upgrade front brakes on a 2017?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by 99blacktacoma, Dec 3, 2016.
  1. Dec 9, 2016 at 7:03 PM
    #41
    cory02taco
    cory02taco Well-Known Member
    Cory
    Maine
    2013 trd super sport
    He specifically said 2000-2006 Tundras, which were 6 lug. 07-current are 5.
    Blasphemy if you ask me.
  2. Dec 9, 2016 at 8:52 PM
    #42
    avitaco
    avitaco Well-Known Member
    A
    2017 DCSB 4x4
    I want to upgrade the brakes too... I dont feel like they have any bite. I know its a truck but the peddle feels "soft" I plan on towing soon and im worried about fade. Some of us dont want to spend for the sake of spending but these brakes are crap. my 89 sr5 stopped on a dime.
  3. Dec 10, 2016 at 7:42 AM
    #43
    Jeff Lange
    Jeff Lange Well-Known Member
    Calgary, Canada
    '86 AE86, '05 NCP13, '11 GSE21
  4. Dec 10, 2016 at 9:03 AM
    #44
    WarrenG
    WarrenG Well-Known Member
    Posts like yours hurt my brain. The guy had a question, someone offered a real answer, and you shit on it.
  5. Dec 10, 2016 at 10:18 AM
    #45
    Nitori
    Nitori Well-Known Member
    Maricopa AZ
    2021 T4R SR5
    Real answer? what is that supposed to even mean? "Add 5,000 cheeseburgers to the bed" is a real answer, doesn't mean it's a good one. I was thinking OP was looking for better braking distance, in which case SS lines are not the right answer.
    ANYWAYS
    OP, your question was unclear. By "better quality brakes" are you talking about:
    • A) Shorter stopping distances, as in hauling the truck down to 0 in a shorter number of feet
    • B) Better "feel" to the brakes in terms of how much initial bite they have, but not necessarily any drop in stopping distance
    If you answered A, get better tires. Tires are your limiting factor, not the brakes. If you can lock the wheels and start the ABS, your tires are what is keeping your from stopping sooner.
    If you answered B, the better and cheaper answer would be slotted rotors up front. They tend to have that more agressive initial "bite" you are probably looking for. SS lines will also make a difference, but less than you might expect.
    There.
  6. Dec 10, 2016 at 12:34 PM
    #46
    Jeff Lange
    Calgary, Canada
    I feel like there is a C) Better fade resistance, especially when more heavily loaded and/or pulling a trailer in mountainous regions, etc. In such a case, larger brakes would be a good option and/or brake pads with higher fade resistance (being able to function at higher temperatures effectively).
    Most of the time, people think they want A, but actually want B, when C is probably the only real reason to upgrade your brakes.
    That said, some people really want B, and if you have bad tires, you may have a bad A situation, and as was said: get better tires.
    Jeff
    su.b.rat likes this.
  7. Dec 10, 2016 at 12:39 PM
    #47
    su.b.rat
    su.b.rat broken truck
    that's actually my experience in all my [modified] vehicles. i've been motivated by A & B, but C was the only situation where i found any kind of real world benefit.
    for example, coming down Pike's Peak they have a brake temp checkpoint halfway down for safety of all vehicles. usually they pull over about half the vehicles coming down to let them cool 5-15 before continuing. i came down with racing Wilwoods on my '70 A-body, and the rotors were not even properly warmed up. the guy laughed and said to ride my brakes on the way down in case i needed them. o_O
  8. Dec 10, 2016 at 12:41 PM
    #48
    dYL0n
    dYL0n أنا لست الإسلامي
    Dyl0n
    New Orleans, LA
    17TRDORDCSBQSJBLKBRO2SPECU1.04
    1.04. Kbro2s. ICONS.
    My brakes are insanely sensitive and work great.
  9. Dec 12, 2016 at 7:27 PM
    #49
    angry john
    angry john Well-Known Member
    john
    2016 DC OR V-6
    Pads change a lot of charistics and are not expensive to swap.
  10. Dec 12, 2016 at 8:06 PM
    #50
    SnowFarmer
    SnowFarmer I intend to live forever, or die trying.
    Corona, CA
    '17 TRD Pro
    I can afford Gas.
    Old racing adage: You can only go as fast as you can stop.
    No one likes these? http://www.trdusa.com/brakes.html
  11. Dec 13, 2016 at 10:28 AM
    #51
    tacitos
    tacitos Tah-Key-Toes
    16 TRDORDCLBJBL
    Those look like Brembo's and probably are. I would go that route, but I would swap out pads and lines before dropping coin for that setup. My OEM brakes have worked perfectly fine so far.
  12. Dec 13, 2016 at 10:33 AM
    #52
    SnowFarmer
    Corona, CA
    '17 TRD Pro
    I can afford Gas.
    For what it's worth? If EBC makes brake pads for the Tacoma's, you can't go wrong. "Red Stuff" pads work very well.
  13. Dec 13, 2016 at 11:22 AM
    #53
    tacitos
    16 TRDORDCLBJBL
    I don't know much about EBC for auto's, on motorcycle's they are "okay" street pads and lack on the track. I prefer a pad with a low initial bite.
  14. Dec 13, 2016 at 11:54 AM
    #54
    Jeff Lange
    Calgary, Canada
    TRD USA's big brake kits are typically made by Stoptech. Also, the only one I believe they ever specifically offered for the Tacoma was only applicable to 5-lug models (specifically the X-Runner, but it would fit others if you had large enough wheels).
    Jeff
