Upgrade to newer wheels?
Discussion in '1st Gen. Tacomas (1995-2004)' started by SmokeyDP, Aug 6, 2009.
What option should I go with?
Poll closed Sep 5, 2009.
  1. Beat stock wheels + BFG KO T/As
    3 vote(s)
    7.0%
  2. Powdercoat black stock wheels + BFG KO T/As
    26 vote(s)
    60.5%
  3. Find a set of 17" OEM take offs from a 06+ w/ tires
    14 vote(s)
    32.6%
  1. Aug 6, 2009 at 7:19 AM
    SmokeyDP
    SmokeyDP [OP] Well-Known Member
    Somerville, NJ
    03 Tacoma
    The wheels on my 97 are pretty corroded and the clear is pretty shot on them. I also need new tires and found that costco has the BFG A/T KO wheels for $660 installed for all 4. I have 3 options here:
    - Stick with what I have and just install new tires (cheapest)
    - Powdercoat the wheels black and get the new tires (not sure of the powdercoat cost)
    - Put on a set of low mileage newer wheels with tires from a newer Tacoma.
    Can I pretty much swap on any set of wheels and tires that came stock on a newer Tacoma or are there size issues? I've seen a bunch of OEM sets with under 10K on them for around $750ish...
  2. Aug 6, 2009 at 7:19 AM
    SmokeyDP
    Somerville, NJ
    03 Tacoma
    Here is the truck in question even though it doesn't show how rough the wheels look from 5 feet away:
  3. Aug 6, 2009 at 8:48 AM
    sirsaechao
    sirsaechao Well-Known Member
    Tim
    CA
    2002 Toyota Tacoma SR5 TRD 3.4L 4X4 V6
    A lift, some wheels, some tires, some performance, some cosmetic and then audio.
    Check around here and TTORA or even craigslist...you should be able to pickup a set of stock wheels for cheap.
  4. Aug 6, 2009 at 8:53 AM
    BAP_29
    BAP_29 Well-Known Member
    Ben
    North Carolina
    05 Prerunner DC TRD Sport
    Bilstein 5100s at 2.5" and Toytec 1.5" AAL Eagle Alloy 063 Wheels on 285/60/18 Cooper Zeon LTZ tires Alpine iDA-X305 Head Unit MB Quart DKD 116 Discus-Line 6.5" Front Speakers (Baffles by Marv) Alpine 6-Disk CD Changer Toyota All-Weather Floor Mats Kobalt Low-Profile Toolbox 13" Wicked Flow Muffler w/ Chrome Tip
    I say get the new bfg a/t tires and powdercoat your rims black. That way you'll have a new look instead of just replacing the stock stuff. Put a poll up on here and see what the votes say
  5. Aug 6, 2009 at 8:57 AM
    SmokeyDP
    Somerville, NJ
    03 Tacoma
    Does an admin want to attach a poll for me for the following options:
    - Powdercoat existing rims black and get BFG A/T KO tires
    - Find some OEM take-off's with tires
  6. Aug 6, 2009 at 8:58 AM
    Incognito
    Incognito No better friend, no worse enemy
    VA
    2012 Pyrite AC TRD OR
    Spacer lift, bumper stickers, ejector seat, etc.
    I'd say take option 3.
  7. Aug 6, 2009 at 8:59 AM
    SmokeyDP
    Somerville, NJ
    03 Tacoma
    Well newer OEM takeoffs with the stock tires even be the same diameter or will my speedo be off?
  8. Aug 6, 2009 at 9:03 AM
    Incognito
    VA
    I would only be off mabye 1-2 mph off if you go with a bigger 17'' rim or a taller tire.
  9. Aug 6, 2009 at 9:07 AM
    SmokeyDP
    Somerville, NJ
    03 Tacoma
    If I powerdercoat the wheels I am going to try to find a black oem bumper to replace the chrome one I have now since it's banged up. And maybe spray the grill black.
  10. Aug 6, 2009 at 9:15 AM
    BAP_29
    Ben
    North Carolina
    to add a poll go to the thread and click on thread tools. it should have an option where u can add a poll.
  11. Aug 6, 2009 at 9:21 AM
    SmokeyDP
    Somerville, NJ
    03 Tacoma
    Thanks. I kept looking in the Advanced post options which is where I am used to seeing it when you create a new thread.
