Upgrade to Pioneer AVIC-W8400NEX questions/parts list, how does this look?
Discussion in 'Audio & Video' started by xenonsupra, Feb 13, 2019.
  1. Feb 13, 2019 at 10:36 PM
    xenonsupra
    xenonsupra [OP] Well-Known Member
    Joe
    Greenville, SC
    2019 White Pro MT, 1994 Supra TT 6spd
    I currently have a 19 Pro MT, so Entune Premium, non-JBL.
    Mainly looking for wireless carplay, capacitive touch, retention of stock steering wheel controls, stock GPS antenna.
    Here's what I plan on ordering and where I found the best price so far:
    AVIC-W8400NEX ($745 Amazon)
    Maestro ADS-MRR ($91 Amazon)
    Maestro HRN-RR-TO2 ($35 Amazon)
    Maestro ACC-SAT-TO2 ($32 Amazon)
    Metra 99-8251B Mounting Kit ($21 Amazon)
    AX-TOYUSB USB port kit ($10 Amazon)
    Metra 40-LX11 Antenna port kit ($9 Amazon)
    Questions:
    1. Which, if any, stock features will I lose? I think I read that I might lose lane departure assist?
    2. Any recommendations on a radio/trim removal tool set?
    I appreciate the help!
  2. Feb 14, 2019 at 6:32 AM
    su.b.rat
    su.b.rat broken truck
    not sure I've seen it done and reported here with a '19 yet, but maybe i just missed it.
    on a 17 MT, same premium non-jbl, a 8200nex and all the idata maestro stuff, i just lost the turn by turn on the dash, but everything else including wheel controls work. totally unsure about the new safety stuff, but good luck!
  3. Feb 14, 2019 at 7:47 AM
    Supr4Lo
    Supr4Lo Well-Known Member
    Surprise, AZ
    2020 DCSB Offroad MT, Supercharged, NWF Eco-Crawler, 4.88's Locked F&R on 37's
    xenonsupra[OP] likes this.
  4. Feb 14, 2019 at 5:37 PM
    Bridge4
    Bridge4 Well-Known Member
    MA
    2003 DCSB Imperial Jade
    I have an alpine head unit with the maestro and I tested out the lane departure this morning to check for you, it works on mine. Could be different with your headunit, but that harness should retain it.
  5. Feb 14, 2019 at 7:01 PM
    zXzL3GENDzXz
    zXzL3GENDzXz Well-Known Member
    Zack
    2019 toyota tacoma trd sport long bed (cement)
    I have the avh4200nex and doesn't effect anything but the audio doesn't mess with Lane departure or cruise control or nada. In a 2019 toyota tacoma trd sport double cab long bed
  6. Feb 14, 2019 at 7:11 PM
    destin_meeks
    destin_meeks I used to fix people's crappy stereos
    Destin
    Tuscaloosa, AL
    2017 SSM DoubleCab TRD Off-Road 4x4
    If lane departure works for the alpine, it will absolutely work for the Pioneer
    As for panel tools, don’t bother. No need for them in this truck
    Grab right side of trim (orange in my truck)
    Pull off
    Remove four 10mm bolts
    Remove radio
    I have used both the axxess and idata USB adapters for Toyota and had no problems with apply car play or android auto.
    Most issues come from people using cheap cables, not the adapter itself.
    CarPlay is pretty reliable even with pretty bad cables. Android auto is the finicky one. Good quality cable (preferably 4ft or under) and you should be ok with either adapter.
    If you want to keep XM, be sure to get the tuner
    When building your wiring harness, add a 6” pigtail to accy (red wire) ground (black) and remote turn on (blue or blue/white from radio) and cap them off. These come in handy down the road for adding things in without having to rip apart your harness. For example, running a turn-on wire to an amp, or powering a radar detector or dash cam.
    jmcwms, Bridge4 and xenonsupra[OP] like this.
  7. Feb 15, 2019 at 4:56 AM
    Bridge4
    MA
    Didn't know our HU was so easy to remove, thanks for that. Gives me more confidence in the future if I want to mess with anything.
    destin_meeks[QUOTED] likes this.
  8. May 24, 2020 at 10:27 PM
    bennyboon
    bennyboon New Member
    2018 Tacoma TRD pro
    Of I got the AVIC-W85000NEX would it be same wires that I need to buy as AVIC-W8400NEX ? Should I get an AMP or the sound is good enough? Thank you guys in advance
