Upgraded door speakers
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TacoYeastAffection, Dec 5, 2024.
  1. Dec 5, 2024 at 11:13 PM
    TacoYeastAffection
    TacoYeastAffection [OP] Well-Known Member
    Johnny
    Kremmling, Colorado
    red 2018 DCSB MT TRD OR and a SAS 1st gen 4runner
    Rough country 4 inch lift and leaf springs with some other mods roughly 5" of lift SPC UCAs 285 75 R16 Black Rhino Arsenal 16x8 -10 spidertrax 1.25" wheel spacers front LED interior lights under-hood light strip Hefty Fabworks front hybrid bumper Badland 12k synthetic winch Body Armor 4x4 PRO-Series Rear Bumper Lasfit amber fog lights and 20" bar Snugtop sport Hiliner shell "deleted" the front sway bar did the 2WD low mod
    Anyone know of some good turn key/plug n play door speakers that are better than factory? I'm not a sound system guy but just curious to see if there are some good replacement speakers that have better sound/bass and are louder.
  2. Dec 6, 2024 at 2:49 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Put an amp to the factory unit and the factory speakers come alive. You will have the best of both worlds for about the same cost and then add an amp/sub combo. Thank me later!
  3. Dec 6, 2024 at 3:03 AM
    TacoYeastAffection
    Johnny
    Kremmling, Colorado
    I'll have to look into that... thanks for the input!
  4. Dec 6, 2024 at 6:04 AM
    Jesse H
    Jesse H Well-Known Member
    Jesse
    Texas
    '22 TRD Pro 6MT
    Agreed with the above. Most aftermarket speakers won't sound better than what you've got unless you add power.
  5. Dec 6, 2024 at 6:52 AM
    SilverTRD Sport
    SilverTRD Sport Well-Known Member
    Houston, TX
    2016 TRD Drowned now 2017 Inferno TRD Sport
    Any suggestions on Amps?
    SnuggleTruck likes this.
  6. Dec 6, 2024 at 7:46 AM
    eurowner
    eurowner Duke Sky
    Scoty
  7. Dec 6, 2024 at 10:52 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    I changed out the Tweeters and added an underseat powered Sub, which makes the sound so much louder.. Didn't touch the door speakers. Sounds soo much better now.
    Wwjvd likes this.
  8. Dec 6, 2024 at 1:27 PM
    SloTaco13
    SloTaco13 Well-Known Member
    California
    2023 Lunar Rock TRD Offroad 4x4
    If you don't have the factory JBL system, everything should be more straight-forward. As other have said, speakers will add clarity, but probably no additional volume (without an aftermarket amp).
    - Check out Trail Grid Pro and Taco Tunes for plug and play solutions (speakers, amps, head-units, wiring harnesses, etc.).
    - OEM Audio Plus also has a plug and play speaker kit for non-JBL trucks.
    The factory JBL system makes things more complicated and expensive (my truck has JBL). I really want to try the plug and play Beat-Sonic "Encore" amp as it claims to boost power and clarity with both the base sound system and JBL system. I personally can't speak to it yet, but it's on my Christmas list.
  9. Dec 6, 2024 at 3:05 PM
    Wwjvd
    Wwjvd Well-Known Member
    Jimmy
    2022 TRD Off-road 4wd
    OP, sounds like you should start here as @Tocamo and most people do.
    If you don't see yourself as a 'sound' guy, these two upgrades will satisfy most folks and can be done reasonably $
    Tocamo[QUOTED] likes this.
  10. Dec 7, 2024 at 2:49 AM
    VaToy
    Parts Unknown
    I used a Rockford and it's behind the dash and a Rockford amp/sub combo behind the rear pass side seat. Fits like a glove, looks OEM and sounds incredible and a set of 2-way dash tweeter/speaker. Even my Friend's stereo shop was greatly impressed.
    Dg75 and TacoYeastAffection[OP] like this.
  11. Dec 7, 2024 at 6:41 AM
    Willy Lump Lump
    Willy Lump Lump Well-Known Member
    21’ dcsbmt
    This and that
    All my speakers have been changed out with kickers I bought from Crutchfield, my front door speakers are 6x9 3 way. And the rear are 6” 2 way. It sounds way better than stock. No amp, yet.
  12. Dec 7, 2024 at 7:25 AM
    mikesixtysix
    mikesixtysix Well-Known Member
    North Jersey
    2018 TRD Pro
    after replacing my non-jbl head unit with a pioneer dmh-wt7600nex i replaced the absolute trash speakers with some pioneer and kenwood mid-level quality speakers from crutchfield (pioneer ts-g690 and kenwood kfc-1796ps), and the stock subaru tweeters that are a popular upgrade. it's like night and day vs the stock system. i was amazed how trash the stock speakers were, feather light with the tiniest magnet and made out of the cheapest materials.
