Upgrade your ScanGauge II
Discussion in '1st Gen. Tacomas (1995-2004)' started by 97TacoNM, Dec 10, 2014.
  1. Dec 10, 2014 at 8:03 AM
    97TacoNM
    97TacoNM [OP] Riding a 97 Taco
    Jim
    NM
    97 Taco LX 4x4 Ext Cab
    Rampage halogens Custom bed rack
    Just FYI for anyone that has this nice scanner - ScanGauge II. For $25 you can send in your unit and they will upgrade the firmware to the latest version (4.13). Check your version (mine was 4.02), and if you like send in your old unit, along with $25 and their upgrade form, and voila - new firmware. My SG II has been a fantastic tool, used it a lot.
    http://www.scangauge.com/support/upgrade/
  2. Dec 10, 2014 at 9:52 AM
    kigmob
    kigmob Well-Known Member
    James
    New Orleans
    97 TRD S/C 4x4 V6 5spd
    ICON/TC TRD Supercharger URD 2.2 and 7th
    Any noticeable difference?
  3. Dec 10, 2014 at 1:14 PM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    It is interesting that it does not say why I should do this.
    I would also be curious to know if the currently programmed XGuage codes get erased or have to be re-entered after the firmware update.
  4. Dec 10, 2014 at 2:40 PM
    97TacoNM
    Jim
    NM
    I haven't done it yet, but being an old school IT guy, I tend to always lean towards software updates and firmware updates, as any errors or potential problems tend to be corrected. Of course, new ones may be introduced ;) And any time you have the first of a kind, well, you know. 4.02 was the first firmware with performance monitoring, so they may have tweaked that a bit. No idea about the XGauge thing, but I bet they would answer a mail :)
