Upgrade sound system keeping stock head unit
Discussion in '3rd Gen. Tacomas (2016-2023)' started by javis11x, Dec 22, 2021.
  1. Dec 25, 2021 at 7:34 PM
    Rogue Ranger
    Rogue Ranger Member
    is the head unit in the 2022 with Android auto etc any better?
  2. Dec 25, 2021 at 8:02 PM
    lacab100
    lacab100 Well-Known Member
    Caleb
    '20 TRD OR M/T, Maggy S/C
    I have a 2020 non jbl with android auto.
    The big issue is bass rolloff at not even that high volumes. Secondly, the stock H/U is EQ'd to protect the factory(cheap) speakers. the rear channel has basically no power, again to protect the factory(really cheap) rear speakers. There are aftermarket options to correct all of these issues without changing the headunit, but you will end up spending more money in the long run than if you just change to a quality aftermarket H/U (and it will sound worse)
    That also provides side benefits of a much better responsiveness, better screen, better android auto/carplay integration, more options, etc.
    With modern canbuss integration you should be able to retain all functions.
    On top of all that you can flip a good working factory H/U on ebay and recoup alot of the cost
    If you want to just upgrade the speakers with the kicker drop inns, dynamat the doors and send it you will probably be happy with that. If you aren't happy with just that then a new H/U should be your next step
    In my opinion...
    ac2ndGenTacoma likes this.
  3. Dec 25, 2021 at 8:21 PM
    wood714
    wood714 Got any Quaaludes?
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    With a new HU do you still have the back up camera, play tunes off a flash drive, and your phone still work with the controls on the steering wheel?
    I have the non JBL in my 2018 access cab, and it's absolutely not close sounding good.
    I'd want new speakers to be plug and play too. Figure Crutchfield would be the best bet for them. Is there an under seat sub for these trucks?
  4. Dec 25, 2021 at 8:33 PM
    tacovagon
    tacovagon Well-Known Member
    Dan
    Oceanside CA
    2016 SW SR5 DCLB 4x4
    ARB Locker 5100s w OME 887s OME EL095R Camburg BJ UCAs
    Yes, if you get an HU with Maestro integration and a USB connection.
    wood714[QUOTED] likes this.
  5. Dec 26, 2021 at 4:53 AM
    javis11x
    javis11x [OP] Member
    Javier
    2013 Toyota Tacoma single cab 4x4
    A friend of mine has done his whole system, and kept the Oem h/u and it sounds amazing! I’ve heard a lot of sound systems but his sounds really good, only thing is that his Tacoma is non JBL system
  6. Dec 26, 2021 at 7:00 AM
    Mike402
    Mike402 Well-Known Member
    Palm Springs, CA
    2020 Custom TRD Off Road
    So can we assume you did the research and this particular model was the best option in terms of fit, retaining oem functionality, etc or was it more that you got a good deal on it?
  7. Dec 26, 2021 at 4:28 PM
    dolbytone
    dolbytone Well-Known Member
    South Carolina
    09 TRD Off Road
    This is kind of the key. If you didn’t have the JBL I would have recommended getting a FiX and some nice amps/speakers a long time ago. Problem is you have a JBL and you can still do this, but it’s more involved.
    I’ve never taken measurements on a JBL either so it’s hard to say what exactly it needs.
  8. Dec 26, 2021 at 6:03 PM
    Great Dane
    Great Dane Well-Known Member
    Dane
    Georgetown, Ky
    2021 TRD Sport 4x4 Access Cab.
    Replacement.
    It needs replacement.
  9. Dec 26, 2021 at 7:20 PM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I did the tweeter upgrade , and added a underseat 8" powered Sub, spliced from the rear speakers. That's it, sounds great.
    VaToy and H7D F5T like this.
