Upgrade UCA or Not - 1.5" lift
Discussion in 'Suspension' started by Markc1024, Sep 20, 2016.
  1. Sep 20, 2016 at 1:25 PM
    Markc1024
    Markc1024 [OP] Well-Known Member
    I've read I probably shouldn't need to on a 2016 for proper alignment, but I'm curious if there would be any realized improvement in doing so as part of my project? I'm currently not much into off-road and mainly looking for improved ride and some light trails camping/hunting. I've already got the Icon's and AAL ready to go.
  2. Sep 20, 2016 at 1:29 PM
    T4RFTMFW
    T4RFTMFW Well-Known Member
    Not needed.
    digitaLbraVo likes this.
  3. Sep 20, 2016 at 1:32 PM
    kashtyaatsi
    kashtyaatsi DieselDub
    Asher
    Bitterroot, MT
    LPC's
    Broken
    Nope.
  4. Sep 20, 2016 at 4:04 PM
    JT@Bajakits
    JT@Bajakits Well-Known Member Vendor
    JT
    Race Trucks and Off Road Suspension
    No...The main purpose of the UCA is to fix the lower caster issue that happens when you lift your truck. The factory cams run out of adjustment ability to fix both the Camber and Caster. At 1.5", you will be fine. Anything over 3", yes.
    So an aftermarket UCA either by design or adjustability, will fix the low caster and bring your alignment back into factory spec. The plus side is that they are made alot stronger than stock and allow for some additional droop in the suspension.
  5. Sep 20, 2016 at 4:12 PM
    gottaToy
    gottaToy Well-Known Member
    JJ
    movin' on up to the east side
    1985 Moped
    Rancho RS66903R7 @2.5", 2x4 block in rear. strait pipe, 37" super swampers
    Nope, not unless you plan on getting extended travel shocks, bigger tires, and need more caster to help with tire rub from the larger tires. If you have the Icon kit with extended shocks, you want to use them or you wasted money on the shocks, standard travel shocks, you wasted money on the UCA unless you like a lot of squeaking.
  6. Sep 20, 2016 at 6:01 PM
    Markc1024
    Thanks all - standard travel shocks.
