Upgrade suspension ??
Discussion in 'General Tacoma Talk' started by Littleriver, Jan 18, 2025.
  1. Jan 18, 2025 at 8:52 PM
    Littleriver
    Littleriver [OP] Member
    yves
    I just bought a toppers Leer 180 and I plan to build a minimalist camper. With all my gear, camper set up, 300 lbs of passenger, I end up ant around 1100lbs of load total. Do I need to upgrade suspension and if I have to what is the cheapest and easiest option for me? Thanks
  2. Jan 22, 2025 at 9:46 PM
    I-Give-Up
    I-Give-Up Well-Known Member
    West Phoenix, AZ
    2023 Ice Cap Tacoma TRD
    Meso spare fuse holder. Aluminum gas cap holder. Genuine Toyota bed lights. Bed molle racks. Ammo case storage under hood. In-bed spare tire. Automatic underhood lights. Gooey glurp on frame.
    Following this out of curiosity to see where it goes. I've become tired of my 2023 reacting badly to crosswinds. So a Hellwig rear sway bar will get ordered when I return home from my current work trip.
    I like the stabilizing action of rear sway bars so much that I'd be tempted to put one on a Radio Flyer wagon. :D
    Steves104x4 likes this.
  3. Jan 22, 2025 at 9:49 PM
    Bishop84
    Bishop84 Well-Known Member
    I wouldnt run a camper top without sway bars, heavier springs or airbags are a must as well, the factory springs invert with campers long term.
    Personally a big thing is removing the camper when not needed, I grew up with one and we never left it on.
    Flori-duh Taco and I-Give-Up like this.
  4. Jan 23, 2025 at 4:43 AM
    Littleriver
    yves
  5. Jan 23, 2025 at 4:48 AM
    Littleriver
    yves
    Thank you, was it a self-propelled camper that you were removing or just a regular fibreglass topper
  6. Jan 23, 2025 at 4:55 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    I’m on the stock recall springs. I stopped giving a shit 12 years ago. Id worry more about the driveshaft ujoints. Send it and good luck!IMG_4069.jpg
    Flori-duh Taco likes this.
  7. Jan 23, 2025 at 5:10 AM
    Hunter gatherer
    Hunter gatherer Well-Known Member
    Andy
    Lillooet B.C.
    13DC4X4BaseModel
    Cheapest ,easiest way would be airbags. Ride quality might suffer a bit but stability with a load would be much improved. Nice thing about Themis when you are loade you can use a bicycle pump to air them up.
