Upgrade JBL question
Discussion in 'Audio & Video' started by Pilvr83, Sep 29, 2019.
  1. Sep 29, 2019 at 10:15 AM
    Pilvr83
    Pilvr83 [OP] Well-Known Member
    Panhandle, Florida
    2020 Tacoma Limited
    Spiker struts, tailgate step, MESO...$$
    I am looking at purchasing the Alpine 9 radio but would like to use my current XM tuner. Is there a way to use the current XM tuner with an aftermarket radio? I would like to use the same sharkfin antenna.
    Last question, Crutchfield told me I have to upgrade all the speakers if I upgrade the radio due to the subwoofer. Is there a work around for this?
    Upgrading is getting pretty expensive just to add the much wanted Car Play!!
  2. Sep 29, 2019 at 10:47 AM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    You cannot use the factory tuner but you can use the factory antenna. You will need an antenna adapter and the svx300 tuner.
    you absolutely do not have to upgrade the speakers in order to swap the radio.
    Get the Maestro RR module and wiring harness and it will integrate the factory amp.
  3. Sep 30, 2019 at 7:32 AM
    Pilvr83
    Panhandle, Florida
    2020 Tacoma Limited
    Alright! That is what I was hoping I could do.
