Upgrade Shocks Suggestion
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ToyodaTruck, Jun 1, 2021.
  1. Jun 1, 2021 at 2:14 PM
    ToyodaTruck
    ToyodaTruck [OP] Well-Known Member
    2019 TRD Sport
    I'm looking into upgrading my stock shocks. I got a TRD Sport 2WD. I don't off road. The most I ever get my self into is driving on the beach sand, climbing over curbs, and occasionally going down bumpy dirt roads. There is a lot of pot holes in the city streets in Houston, TX that I'm usually hitting. I'm not rock climbing at all. I'm looking for something that will absorb the "bouncing around" a lot more better then the stock TRD Sport shocks. What do yall suggest?
  2. Jun 1, 2021 at 2:15 PM
    JWestie
    JWestie Well-Known Member
    2019 Tacoma DCLB-OR Mag gray
    Bilstein 4600.
    MannyS likes this.
  3. Jun 1, 2021 at 2:16 PM
    ToyodaTruck
    2019 TRD Sport
    Do you have them on your truck? If so, do you get the "bouncing around" a lot?
  4. Jun 1, 2021 at 2:22 PM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    FOX 2.0 if you want it really plush and don’t mind spending a bit more money.
  5. Jun 1, 2021 at 2:24 PM
    ToyodaTruck
    2019 TRD Sport
    Is Fox 2.0 overkill for me or not? Also, is the TRD PRO shocks Fox 2.0?
  6. Jun 1, 2021 at 2:28 PM
    Sharpish
    Brian
    You’ll enjoy a plush comfy ride for many years. Overkill would be Kings or FOX 2.5 with adjusters and reservoirs. Not sure what the new PRO come with. Bilstein 4600 are basically what the stock off road come with maybe you could buy new take offs from someone who upgraded their off road off the lot. That would be a cheap option but the improvement wouldn’t be as drastic as some nice FOX 2.0.
  7. Jun 1, 2021 at 2:29 PM
    FuzzysTacos
    FuzzysTacos Well-Known Member
    Corey
    Wichita, KS
    Sold: 2017 TRD OR/2012 TRD Sport
    I had foxes, didn't think they were that plush. I wouldn't spend the money on big name suspension again unless I moved to the desert, personally.
  8. Jun 1, 2021 at 2:33 PM
    ToyodaTruck
    2019 TRD Sport
    Man, this is a tough decision.
    98_3RZ_NIC likes this.
  9. Jun 1, 2021 at 2:35 PM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    I wanted a better ride on my offroad. I dont go offroading, but do go in snow (like your sand, but slicker) I went with trd pro suspension and its miles better than the stock. The truck feels so much more controlled with something better than the marshmallow sticks it comes with stock.
  10. Jun 1, 2021 at 2:36 PM
    AZ_J
    AZ_J Well-Known Member
    Ahwatukee, AZ
    2019 TRD OR 4x4 DCSB
    265/75r16, sliders, softopper, roof rack, 6112/5160's
    My vote is for OR or PRO Take-offs
    Clearwater Bill likes this.
  11. Jun 1, 2021 at 2:43 PM
    Sharpish
    Brian
    Tires play a big role too. Even the really good suspension doesn’t feel great with heavy, stiff ass E-Loads. Ask me how I know haha
    bulalo and 71tattooguy like this.
  12. Jun 1, 2021 at 2:46 PM
    FuzzysTacos
    Corey
    Wichita, KS
    Agreed. Was just disappointented with as much hype as there is/money was spent. My big takeaway is stay within your lane/intentions for truck use. Also wouldn't recommend ARB leaf springs lol.
    Edit: foxes I'm referencing are not the factory take offs. (Saw someone mention those) Solid performance option if you can find them for around 1200.
  13. Jun 1, 2021 at 2:50 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    Can you describe what you mean by "bouncing around?" Wallowing through all the travel and not settling quickly could be considered bouncing around to some and might indicate worn out shocks. Riding rough over potholes and not soaking up the bumps, skittering around on rough terrain could be considered bouncing around to others. Both have different solutions.
    I don't have experience with a Sport, but from what I read here on TW, they are a bit stiffer than the Off Road. The 2nd gen Off Roads had softer front springs that were progressive, giving it a better ride under off road conditions but ramping up so as to not bottom out. Not sure if that carried forward to 3rd gens. If so, you might want to find some Off Road take-offs and snag the springs.
    There are 3 main things that affect your suspension: weight (both sprung and unsprung), spring rate, and damping. Your weight only varies with the load you are carrying. Spring rate is also more of a constant, but springs can be progressive (rate goes up slightly as the spring is compressed). Damping (what the shocks do) provides resistance that affects how quickly your suspension can move through the travel, both compression and rebound. Shocks can have different damping rates for both, have bypass zones where this damping changes based on shaft position, and/or valving that increases/decreases damping based on shaft speed. No damper performs well under all conditions. That's why you see high-end shocks with adjustable high-speed and low-speed compression damping, as well as adjustable rebound damping. Example: If you carry more weight, you need a higher spring rate to hold the vehicle up, so you may need to increase the rebound damping (the spring is pushing the wheel back down with greater force, so you might want to dampen it more).
