Upgrade Upholstery
Discussion in '1st Gen. Tacomas (1995-2004)' started by gibsonman63, Apr 20, 2014.
  1. Apr 20, 2014 at 3:20 PM
    gibsonman63
    gibsonman63 [OP] New Member
    Bob
    Houston
    PreRunner
    Stock
    I took a chance on eBay and bought a used passenger seat from a 1998 Tacoma. Eight bolts later, I have a new driver's seat on my 1999 Tacoma. Total time under an hour. The hardware and mounts are different from the driver to the passenger side, but the upholstery is the same and fits either side.
  2. Apr 20, 2014 at 5:22 PM
    Andy.G
    Andy.G Well-Known Member
    Andy
    Virginia
    96 tacoma sx 4x4 2.7 5 speed
    Started automatic. Swapped to manual
    Did you skin it?
  3. Apr 21, 2014 at 4:13 AM
    gibsonman63
    Bob
    Houston
    PreRunner
    Stock
    No skinning required. The bottom part has four bolts holding the seat to the frame. You have to remove the plastic trim off if each side first. The top is also held on with four bolts. The seat is clipped together at the bottom. Unclip by hand and push the cover up on each side to reveal the bolts.
  4. Apr 21, 2014 at 6:35 AM
    Andy.G
    Andy
    Virginia
    Cool. So the seats are bi, only seat rails are left and right!
  5. Apr 21, 2014 at 7:23 AM
    40950 Well-Known Member
    CR, WA
    1999 8 port 3RZ 4WD SR5
    stock
    So you had a 60/40,, you removed the 60 and just bolted a 40(pass seat) into those driver side mounts?
  6. Apr 21, 2014 at 8:26 AM
    Ice Horse
    Ice Horse Stalking horse
    Lauren
    Florida
    Two 1998’s and a 2025. All TRD Offroads.
    ADS Racing Shocks 2.5" Extended Travel Coilovers with Reservoirs, 3 inch All Pro rear suspension kit, factory E-locker, Trail Gear sliders and front stinger bumper, CBI Offroad rear tube bumper, XRC8 Winch, 33 inch BFG KM2's, 16 inch Ivan Stewart Wheels, Uniden CB radio, flip up license plate, white tail lights, LED front signals, Tundra front brake upgrade, new radio, rock lights, sub woofer, remote start, satoshi grille with Prius emblem, Rigid DOT/SAE Fog Lights, 12" Light Bar
    How does that work with the seat belts?
  7. Apr 21, 2014 at 4:44 PM
    Andy.G
    Andy
    Virginia
    Must be buckets.
  8. Apr 21, 2014 at 6:11 PM
    gibsonman63
    Bob
    Houston
    PreRunner
    Stock
    It only works with buckets. The seat belt clip is attached to the frame, which is not used. Sorry I did not take pictures of the process, but I was learning as I went.
    A couple more notes:
    I wasn't sure if I could get the seat belt warning sensor connector apart without breaking it. Once I removed the four hold down bolts for the seat, I had enough room to maneuver the seat around in the truck without unplugging it.
    I installed the bottom cushion on the driver seat before I removed the seat back. Once I removed the seat back from the donor seat (both cushions removed), the rails come apart. I got lucky and did things in the correct order. This would have been much harder if I had removed both before installing the donor upholstery on my existing driver seat rails.