    MrTreehorn and Kcruisin like this.
  13. Dec 7, 2024 at 9:20 AM
    I.eat.tacos
    I.eat.tacos Well-Known Member
    Steve Rogers
    '18 TRD 4x4 Sport
    Please report back on the additional amp for your JBL system. I was thinking of doing the samething too.
    SloTaco13[QUOTED] likes this.
  14. Dec 7, 2024 at 10:06 AM
    Jesse H
    Jesse
    Texas
    '22 TRD Pro 6MT
    I'm actually impressed by the quality of the factory speakers. I believe they use neodymium magnets which are stronger and lighter. In the industry stronger and lighter means more expensive.
  15. Dec 7, 2024 at 11:04 AM
    wood714
    wood714 Got any Quaaludes?
    Kevin
    East Coast Florida
    2018 4x4 V6 SR5
    LOL!
    I changed the tweeters, door speakers, and put a 20W JVC head unit in my truck. I think the factory non JBL I had put out 6W. The JVC really helped along with the speaker upgrade.
    Crutchfield has plug and play harnesses to make the job simple.
    mikesixtysix likes this.
  16. Dec 7, 2024 at 5:00 PM
    TacoYeastAffection
    Johnny
    Kremmling, Colorado
    Man this is like a whole new field I need to learn about... I can wire lights and rebuild a transfer case but this shit sounds like Hogwarts lol thanks for all the info! I'll need to go down the rabbit hole and look into some of your guys' set ups.
    Suggestausername likes this.
  17. Dec 7, 2024 at 6:18 PM
    TheGrayNorthWest
    TheGrayNorthWest Well-Known Member
    I put some 6x9 JL 2-way speakers in my doors, and assumed I would add an amp later, but they sound great, and I am happy with the sound levels from the factory head unit. As others have mentioned, if you buy them from Crutchfield, they give you the harnesses for a plug and play install.
    *note* I also had already replaced the dash speakers with the Subaru Kicker tweeters off of Amazon (also plug and play) which was a HUGE upgrade, but the mids and lows were missing, so I added the JLs. Friends often comment on how good my stereo system sounds, and I laugh because all I did was replace the front 4 speakers.
    I think if you listen to music super loud or want huge bass, then an amp will be necessary, but you'll also probably want to add a subwoofer. Personally I'd start with the speakers and see if that isn't enough. For me it made a huge difference.
  18. Dec 29, 2024 at 1:51 PM
    Dg75
    Dg75 Member
    NY STATE
    2019 MT AC QUICKSAND
    Please post pic
  19. Dec 29, 2024 at 9:29 PM
    MrTreehorn
    MrTreehorn 2016 TRD BUILD IN PROGRESS
    Dan
    SF East Bay
    2016 TRD OR 4x4 MGM
    King 2.5s F/R, Icon RXT Leafs, Camburg UCAs, Wheeler's Offroad Superbumps, AllPro Spindle Gussets, JDFab Double Sheer Steering, RCI Skids, Bay Area Metal Fab Shackles and Hangers, Bay Area Metal Fab Gas Tank skid, RRW RR7H Flow Formed, 34" Mickey Thompson Baja Boss A/Ts , AllPro Sliders, Snug top Camper shell, MESO Customs bits n bobs, Powerbrake BBK, SSO Hybrid Front Bumper, Baja Designs 20" Amber LB, Warn Evo 10s
    Have to agree, trailgridpro is a great solution for plug and play packages in speakers. I have the same kickers they offer and they are great. Granted I have a dedicated amp and pioneer head unit.
    For a subwoofer many recommend the kicker hideaway's in 8" or 10". Seeing as you have a 2018 you may not have power seats. Unless you have seat jackers you'll have difficulty clearing this sub under a seat.
    For a subwoofer I removed my driver rear behind seat cover and was able to fit a JL Audio 8" powered sub which is a bit more pricey but far better performing than the kicker and doesn't require a dedicated amp, but you do have to run power to your battery.
    WARNING: If you have factory JBL speakers you are running 2 ohm and complicates installing new speakers as majority are 4 ohm if you plan to just go with your factory headunit.
  20. Dec 30, 2024 at 3:49 AM
    VaToy
    Parts Unknown
    Of what the rear sub? If so when I get back in town.
