Upgrade to Tundra brakes
Discussion in '1st Gen. Tacomas (1995-2004)' started by JDMcQ, Feb 17, 2010.
  1. Oct 26, 2017 at 7:01 AM
    #81
    BYJOSHCOOK
    BYJOSHCOOK Mr. Mojo Risin
    Josh
    Woodstock and Alpharetta Ga
    2000 SR5 4WD Lunar Mist
    Check Out My Builds
    Good luck! Only issue I had was I sheared a bolt into the axle housing so don't do that. Other than that it's a bolt on procedure
    Dalandser and TJlTT[QUOTED] like this.
  2. Oct 26, 2017 at 7:01 AM
    #82
    TJlTT
    TJlTT Member
    Colorado
    01 Tacoma Crew Cab
    I read on some other threads about similar problems, one took it to a shop and had his "brakes and pedal adjusted" cost him $40 dollars and solved the problem. Another guy had a leaking cylinder on the rear drum.....hope this helps.
  3. Oct 26, 2017 at 7:05 AM
    #83
    TJlTT
    TJlTT Member
    Colorado
    01 Tacoma Crew Cab
    Ouch, that's the worst. Maybe I should buy an easy out set now that I'm thinking about it.
  4. Oct 26, 2017 at 7:07 AM
    #84
    BYJOSHCOOK
    Josh
    Check Out My Builds
    Or just new bolts depending on how bad your truck looks haha. I did it putting the bolt back in
  5. Oct 26, 2017 at 9:39 PM
    #85
    TJlTT
    TJlTT Member
    Colorado
    01 Tacoma Crew Cab
    rusted of course, aren't they all? :rofl:
    BYJOSHCOOK[QUOTED] likes this.
