Upgraded E-Locker axle
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tangerinetaco87, Aug 18, 2025.
  1. Aug 18, 2025 at 7:13 PM
    Tangerinetaco87
    Tangerinetaco87 [OP] New Member
    I am brand new to the Tacoma world forum and looking for help in wiring a locker into my truck I have a 4x4 sport but just upgraded to a 4x4 Offroad axle with a locker and do not have a harness to actuate the locker could you help me? Does anyone have a DIY harness I can buy or get?
  2. Aug 18, 2025 at 8:31 PM
    Toycoma2021
    Toycoma2021 Well-Known Member
    Northern California, Temporarily
    2021 Access Cab, LB, AT, V6, Off Road
    Nope, I've not heard of a manufactured harness produced. There was work on an anytime rear locker but haven't heard much about that recently. In the stock configuration the E-locker could only be activated in 4LO.
    You will need the female connector that goes to the locker coil, plus a 12vdc source to drive the coil. Are you aware the stock ECU puts out a PWM source to the locker. There is debate as to if it is needed though.
    This should get this thread started for others to join in.
    SR-71A likes this.
  3. Aug 18, 2025 at 9:04 PM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    shoulda researched more. the oem e locker isnt as simple as sending it switched 12v power. it uses 12v to engage then drops down coil voltage to 8v to maintain engagement.
    MR E30 likes this.
  4. Aug 19, 2025 at 7:13 AM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    I know a couple people have tried to make this work, but I don’t know if anyone has been successful. You’ll need to do some research. Searching for “site:tacomaworld.com anytime locker” or “site:tacomaworld axle swap locker” on google will get you started.
    Here is one hit for you:
    https://www.tacomaworld.com/threads/full-axle-swap-for-rear-locker.783479/
    You might be better off swapping back to the old axle and installing an aftermarket locker. Sorry to be the bringer of bad news.
  5. Aug 19, 2025 at 7:29 AM
    TacoTuesday603
    TacoTuesday603 I welded it helded
    Jack
    New Hampshire
    2011 OR DCFB
    Fox and Locked suspension 63's Skinny 33's
  6. Aug 19, 2025 at 7:32 AM
    gudujarlson
    Minnesota
  7. Aug 19, 2025 at 7:33 AM
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    Read the title.
    gudujarlson[QUOTED] likes this.
  8. Aug 19, 2025 at 8:07 AM
    545 Well-Known Member
    2015 Access Cab
    The thread contains useful info
  9. Aug 19, 2025 at 10:31 AM
    devinzz1
    devin
    2023 aclb trd or mt
  10. Aug 19, 2025 at 12:06 PM
    gudujarlson
    Minnesota
    I misread the title and failed at skimming the post for important points. The key is this:
    “This swap was made much easier by Joshua Peace at ExperiMental Designs, maker of the Freedom Locker for 2nd and 3rd Gen Tacomas, working with me to develop a prototype wiring harness, to allow me to swap a 3rd Gen OR axle assembly into my 2nd Gen Tacoma.”
    He appears to have proven wrong those in the thread I posted that said it was too complicated to be worth doing, but I don’t understand all the details.
  11. Aug 19, 2025 at 12:50 PM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    This part has absolutely nothing to do with wiring the Locker. But AT and MT have different gear ratios so hopefully the donor truck had the same Transmission as your Sport.
    blu92in99, devinzz1 and tonered like this.
  12. Aug 19, 2025 at 1:27 PM
    devinzz1
    devin
    2023 aclb trd or mt
    the experimental designs guy is an electrical engineer is he not. to mimic function of oem 4x4 ecu its not an average joes task. what many people do is just send 8 volts to the locker but it doesn't engage as easily
  13. Aug 19, 2025 at 2:26 PM
    TacoTuesday603
    Jack
    New Hampshire
    2011 OR DCFB
    I wonder if it just needs 12v to engage then it holds the locker engaged with 8v. To prevent overheating of the electromagnet. I think Cummins shut down solenoids work in a similar way
    tnt116 likes this.
  14. Aug 19, 2025 at 2:36 PM
    gudujarlson
    Minnesota
    I don’t know who he is, but I have read some pretty in-depth discussion of the problem on here, more in depth than you describe.
    shakerhood likes this.
  15. Aug 19, 2025 at 2:38 PM
    Toycoma2021
    From my memory of reading of the old threads the lock voltage was indeed something like 12V and then reduced to 8V, but it was PWM. So the frequency of the PWM could have been what was being measured rather than the true voltage.
  16. Aug 19, 2025 at 5:28 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    Per service manual, diff locked above 3.5V
    Unlocked 3.5V or below.
    PWM is on CAN lines to provides status to ecu for locked and unlocked positions
  17. Aug 19, 2025 at 5:47 PM
    Toycoma2021
    Nope, I’ve measured it with a scope meter. Definitely PWM. Floating not grounded.
    Locked and unlocked condition was a simple switch closure reported to the 4x4 ECU.
  18. Aug 19, 2025 at 6:07 PM
    Vlady
    Issy, WA
    Measured at the coil or ECU?
    per service manual the coil output is PWM
  19. Aug 19, 2025 at 7:30 PM
    devinzz1
    devin
    2023 aclb trd or mt
    this is how it works from what i remember reading. it doesn't seem to need the full 12 volts though. it will engage with just 8. i actually ordered everything to do a standalone switched setup myself and still have in my garage somewhere.
  20. Aug 19, 2025 at 8:34 PM
    Toycoma2021
    I did my measurement at the diff coil input and it was PWM, the output from the ECU would be the same with some waveform degradation at the diff. Voltage is input to the coil to energize it. It is not an output at the coil.
    Your attached chart shows the output at F12 (the 4x4 ECU). Curious that they show no measurement test between pins 1&5 of F12; that is where the real power is put to the diff coil. You didn’t include the “Waveform 1&2” detail, they probably show reverse polarity. The test seems to be testing each side of the FET output from the ECU. Making sure both FETs are conducting. If one FET was not conducting properly it might seem like the locker was working but not reliably.
