Upgrade Your 2024+ Tacoma: TRUMGETA Side Steps & Running Boards for Style & Durability!!
Discussion in 'TRUMGETA' started by TRUMGETA, Feb 17, 2025.
  1. Feb 17, 2025 at 4:06 AM
    TRUMGETA
    TRUMGETA [OP] Active Member
    2024 White Tacoma TRD
    Hey Tacoma enthusiasts,
    Are you ready to enhance the functionality and style of your 2024 Toyota Tacoma Double Cab? Look no further! TRUMGETA is excited to introduce our comprehensive lineup of side steps and running boards, designed specifically to blend durability, style, and convenience for your Tacoma. Whether you're gearing up for off-road adventures or daily commuting, we've got the perfect addition to your truck.
    1. 4Pcs EZ Side Steps for 2024 Toyota Tacoma Double Cab/Crew Cab
    • Material: Crafted from robust steel for maximum durability.
    • Loading Capacity: Can handle up to 350 lbs on each panel.
    • Design: Features a sleek, flush design with the chassis height and a wide 6.7-inch step.
    • Installation: Quick and easy DIY installation.
    Purchase Here
    2. 5.5" Running Boards for 2024 Toyota Tacoma Double Cab
    • Material: Made from sturdy aluminum.
    • Loading Capacity: Supports up to 600 lbs.
    • Features: 5.5 inches in total width with a 4.3-inch step width and anti-slip step pads for secure footing.
    • Installation: Straightforward bolt-on installation.
    Buy on Amazon - Use code 10PSN6ML at checkout for a 10% discount!
    3. 5" Running Boards for 2024 Toyota Tacoma Double Cab
    • Material: Constructed from durable aluminum.
    • Loading Capacity: Up to 600 lbs.
    • Features: 5 inch step width with an anti-slip surface to ensure safety and ease of use.
    • Installation: Effortlessly install with bolt-on connections.
    Purchase Here
    4. Running Boards for 2024 Toyota Tacoma Double Cab
    • Material: Designed with high-quality aluminum and an ABS surface.
    • Loading Capacity: 500 lbs.
    • Features: 4.5 inch step width offers a balance of comfort and support.
    • Installation: Simple bolt-on installation for quick setup.
    Purchase Here
    Each of these options is engineered to meet the specific needs of Tacoma owners, ensuring that you not only enhance the accessibility of your truck but also boost its aesthetic appeal. With TRUMGETA's side steps and running boards, you're not just stepping into your vehicle; you're upgrading your entire driving experience.
    Feel free to ask questions, share your thoughts, or even post pictures of your Tacoma equipped with TRUMGETA products! We love seeing our accessories in action and hearing from our community.
    Drive safe and step confidently with TRUMGETA!
    Best,
    The TRUMGETA Team
    mjp2 likes this.
  2. Feb 17, 2025 at 4:24 AM
    CTSpruceMica
    CTSpruceMica Is a hotdog a sandwich?
    Dennis
    2014 Spruce Mica
    These products are made where?
