Updating Rims
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Dbmpburg, Mar 10, 2023.
  1. Mar 10, 2023 at 2:41 PM
    Dbmpburg
    Dbmpburg [OP] Member
    Dan
    2021 Tacoma Sr Access cab 4wd
    Lift level 1 rear 3 front
    I have a 21 Tacoma SR access cab 4wd with the stock 16x7 rims. Want to go to a 16x8 rim. Will I have any clearance issues with 0 offset ? Truck has a 1 3 lift level. Thanks
  2. Mar 10, 2023 at 2:46 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Lift doesn't matter if you are going to stuff the wheels. But, 8in, 0mm offset is no big deal if you stick with 265s.
    Dbmpburg[QUOTED][OP] likes this.
  3. Mar 10, 2023 at 2:51 PM
    Dbmpburg
    Dan
    Thanks
    tonered likes this.
  4. Mar 10, 2023 at 2:59 PM
    Ballz
    Ballz Well-Known Member
    Bfe SF Bay
    2023 Ice Cap Taco TRD Pro
    3” up front and 1” in the rear? You could go 285/75-16
  5. Mar 10, 2023 at 3:06 PM
    Dbmpburg
    Dan
    Yes. Going with 265 75 16 just concerned about the rim clearance if go to an 8 inch rim with no offset
  6. Mar 10, 2023 at 3:09 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    I have 17x8.5 -10mm with 32s. No issues at full uptravel.
  7. Mar 10, 2023 at 3:10 PM
    Dbmpburg
    Dan
    Great. Thanks
    tonered likes this.
  8. Mar 10, 2023 at 3:22 PM
    malatx
    malatx Well-Known Member
    2022 TRDOR DCLB Army Green
    depends on what tire size, at 16x8 at 0 offset you can safely run stock or slightly bigger without rubbing scrubbing on anything
  9. Mar 10, 2023 at 3:27 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    You should be just fine. I have a 2 inch lift up front and my wheels are 16x8 with a -10mm offset. Tires are 265/75/16.
    Nowhere close to rubbing. I previously had 285/75/16 mud terrains on the same set up and those didn’t even rub.
    Dbmpburg[OP] likes this.
  10. Mar 10, 2023 at 3:45 PM
    Ballz
    Bfe SF Bay
    You’ll have zero issues. Your stock offset is 25, and you’re going to 0 offset, so you’re bringing your wheel out 25mm. You’ll be fine with 285/70-16
  11. Mar 10, 2023 at 4:10 PM
    Dbmpburg
    Dan
    Great info. Thanks
    Road_Warrior likes this.
  12. Mar 11, 2023 at 4:34 PM
    Domeimazn
    Domeimazn Well-Known Member
    Henro
    2020 tacoma pro
    How did it turn out
  13. Mar 12, 2023 at 9:56 AM
    Dbmpburg
    Dan
    Just ordered the rims. I will upload before and pics when it's finished. Thanks for asking
