Upgrade Headlight Bulbs
Discussion in '3rd Gen. Tacomas (2016-2023)' started by n7oTac, Dec 21, 2021.
  1. Dec 21, 2021 at 2:01 PM
    n7oTac
    n7oTac [OP] Member
    Nigel
    2017 Tacoma Off Road
    Looking to upgrade my bulbs from stock to LED bulbs. Been looking at the Tacoma Beast plug and play set for my Highbeams/Lowbeams. Any recommendations?
  2. Dec 21, 2021 at 2:06 PM
    chstaco
    chstaco Well-Known Member
    SC
    2020 Tacoma
  3. Dec 21, 2021 at 2:07 PM
    Matt8vt
    Matt8vt Well-Known Member
    Illinois
    2021 MGM TACOMA SR5 SB 4X4
    Method 305 16x8 in black with duratracs 265/75/16 Running boards SS3 fog lights Truxedo tonneau Carhartt seat covers
  4. Dec 21, 2021 at 2:21 PM
    burgershot
    burgershot Well-Known Member
    Tacomabeast is trash
    JDKred likes this.
  5. Dec 21, 2021 at 2:23 PM
    nattykanari
    nattykanari Well-Known Member
    Natty
    Murrieta, CA
    2016 Tacoma TRD 4x4 Off-Road
    Armor: C4 Fab Overland Front Bumper C4 Overland Rear Bumper with Swingout and Dual Jerry Can Holder Demello Hybrid Bolt-on Rock Sliders Suspension: King 2.5 Extended Travel Front and Rear Shocks with 650 lb Coils Icon RXT Leaf Pack Stage 3 Archive Garage U-Bolt Flip Kit with Option 3 Archive Yellow Speed Stops DuroBump Front Bump Stops Engine: Injen Cold Air Intake SibiBuilt Custom 87 OVTune Odyssey 31 Battery Rago Fabrications Battery Box Wheels & Tires: SCS Ray 10 17x9 -38 Offset 295/70/17 Yokohama Geolander MTs Lighting: Baja Designs 30” S8 Amber Light Bar Baja Designs Squadron Pro Amber Fog Lights Baja Designs Squadron Sport Amber Ditch Lights and Chase Lights Tacoma Beast Spyder Headlights with Morimoto LED Bulbs Tacoma Lifestyle Sequential Turn Lights Runnin4Tacos Amber Raptor Lights LED Interior Lights Upgrade Misc: Total Chaos Bed Stiffeners Expedition Essentials 3TPAM Mount CaliRaised Mid-Console MOLLE Panels CaliRaised Ditch Light Brackets WaterPORT Day Tank with Bedrail Mount RCI Bed Rail Hi-Lift Mount Dynamat Interior and Engine Bay Sound Deadening
    I like the auxbeam LED bulbs I had. Fit like OEM and output was way better than stock halogen. Got them off Amazon. Morimoto sells great bulbs too
  6. Dec 21, 2021 at 2:26 PM
    drizzoh
    drizzoh itsjdmy0
    Andrew
    Arizona
    2021 Tacoma TRD Off-Road 4x4
    IMO don't waste your time with leds in these housings. I was less than thrilled with my Morimoto 2 Stroke 3.0's. I hear the Hikari's outperform these on this platform but I don't have first hand experience with them. The Mori's have been great in every other vehicle I've used them in, just not in these housings. Run HID or retrofit to RX350 projectors.. and then run HID in those.
    FWIW, a properly designed led is designed to be used as a halogen replacement, but a simple led swap is still nowhere as powerful as an hid in the same housing. Toyota projectors generally do pretty well with an HID with minimal glare to oncoming traffic, so long as they're aimed properly.
    All that being said, I got fed up with the stock lighting pretty quickly and swapped housings to the Morimoto XB-led gen2's. They're amazing for a pnp setup - even better than the stock led option.
  7. Dec 21, 2021 at 2:30 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    Stay with the stock type bulbs. There are multiple options for "brighter" bulbs with the same wattage or slightly higher.
    Plunking LED into the existing lenses will not work very well. The bulb needs to be at the correct location inside the reflector, specifically the focal length of the reflector. The LED bulbs won't land at the focal length. Meaning, the light beam will be poorly formed and won't illuminate the field in front of the truck.
    FWIW, I changed to a Sylvania SilverStar bulb at 55W. It isn't the best bulb on the market, but it was a significant improvement. My low beams will reflect off signs 1/4 mile distant. My vision field has been extended.
    shakerhood and Grossomotto like this.
  8. Dec 21, 2021 at 5:56 PM
    eurowner
    eurowner Duke Sky
    Scoty