    Not sure why I am telling you all this other than it can be complicated, and there are compromises. If your springs are too stiff for how you want it to ride, changing the shocks alone may do nothing for you. Adding some weight in the bed may improve the ride of the rear with no change to anything else. I like how my truck handles best with some weight in the back. Understanding what it is doing that you don't like and what needs to change to improve it is the first thing, but it isn't easy to find that perfect sweet spot unless you are an expert suspension tuner.
    rizrox likes this.
  14. Jun 1, 2021 at 3:14 PM
    ToyodaTruck
    2019 TRD Sport
    Thank you for explaining all that to me. It makes more sense now. The Sport is more stiffer then the Off Road to my knowledge. I brought the truck used and I am the second owner of the truck. When I brought the truck it had 9k miles on it with original shocks setup. I am now sitting at 26k on my truck. The main goal for me is to have less of the stiffness which causes the truck to have a hard bounce when hitting speed bumps, pot holes, curbs, etc. My tires on the truck is Nitro Grappler which I brought brand new and now have about 15k miles on them. But the stiffness have always been there on the truck since I brought it. I don't have any armor on my truck that put on a lot of weights. I do typically errands with my truck like haul bags of mulches for the house, grocery shopping, etc. I am not an off roader
  15. Jun 1, 2021 at 3:19 PM
    Sierra Trail Pro
    Sierra Trail Pro The more I play with it, the Bigger it gets!
    Kelly
    Cameron Park, CA
    2020 TRD Pro, Magnetic Grey Metallic
    Upgraded REM Polished 5.29 Revolution Gears Dobinsons 2.5 MRA/MMR adjustable remote reservoir front coilovers w/732lb springs, 35x12.5 BFG KM3 MTA tires on Moto Metal 16" wheels, incl. full size spare Bushmaster bolt on wheel well flares CaliLED full cab length DOM Steel Rock Sliders w/kickouts, Total Chaos welded spindle gussets, & LCA Cam Tab Gussets, Welded "Runnin 4 Tacos" Cab Mount Relocation Bracket, C4 Fabrication front steel hybrid bumper incl. heavy duty steel bumper support add-on's, C4 Fab Rear overland high rise steel bumper w/steel rear qtr panel wrap armor and side tube upgrades, 12k Smittybilt XRC Pro Comp Winch w/Factor 55 Flatlink Expert shackle mount assembly, Dobinsons heavy duty rear leaf spring pack, Timbren Off Road Racing bump stops (F&R), Fox 2.5 TRD Pro OEM rear monotube shocks, OEM Factory TRD Pro front aluminum skid RCI Steel skid plates (tucked in to factory engine skid)@ transmission, transfer case, lower A arms, and rear diff; CBI steel gas tank skid, ARB Twin Compressor in an M.O.R.E. engine bay mount, ARB Front Air Locker w/ Stainless Steel Air Lines Diode Dynamics 30" LED light bar @front bumper, RIGID front fog lights tied into factory wiring harness, Odyssey Group 31 AGM battery in a CBI Steel battery tray, Decked Slide-Out lockable Bed Drawer System, Yaesu FTM-400XDR HAM Radio (c/s:K6TOY), FreeSpirit Recreation "Evolution" Aluminum Hard Shell RTT w/Accessory Rails X2, FreeSpirit Recreation 270 Degree Swing-Out Self Supporting Awning w/Tent Mount Brackets, Cab Rack Mounted shower/changing tent, CBI corner to corner Steel Full Bed Rack, Prinsu Cab Rack w/extra rails, UpTop Overland upTAKE Snorkel (Functional & self draining), iPOD Bantam X touch screen switch panel control module, Dometic CFX3 95DZ Dual Zone Electric Refrigerator/Freezer w/dedicated electrical circuit & outlet, Dometic Refrigerator Slider Bed Mount, (4) 4 Gal Roto Pax Gas Cans w/locking Bed Rack Mount, MaxTrax Extreme Recovery Boards w/locking bed rack mount, Valley Runner custom ECU tune, TRD Advanced Cold Air Intake, Escort Radar Detector, hard wired w/RVM mount ALL K&N cleanable filter media installed, Only use Mobile One Full Synthetic Oil, changed every 5K miles, All Major Mods Professionally Installed
    TRD Pro runs Fox 2.5 Coil overs font and Fox 2.5 remote reservoir rears , custom tuned for Toyota TRD
    And, yes they are probably way over kill for a 2wd...
  16. Jun 1, 2021 at 3:22 PM
    Sierra Trail Pro
    Kelly
    Cameron Park, CA
  17. Jun 1, 2021 at 3:34 PM
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    KYB 'plus' series. Mono tube, stock upgrade. Good bang for the buck. I like 'em.
    zoo truck likes this.
  18. Jun 1, 2021 at 3:42 PM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    I have fox 2.0 and no complaints about the quality. I payed around $1700 for parts and labor and I think it was a well worth it (~$1300 parts, ~$400 labor)
  19. Jun 1, 2021 at 3:58 PM
    ToyodaTruck
    2019 TRD Sport
    Where did you buy the Fox 2.0 shocks from?
  20. Jun 1, 2021 at 4:02 PM
    brandon78lusch
    Brandon
    RimzOne in Mooresville, North Carolina. They ordered them for me so I have no idea. I got lucky and they were able to find a set that was still in stock because everything else was backordered back in march 2021.