  12. Aug 6, 2009 at 9:27 AM
    BAP_29
    Ben
    North Carolina
    no problem. were all here to help!
  13. Aug 18, 2009 at 6:23 AM
    SmokeyDP
    Somerville, NJ
    03 Tacoma
    I have been watching craigslist and the only wheels I found so far are a set of 2001's with BFG A/T's with 2K miles on them for $800.
    How much does it cost to get wheels powdercoated?
  14. Aug 18, 2009 at 8:02 AM
    BAP_29
    Ben
    North Carolina
    you'll have to ask around your local shops that powdercoat. ive seen a wide range of costs from others posting what it cost them. I think it cost most of them close to $50 a wheel though. Somebody correct that if I'm wrong
  15. Aug 18, 2009 at 8:11 AM
    Toyota Truck
    Toyota Truck Well-Known Member
    JT
    Texas
    2008 Prerunnner
    Magnaflow Muffler-TSB springs-Nuvi 265wt-aFe pro dry s filter-Husky Liners-Blue dome light-extra d-rings-OME 90000 sport struts-885 coils-N182 shocks-TSB AAL-LR UCAs-procomp black alloy rims- nitto terra grapplers-20% tint
    Get some new wheels if you powder coat them your just putting a band aid on the corrosion problem...I thinl
  16. Aug 18, 2009 at 8:33 PM
    04coma
    04coma Well-Known Member
    Justin
    Temple Texas
    04 trd offroad sr5 prerunner debadged
    air aid intake and throttle body spacer billet grill clear corner lights and 3rdbrake decal "coma" :)
    plz keep the speedo on lmao ok no joking im intrested in this thread too not wantin to screw up my "speedo" any way you put it its jus so dirty
  17. Aug 19, 2009 at 6:17 PM
    moto932
    moto932 What's the matter, Colonel Sandurz? CHICKEN?
    Eric
    Dayton, Ohio
    04 TRD Off Road
    Basically stock. OME 882s, HD Dakars and nitrochrgers, TG front bumper, custom rear bumper, 4Xinnovations sliders, RAT skids, Softopper, 255/85/16 ST MAXX's on 16" steelies, 1" B.O.R.A. wheel spacers Scangaugae II, deck plate mod, grey wire mod,ECGS bushing, diff breather relocation, alarm mod, defrost w/o compressor mod, de-badged, sockmonkey beside decals.
    i think the stock wheel that are on your truck look pretty good black. imo i would just paint those instead of getting a newer set
  18. Aug 19, 2009 at 7:55 PM
    RattleTractor
    RattleTractor Lube: It's the key to penetration.
    Harry
    VT
    '03/'04 Mutt Unicorn Tacoma
    1KZ-TE Diesel, GFC, Pizza cutters, Manual hubs, Dorkel
    OEM 17s are hideous. I had a set that came on my taco when i bought it. sold them immediately and bought the rims you have with 32 BFG ATs. best decision ever.
  19. Aug 20, 2009 at 10:20 AM
    phidauex
    phidauex Well-Known Member
    Sam
    Boulder, CO
    '96 4x4 V6, manual, 201k
    Small lift and a topper!
    The wheels you have are the same ones on my '97, and they were corroded as well. Personally, I think they were the best looking of all the stock wheels from around that era. I painted mine with Duplicolor Graphite (metallic dark grey) and really like it. The Satin Black would look nice too. Powdercoating is a good option, but for 6$, the Duplicolor is awfully tempting. I get comments on the wheels as they are, and people are surprised to learn they are stock, painted with a rattle can!
    To deal with the corrosion, just make sure you do a good job cleaning and sanding the wheels, a wire brush in a drill helps a lot. Remove, clean, sand, clean again, allow to dry, and follow instructions on the wheel paint. You don't even have to remove the tire if you mask with index cards stuck into the bead.
    -Sam
  20. Aug 20, 2009 at 12:48 PM
    SmokeyDP
    Somerville, NJ
    03 Tacoma
    I think I am going to just install some new tires on them and try the rattle-can approach for now. The idea of new wheels died when I bought a 2nd M3 yesterday. I haven't really seen anything aftermarket that I liked, and I think the wheels I have look almost as good as the newer style ones anyway. I haven't been able to find any take-off's with tires for a decent price anyway.
