Updated with install pics - Will drilling into pinch weld void warranty?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by pdxrado, May 31, 2019.
  1. May 31, 2019 at 12:59 PM
    pdxrado
    pdxrado [OP] Well-Known Member
    Portland, OR
    Black 19 DCSB Sport
    LOL. thanks.
    it looks like we can actually drill into the pinch weld and not the frame which makes me feel a little better.
    Slashaar likes this.
  2. May 31, 2019 at 1:03 PM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Not sure where you live, but you'll most likely want to consider some type of rust prevention after drilling. Could be as simple as lots of paint, or better yet a coating of some sort like Fluid Film. :thumbsup:
    Boghog1 likes this.
  3. May 31, 2019 at 1:06 PM
    pdxrado
    Portland, OR
    Black 19 DCSB Sport
    Thanks @SR-71A . Does that still apply if it's the pinch weld i'm drilling into?
    I'm in Oregon. Lots of moisture. If i wanted to paint the hardware that goes with the steps also black - my truck is metallic black - is there a spray paint that would be recommended that woudl last longer?
  4. May 31, 2019 at 3:14 PM
    SR-71A
    Zack
    Southern Maine
    Absolutely if its the pinch weld. Honestly Ive never really had good luck with paint, so I cant speak to that too much. But given that you're in a damp climate and maybe(?) have to contend with road salts, Id say just go straight for Fluid Film. Do whatever you want to the hardware, do all the prep work, install the steps, and then give the whole area a coating w/ FF. I might even spray some up into the new hole before you install the hardware.
    Fyi, it can make a mess and is a bi&ch to get out of clothes (like a really thick oil) so beware when applying.
  5. May 31, 2019 at 3:51 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Just weld outriggers to your frame long enough to position your step where you want it. Then you don't have to drill anything and they will be stout! Make sure you properly plate the area you are welding.
    rtzx9r likes this.
  6. May 31, 2019 at 6:23 PM
    rtzx9r
    rtzx9r Well-Known Member
    Bueller
    2016 TRD Sport
    LS1 swap with nitros.
    Bingo. This is the best answer.
    Slashaar[QUOTED] likes this.
  7. Jun 2, 2019 at 3:18 PM
    pdxrado
    Portland, OR
    Black 19 DCSB Sport
    Update - installed the steps this morning. It was relatively easy because I had it up on a rack. I wouldnt want to do it while laying on the ground.
    I painted all the chrome hardware black so it matches the step (and the truck). A little touch up needed but surprised how much of it stayed during install.
    Happy with result. They don’t hang as low as this picture looks, it was an odd angle. I didn’t lose any ground clearance (at least vertically). My wife and kids love them.
    I just personally like this look so much better than a running board. Subjective , obviously.
  8. Jun 20, 2019 at 7:31 PM
    AWF ROWD
    AWF ROWD ...eats at the " Y " often....
    Doc
    40.102° N, 82.804° W
    '13 BLOWN 4X4 Sport
    TRD Supercharger, Walbro 255 FP Upgrade, aFe Stage 2 si CAI, TRD Acrylic cover by Coupe ADD 1 OIL Catch can/SS hoses, TRD cat back exhaust, URD 2.8" Stealth pulley, 3" lift, Toytec/Bilstein C/O's, Toytec Progressive AAL's, LR UCA's, 5100 Rear Billies, Bi-Xenon HID BHLM Retro's w/ Halos RED LINE Tuning Hood Rods Swaybar Relocate, Line X'd Bull Guard/Step, Hitch, Craven Speed Dual Gauge mount, AEM Boost/AFR Gauges, Windows 20% tint, Weather Tech deflectors, GrillCraft upper and lower, Tacoma Raptor letters, LED Interior/Exterior lighting, Lund 6" Color Matched Oval Side Bars, Webasto 700 II sunroof, Heated Two toned custom leather TRD logo'd, Kenwood Multimedia 6990 HD head unit ,JL Stealthbox sub, Hertz Component speakers,, Entire cab damped with hushmat, Viper Security/Remote start, Weather Tech Liners, Blackened exterior LED Lights, Undercover Top w/LED's, Carbon fiber TRD windshield decal,, TRD stitched leather shift knob, TRD steering wheel emblem,
    Any problems drillin into the rocker panel..??
  9. Jun 20, 2019 at 9:08 PM
    pdxrado
    Portland, OR
    Black 19 DCSB Sport
    Eh, kinda. You just have to have the right kind of drill bit. The pinch weld was harder & the part I wouldn’t want to be laying on the ground for.
  10. Jul 1, 2021 at 12:13 PM
    JJ Diablo
    JJ Diablo Well-known member.
    JJ.
    CT
    2021 Cement TRD Sport Premium
    BOSS HTX Snowplow, Bilstein 5100s, Vled reverse light kit, Vled interior lighting, FitCamX dashcam, Timbren SES
    I know this is 2 years late, I had an entire snow plow installed into my 2nd gen frame which required drilling several large holes.. Toyota replaced the frame during the rust recall, and also said plow install would not void warranty on my new 3rd gen. If I bent a suspension component by smacking into something then no, thats not covered. Same as if a tech at the dealer stripped a lug nut.
    But simply drilling a hole into frame will not void trucks warranty.
  11. Sep 17, 2021 at 4:47 PM
    bass player
    bass player New Member
    2017 SR5
    I also favor hoop step, so I went to a local accessory shop and purchased 2 Carr hoop steps for my 2017 extended cab and when I took it in for install and after waiting for an hour they said they could not install them because there was nowhere to bolt the top of the rear bracket (maybe using the holes from the factory) due to the way the rocker tapers down. Any suggestions? Is this just an issue on extended cabs
