Upgraded brakes?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cmartinez58, Nov 21, 2021.
  1. Nov 22, 2021 at 2:02 PM
    #41
    MidCitiesMildMan
    MidCitiesMildMan Well-Known Member
    2017 Toyota Tacoma Limited
    Stock and staying that way
    If you use SRF you can skip the annual flush. I’ve road raced a 3,700# 500hp car on technical tracks known to be hard on brakes. And ran SRF for years between a caliper bleed (not full flush).
  2. Nov 22, 2021 at 2:06 PM
    #42
    vecdran
    vecdran Barely-Known Member
    Jeremy
    Kirkland, WA
    2020 TRD Pro Super White 6MT
    Financial Black Hole
    Good lord, $75/liter? I'd rather bleed semi-regularly with a cheap high temp DOT3.
    I thought it the end it doesn't matter what fluid you use, it's always going to load up with water eventually, especially higher temp formulations?
  3. Nov 22, 2021 at 2:19 PM
    #43
    MidCitiesMildMan
    Fully saturated SRF has a higher boiling point than DOT 3 has straight out of the bottle. How much is your time worth?
    vecdran likes this.
  4. Nov 22, 2021 at 2:21 PM
    #44
    Vst
    Vst IG:@vehiclesupportedtravel
    Scott
    Kodak, TN
    18’ Access cab TRD OFRD 4x4
    Where did you get the propex heater I’ve looked everywhere and can’t find any in stock
  5. Nov 22, 2021 at 4:29 PM
    #45
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    If the stock brakes were not adequate for normal use (hauling and towing within the limits published by Toyota), I think there would be a class action lawsuit. Also always keep in my that your tires are what limit your braking; not the brakes (unless they overheat). I personally am going to spend my money elsewhere.
  6. Nov 22, 2021 at 6:25 PM
    #46
    NMBruce
    NMBruce Well-Known Member
    SW Colorado
    2020 Quicksand TRD OR, sold = 2006 GX470 (past 85, 2-1987 pickups,90, 92, 96 pickup, 2000 xtracab, 2002 double cab)
    Ironman Foamcell 3" lift, ARB dual compressor, GoPro mount, BadElf mount, Drive grab handle, RCI skids, Victory sliders, half rack, TuffStuff Alpha ll RTT, Dometic 75 Fridge, extra USB & Outlets
    for many years, I used Valvoline Synthetic DOT 4 brake fluid and would use it again.
    Dry Boiling Point, 446°F,
    Wet Boiling Point, 311°F
    Since I was at a road cross about 1-2 times a month for the Porsche club, Drivers Edge and others, I was changing my fluid every 6 months.
    With my daily vehicles, I check the PH level and change as needed.
  7. Nov 22, 2021 at 8:05 PM
    #47
    shotgunbilly420
    shotgunbilly420 OG Owner 249+ mi club/Tacoma enthusiast
    Montesano, Washington elv. 66ft
    2017 trd Tacoma offraod AT Inferno
    315/75/16, 6in modded RC lift,Anderson Engineering manifold spacer,K&N air intake, URD YPipe, stock exhaust ,16" method nv305 wheels, AFE throttle body spacer, vf Tune program, JTL 3.0 Oil catch can x2, rear cat delete
    Wtf
    muddog321 likes this.
  8. Aug 31, 2023 at 2:30 PM
    #48
    TegoTaco
    TegoTaco Well-Known Member
    Ontario, Canada
    ‘13 SUPERCHARGED DCLB TRD SPORT
