Upgrade 2004 Tacoma 2wd, 4dr, TRD Limited front brakes
Discussion in '1st Gen. Tacomas (1995-2004)' started by Bluepepper, Jun 16, 2016.
  1. Jun 16, 2016 at 3:08 PM
    Bluepepper
    Bluepepper [OP] Member
    Leslie
    K&N filter and intake kit
    I am planning to upgrade my stock rotors/pads and considering using a kit from Power Stop rotor kit that include a drilled/slotted rotor and matching pads. The Power Stop website indicates two options available for the Z36 kit (truck & tow) that works with 6-lug wheels: With "VDC" that includes a 318.5 mm rotor or without "VDC" that includes a 296.8 mm rotor. I did not know I had a VDC option for my Tacoma. Support from Power Stop was no help, so can someone shed some light on this here in the forum?
  2. Jun 17, 2016 at 12:24 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    It's actually VSC (Vehicle Stability Control). "most" 1st Gen Tacomas did not have it but some did as an option. The easiest way to tell is bust out the tape measure and check the ones you have on now.
    Another option you may want to consider (depending on how much you tow) is the "Tundra brake upgrade" (do a search in 1st Gen forums) which give you larger rotors, brake pads and caliper all while being bolt-on with minor shield trimming. drilled and slotted do expend heat but are not really that necessary unless you plan to brake a lot, or ride them. A good quality/OEM rotor and pad will be a good option.
    Bluepepper[OP] likes this.
  3. Jun 17, 2016 at 9:14 PM
    Area51Runner
    Area51Runner Well-Known Member
    Northern California, Bay Area
    02 3.4 DC TRD PreRunner 4WD SWAP
