Upgrade to 265/70/16?
Discussion in 'Wheels & Tires' started by ChunkyLover53, Oct 24, 2013.
  1. Oct 24, 2013 at 6:24 PM
    ChunkyLover53
    ChunkyLover53 [OP] Well-Known Member
    California
    2013 Regular Cab 4x4
    I have a stock 2013 regular cab 4x4 manual transmission with the dunlop 245/75/16 at20s on. I started to do a couple trails and am having a blast.
    I want to upgrade to a 265 tire for extra traction, but I have heard many mixed reviews on 265/75/16. Too much of rubbing / non rubbing talk. So the 265/70/16 would basically keep the same diameter while increasing the tread width.
    Is it worth it to put on 265/70/16s to get the extra width without the height that the 75s add? I just don't want to run into rubbing problems when the suspension is compressing and I'm turning type stuff.
  2. Oct 25, 2013 at 10:13 AM
    ChunkyLover53
    California
  3. Oct 25, 2013 at 10:14 AM
    JEA86
    JEA86 Well-Known Member
    Jeremy
    WV
    2016 TRD Off-Road
    i got 265-75-16 on my truck no rubbing at all, if you have factory wheels you will be fine, its aftermarket wheels that will allow some rubbing issues.
  4. Oct 26, 2013 at 9:29 AM
    wingspar
    wingspar Well-Known Member
    Oregon
    2011 Tacoma 4x4 Access Cab
    I was about to ask this exact same question, so no reason for me to start another thread, so I’ll just jump in here. I’m all stock. No lift. Am about to replace the stock tires that came on my 2011 Tacoma and am thinking about the 265/70/16.
    Is there any advantage to the extra width of the 265/70/16 over the 245/75/16's besides the cool look?
    These will most likely be the Cooper Discoverer AT3's
  5. Oct 26, 2013 at 9:35 AM
    rev25sharp
    rev25sharp Well-Known Member
    Al
    jacksonville fl
    Silver 17dcsb trd sport
    i went from a dunlop at20 245/75/16 to 265/70/16 Michelin i think it drives better. i lost about 1mpg, but happy i did it
  6. Oct 27, 2013 at 2:29 PM
    wingspar
    Oregon
    Minus 1 mpg just for going to a tire 1 1/8 inch wider?
  7. Oct 28, 2013 at 3:40 AM
    rev25sharp
    Al
    jacksonville fl
    i don't think its the size but the added weight
  8. Oct 28, 2013 at 8:20 AM
    ChunkyLover53
    California
    Well I wasn't as concerned with how they will look or the mpg loss. It's my understanding that when you put more tire surface to the pavement / dirt / whatever that you're increasing the resistance and mpg loss is to be expected.
    I was just starting out doing some trails and wanted some all terrain tires. I was just wondering about the 70s vs the 75s. What benefits would be lost by going with the 70s?
  9. Oct 28, 2013 at 8:25 AM
    Pugga
    Massachusetts
    '19 Ford F-250 6.7 SCrew
    F-250 Land Yacht Mod
    The real benefit would be losing the Dunlops and going with a better tire. 245 vs. 265 in the same overall height would not make much of a difference since you typically air down for trail driving anyways.
  10. Oct 28, 2013 at 8:40 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    Given the same exact tire you probably wouldn't notice any difference in feel but they definitely do LOOK better. When I bought mine it was side-by-side with an identical truck with 245's and it just looks better. If you're going to be buying new tires I don't see any reason to stick with the 245's, but I wouldn't replace them just because of the size.
  11. Oct 28, 2013 at 9:13 AM
    ChunkyLover53
    California
    I see. I have a second set of wheels that I want the all terrain tires on. I don't mind the 245 dunlops for highway driving. I will run them until they wear out.
    I just tried a couple trails and thought it would be nice to get a tire more suited for that in a LT version. I thought they would stand up to the abuse better.
  12. Oct 29, 2013 at 9:27 PM
    wingspar
    Oregon
    That seems to make sense, but I’m sure air pressure in the tires would make a difference too. I’d like to go with 265/70/16's vs 245/75/16's mostly for looks. I have to wonder how much of an improvement one might see in handling on the highway and traction off road or highway road noise.
  13. Oct 29, 2013 at 9:30 PM
    12TRDTacoma
    Rob
    Concordia
    Boosted
    265/75/16 with aftermarket rims here Level 8 Guardian rims on BFG A/T KO's. Some rubbing here. Very minor but it's there.
  14. Oct 29, 2013 at 11:02 PM
    ChunkyLover53
    California
    Ya, you could probably get varied results with different air pressures. I agree that I think 265/70/16 would accomplish my goal of getting more traction and be just fine for off road driving / trails. I was just wondering if a 75 series tire would be just for looks or if there is some benefit to having the taller sidewall.
    Cool deal, I have a set of stock wheels that I'll be using. I know there is probably very little reason for me not to get the 265/75/16, plus it sure does look a whole lot cooler. But I'd like to stay away from choosing based on looks for this particular purchase. I'm totally willing to remove the front mud flaps, but I don't know about cutting stuff in the wheel well. I know I'd be fine if all I did was drive in a straight line on the highway, but I'm buying these tires specifically for off road purposes. The suspension will be compressing and I will be turning.
  15. Oct 29, 2013 at 11:07 PM
    bzzr2
    bzzr2 Well-Known Member
    if you want a new tire that will be better off road and still drive ok and get good gas mileage i suggest looking to the 235/85/16 size. i ran these on my reg cab with no lift and no concern for rubbing. same width as the crappy stock tires but an inch taller.
  16. Oct 29, 2013 at 11:31 PM
    ChunkyLover53
    California
    I'm not looking for better gas mileage. I am looking to increase tread width for more traction and mostly off road use.
    I'm just going to suck it up and try the 265/75/16. If I decide they're not what I'm looking for I suppose I can always sell them and get the 70s. I'd rather try the 75s and know for sure rather than getting the 70s and wondering what could have been.
  17. Oct 30, 2013 at 12:55 AM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    I just saw where you're going to mount these on a second set of rims and use them purely for off roading, keeping your factory tires for street & highway use.
    If you're doing that - definitely get the larger size; no need to compromise and accept the factory diameter for a pure offroad use tire.
  18. Oct 30, 2013 at 5:18 PM
    bzzr2
    i didn't realize you were looking for a set just for wheeling. go for the 265's for sure then. you should check out intero's site, they have recently posted 265/75/16's in the iroc nd!
  19. Oct 30, 2013 at 5:22 PM
    bzzr2
    also important when looking to your wheeling tire choice that not all 265's are actually the same size, they vary by half an inch or so in height and also in tread width. a good example of this is another interco tire, the ssr in the 265/70/16, well worth a look..
  20. Oct 31, 2013 at 2:18 PM
    ChunkyLover53
    California
    Well thanks for the input guys. It's a done deal.
    I pulled the trigger on some Michelin LTX A/T 2 - 265/75/16
    I was stuck between the duratracs and the a/t 2s for a long time. I'm sure the duratracs look cooler and have a more aggressive tread, but I called tire rack and liked the deal on the Michelins they gave me. So it's done now and they're on the way.
    Thanks again.
