Upgrade to a Derale Transmission Cooler!
Discussion in '2nd Gen. Tacomas (2005-2015)' started by override, Mar 16, 2020.
  1. Mar 23, 2020 at 9:40 AM
    #41
    caribe makaira
    Caribbean, Puerto Rico
    2016+ have power steering cooler.
    nudavinci64 likes this.
  2. Mar 23, 2020 at 9:47 AM
    #42
    caribe makaira
    Flip the hoses on this side. Make it function like it's suppose to. As heat enters the cooler..not as it exits...
  3. Mar 24, 2020 at 6:22 AM
    #43
    ARB1977
    ARB1977 It’s a beaut Clark
    North Texas
    15 DCSB Prerunner 4.0L Blue Ribbon Metallic
    Black TRD Fj Cruiser wheels, TRD catback exhaust.
    PML is the only one I know of.
    Flake Boost[QUOTED] likes this.
  4. Mar 26, 2020 at 12:30 PM
    #44
    override
    override [OP] Well-Known Member
    Robert
    2015 DC Tacoma Sport 4x4
    I thought about bypassing the radiator but as of right now I didn't think it was necessary step, I bypassed the radiator and added an aftermarket cooler on my old Tundra but those trucks were known for the strawberry milkshake. In regards to cooler size, this is a pretty beefy cooler, it may not be the biggest I could run but it was a fairly simple install, I didn't have to make any modifications besides mounting holes to the truck and I like to keep things clean and simple. I also think this cooler is plenty enough for what I use my truck for, if I was hauling a camper then the bigger one would probably be justified.
    What are your thoughts on the matter?
    I intend to change it when I redo the thermostat, I will need to order another length of hose as well and as little as I drive this truck it's something that can wait.
  5. Mar 26, 2020 at 12:58 PM
    #45
    caribe makaira
    Why? Heat should enter the top, cooled oil leaves through the bottom. The Cooler does not have a check valve.
    Just flip the hose ends at the metal tubing side...
  6. Mar 26, 2020 at 2:21 PM
    #46
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    I would say fill from the bottom so you dont get air pockets.
  7. Mar 26, 2020 at 2:22 PM
    #47
    caribe makaira
    The transmission has a vent...
  8. Mar 26, 2020 at 3:20 PM
    #48
    nd4spdbh
    SoCal
    but the fluid lines do not... air pocket as in a high spot / area where fluid will never reach within the cooler.
  9. Mar 28, 2020 at 12:24 PM
    #49
    override
    Robert
    Correct, the cooler can be mounted in any which manner and either ports can be used as inlet or outlet but as @nd4spdbh mentions you generally want to have your fluid entering from the bottom and exiting the top to prevent air pockets from forming therefore reducing your coolers efficiency. I may not need to order more hose but I would have to look at it, either way I am only home a week a month so it will have to wait until I am home again. I have had that truck since 12/16 and only put 20k miles on it. It literally just sits in the driveway and looks pretty 9 months out of the year.
  10. Mar 28, 2020 at 1:00 PM
    #50
    caribe makaira
    It's not coolant...
  11. Apr 4, 2020 at 2:23 PM
    #51
    override
    Robert
    @caribe makaira What are you talking about? Nowhere on this page did anyone say coolant.
  12. Apr 4, 2020 at 2:28 PM
    #52
    caribe makaira
    You do you're thing. It's nothing.
