    Southern UT
    2018 TRDOR 4X4, 2007 Sequoia 4X4
    According to the installation instructions for those steps, they install on the rocker, not the frame.
    AWF ROWD, SR-71A and Freegolf like this.
  6. May 31, 2019 at 10:11 AM
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
  7. May 31, 2019 at 10:12 AM
    pdxrado
    Portland, OR
    Black 19 DCSB Sport
    I have a buddy who runs a shop who can do it at his home shop.
    I seriously cannot find a single hoop step that uses the prefabed holes. Link?
    @TailHook - you can do both is my understanding but I guess the same question would apply to the rocker.
  8. May 31, 2019 at 10:13 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I had a buddy who had sliders welded onto his frame, and then toyota replaced his entire frame under the rust recall. If that's the route you wanna go with that step, you'll be fine.
    Skydvrr likes this.
  9. May 31, 2019 at 10:20 AM
    TheFang
    TheFang No Big Deal
    SoCal
    Tacoma TRD Sport
    TRD Exhaust, URD Short Shift, TRD Supercharger, Hellwig rear sway bar, TWM shift knob, limo tint, URD Y-pipe, URD LT Headers, URD Rear O2 Sim, Custom tube front and rear bumpers, LED spot pods, K&N CAI
    I have drilled holes in my frame to install a rear anti-sway bar.
    Things that will help:
    - A corded drill. Battery drills will get the job done if it's all you have though.
    - Oil as you drill. Even if WD-40 is all you have, spray that on the hole and drill bit as you go. A buddie is useful for this.
    - Drill bits ment for metal. Dont use wood drill bits cause you will just burn then up.
    - Drill a pilot hole first. Use a smaller than you need bit size to get the center of the hole where you want it. Its eaiser to control a smaller bit when you first start. Then you can go up in size and not worry about the bit walking around on you.
  10. May 31, 2019 at 10:25 AM
    pdxrado
    Portland, OR
    Black 19 DCSB Sport
  11. May 31, 2019 at 10:29 AM
    Wixo
    Wixo Platinum+ Member
    Hank
    ‘21 SR5 Tundra CM 5.7L Barcelona Red
    Tint, LED interior
    I do not recommend those at all. I had them and evetually they got pushed back a bit and would rub my frame. They left some little cuts on it. I had to re spray over those areas.
  12. May 31, 2019 at 10:40 AM
    pdxrado
    Portland, OR
    Black 19 DCSB Sport
    Thanks @Wixo ! Anyone else had this experience?
  13. May 31, 2019 at 10:44 AM
    Wixo
    Hank
    Tint, LED interior
    If you're still set on em Ill sell you mine
  14. May 31, 2019 at 10:58 AM
    Drunken Chewbacca
    Drunken Chewbacca Well-Known Member
    Josh
    3rd Gen Taco
    Not enough to list
    Get some Bolt On rock sliders....
  15. May 31, 2019 at 11:19 AM
    Inferno!
    Inferno! Well-Known Member
    El Dorado Hills
    2018 TRD OR Inferno 285/65/17
    Supercharger, sway bars, lift, leather, tires, Gobi, etc.
  16. May 31, 2019 at 11:24 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
  17. May 31, 2019 at 11:26 AM
    dilbert
    dilbert AI Member
    PNW
    The owner spent spent $3500 (not including the value of the free legal representation(~12k)) and had their car impounded. In the end they were awarded a $200 part. I think the owner lost worse.
    Running Board Man likes this.
  18. May 31, 2019 at 11:30 AM
    Inferno!
    El Dorado Hills
    It shows the Act works. I waved the printed Act to my dealer, threatening to retain an attorney after they declined my warranty for modifications. The dealer changed their mind and installed a $2,500 new transmission under warranty. Granted the other guy had a tough go of it, but it is an overstatement to say the Act has no teeth.
  19. May 31, 2019 at 11:38 AM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    It is your truck. Drill baby drill. Your warranty will run out before it rusts through anyway so it’s a mute point. If you are actually on the frame bar that’s pretty unlikely.
    Welcome to TW. In a year you’ll have so much stuff bolted to your truck you won’t have any part not drilled. :sandwich:
    Giggity Reid and Inferno! like this.
  20. May 31, 2019 at 12:07 PM
    Bleep100
    Bleep100 TOYOTA 4 LIFE
    17 Sport
    Look at all the holes the factory drills in the frame .
    MtnFisher likes this.