  10. Dec 27, 2021 at 7:40 AM
    Bmw2Taco
    Bmw2Taco Well-Known Member
    2018 Blue 4x4 TRD Sport Premium
    I did the PacAMP Pro TY12, replaced the factory door and dash speakers with Kicker Components for front and Kicker Coax for rear. Using Alpine 4 ch amp mounted in cubby behind driver rear seat. Using factory amp to drive factory sub. I spliced into factory speaker wires at passenger side rear corner. Everything from Crutchfield
  11. Dec 27, 2021 at 9:58 AM
    kshoots
    kshoots Active Member
    HI
    2017 Quicksand TRD Sport 4x4 DCSB
    @Mike402 I did over a year of testing fitment and functionality. This unit was closest fit to stock opening. There was no modifications done to the trim piece that fits around headunit. The only modification to help fitment was to remove a plastic wire raceway to ensure the usb c connection was not torqued. Retaining stock functionality like steering controls came from the Maestro RR unit that keeps that functionality and also plugs into OBD port for running gauges and tire pressures.
    This unit is considered a "floating display" it has a bracket with many mounting options. Took about 3 hrs to line it up properly with the opening, i do have picture somewhere of the holes i used to assemble the bracket for the correct fitment.
  12. Dec 27, 2021 at 10:00 AM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
    Contact Crutchfield
    I bet you will be disappointed with the factory head.
    It is the worst head I’ve ever had, and fortunately I’ve had a lot.
  13. Dec 27, 2021 at 11:47 AM
    Mike402
    Palm Springs, CA
    Thanks for the detailed response! I've been thinking about getting a new head unit, but I have the anytime backup camera as well, and everything is working perfectly. Part of me is loathe to bring something new in and try to get everything working correctly. I guess the optimal way is to also run new and thicker speaker wire.
  14. Dec 27, 2021 at 11:54 AM
    kshoots
    HI
    @Mike402 This pioneer unit has the ability to have (2) camera inputs. Also has the option to use either camera at anytime. I'll use this if load in bed covers rear view mirror.
    Agreed new speaker wire is the way to go, i have yet to reinstall the 4channel amp but when i do ill run new thicker wire to doors.
  15. Dec 28, 2021 at 8:18 AM
    #35
    ULURU
    ULURU Well-Known Member
    2018 Inferno TRD OR DCSB
    I think the factory Delco AM/FM Cassette, complete with mechanical presets, in my first car (a '78 Buick) driving a pair of Bose 6 x 9's sounded way better than the factory unit in my Taco...
    My '18 does not have the JBL System.
    Does anyone have experience with the stuff sold from taco tunes dot com? They appear to have a turn-key solution for non-JBL Tacos, keeping the factory head unit, and just upgrading most everything else, and adding stuff, too.
  16. Dec 28, 2021 at 3:17 PM
    #36
    hr206
    hr206 Well-Known Member
    Western Washington
    '16 DCSB TRD OR, '98 regular cab 4x4
    I used a JL Audio Fix86 to get line level outputs to all my aftermarket gear. I did this back in 2017 when there weren't as many options and have been happy ever since. (I have the factory JBL head)
    dolbytone likes this.
  17. Dec 28, 2021 at 3:29 PM
    #37
    Iceman1N
    Iceman1N Active Member
    2022 Metallic Grey Toyota Tacoma TRD Off-Road
    I'd check out the guys at OEM audio plus. They make replacement speakers and subwoofer that still uses the factory head unit. Everything is Tacoma specific so it fits perfectly and they engineered the sound for the Tacoma specifically, everything is plug and play... one warning is that it is pricey, however customer service is top tier and they can answer any question you may have. Improves the sound greatly and looks completely factory you'd never know it was replaced to the naked eye!
  18. Jan 19, 2022 at 9:02 AM
    #38
    H7D F5T
    H7D F5T Active Member
    Which sub did you get?
  19. Jan 21, 2022 at 9:47 AM
    #39
    TurboSF
    TurboSF Active Member
    2021 Cement Tacoma Off Road
    I recently swapped out all of my speakers, added a sub and two amps, one for speakers and one for sub. I am finding the sound to be underwhelming in relation to the quality of the components so I am thinking of swapping my HU now. Question I have is what happens to all of the vehicle controls / settings that are accessed through the stock HU? Do you lose all of that functionality?
  20. Jan 21, 2022 at 9:54 AM
    #40
    tacovagon
    Dan
    Oceanside CA
    No, you can use a Maestro interface to retain all/most of the functions.
