Upgrade to homelink mirror
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Linkbelt, Mar 31, 2020.
  1. Mar 31, 2020 at 8:39 AM
    Linkbelt
    Linkbelt [OP] Active Member
    Robert
    2020 white double cab sport
    Changed out stock dimming mirror to homelink mirror over weekend.easy change,just check plug on stock mirror to see how many pins it has.than find gentex homelink with same plug on eBay,junkyard ext.homelink mirror needs two hot wires plus one ground wire.on my 2020sport I had only had one hot wire when you turned ignition on.so to get the other constand hot I spliced into dome lite.easy project
  2. Mar 31, 2020 at 9:52 AM
    FLA_Hoosier
    FLA_Hoosier Well-Known Member
    Rick
    Space Coast
    2017 White TRD Sport AC
    I installed one when I owned my Tundra (2008). Then realized it is hot all the time so if somebody broke into my truck, they could open the garage. Never programmed it after that.
    And before anyone asks, no, I don't leave an opener in the truck for the same reason.
  3. Mar 31, 2020 at 10:05 AM
    MannyS
    MannyS Well-Known Member
    Republic of Texas
    FYI. Bob the mirror guy has a plug and play wiring adapter that resolves the power issue when installing a homelink mirror on a 20 Sport.
    20 Sport w/o factory installed homelink requires splicing power or using Bob’s adapter cable in order to get the owner added homelink going. Bob found out that 20 Sport models built after Oct 2019 do not provide full time mirror power as earlier models (e.g. owner added Homelink mirror only powers up for 10 seconds after start up).
    ajsandiego, eurowner and VaToy like this.
  4. Mar 31, 2020 at 10:52 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Yes ,Bobs mirrors are the best. True plug and play, looks factory, can't beat the price. Took me 10 minutes and done. Now I can control all my garage doors and no more remote.
    ajsandiego and Jtoeps like this.
  5. Mar 31, 2020 at 11:31 AM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    i bought one on e-bay about 3 years ago for my 2016, there was no wire splicing require just plug the connectors together.
  6. May 18, 2020 at 1:29 PM
    TACAHOLIC
    TACAHOLIC Well-Known Member
    20 Cement DCSB TRD SPT
    I have a new one from a 2020 Sport that might be available.
  7. May 18, 2020 at 1:49 PM
    calebc
    calebc Well-Known Member
    Yep, I worked with Bob on figuring this out. However, it doesn't just power up for 10 seconds, it just doesn't work. You get power once the ignition is on but the mirror doesn't work. Bob's harness just splits the power wire and provides power to the other pin. This is actually super nice because then you can only use the homelink if the vehicle is turned on (i.e. someone can't break in to your truck and open your garage). If you are worried about your factory one being on all the time, you could get his harness and do the same thing. I think he charges $20 for the narness.
    That's because they are factory mirrors.
    2020 Changed so there's no longer fulltime power, the wire is there but it's dead.
  8. May 20, 2020 at 11:37 AM
    s.wilson
    s.wilson Less talk, more tech
    Morgan Hill CA
    1988 4Runner 3RZ, 2019 Tacoma TRD Off-Road
    TLCA Member #5261
