Upgraded heat exchanger/bigger coolant res
Discussion in 'Performance and Tuning' started by Brianawd, Sep 4, 2015.
  1. Sep 4, 2015 at 10:03 PM
    Brianawd
    Brianawd [OP] Well-Known Member
    Brian
    Portland OR,
    2015 Tacoma dclb
    Billstein 5100s set at 2.5 in the front,2in AAL in the rear with 5100s
    So I'm working with some friends that work at extreme turbo systems that are going to build me a thicker heat exchanger with my SC Tacoma. They are also going to build me a bigger coolant reservoir. If I can get enough interest they may start producing this as a kit. So just trying to gauge interests to see if it's even worth their time. If interested please PM me
    Here is there link. They make some of the best intercooler and turbo kits around. Along with having a world record GTR and evo X
    http://www.extremeturbosystems.com
    Torspd, D.Mathys and 1truckdriver like this.
  2. Sep 7, 2015 at 1:12 AM
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    for trd SCer?
  3. Sep 7, 2015 at 3:04 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Yep
    Urd already has a larger one
  4. Sep 7, 2015 at 3:36 PM
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    I dont see any signs of said product on URD site
  5. Sep 7, 2015 at 5:31 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    It's in the MK kits, not separate
  6. Sep 7, 2015 at 7:13 PM
    BenMara
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    that helps me none.
    vlodpg likes this.
  7. Sep 7, 2015 at 7:28 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    It comes with the rotrex supercharger kits
  8. Sep 7, 2015 at 7:35 PM
    vlodpg
    vlodpg Well-Known Member
    Connecticut
    15 Tacoma TRD Off Road 6sp Supercharged
    TRD Supercharger/URD Stage II Clutch
    PM Sent
  9. Sep 7, 2015 at 7:43 PM
    Brianawd
    Brian
    Portland OR,
    2015 Tacoma dclb
    The UDR supercharger kit uses a air to air intercooler not a heat exchanger
    Torspd likes this.
  10. Sep 7, 2015 at 8:21 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Shit
  11. Sep 9, 2015 at 4:45 AM
    VolcomTacoma
    VolcomTacoma Well-Known Member
    Jeff
    NorCal
    2015 TRD Sport 4x4 6 Speed Supercharged
    Front- Camburg 4x4 Long Travel 2.5" King Coilovers 2.5" King Triple Bypasses Wheelers Superbumps Rear- DMZ SUA 16" 3.0 King Triple Bypasses 3" 2.0 Fox bumps Wheels and Tires- 295/75/16 Toyo ATII XTREME SCS SR8 Dark Matte Bronze 16" Lighting- (2) 30" Combo light bars (4) Iggycorp diffused pods Tepui Ayer TRD Supercharger URD Mark III 3" Exhaust URD 4x4 Y Pipe URD CAI URD 2.85 Stealth Pulley Hurst Core Shifter with Hurst T URD Stage 3 clutch URD Lightweight flywheel URD Throw out bearing upgrade AEM Wideband AFR Gauge Speedhut Boost Gauge Craven Speed Flex Pod mount Weathertech Floor Liners BAMF Sliders Ultragauge sPod SE ARB CKMTA12 Hella Supertone horns Relentless Tailgate Reinforcement
    Id be down as long as its all completely bolt on. I dont wanna have to start adjusting tubing and bolt holes and shit.
  12. Sep 9, 2015 at 5:34 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Now if they only made a turbo kit....... :spy:
  13. Sep 9, 2015 at 5:35 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I second this.
  14. Sep 9, 2015 at 5:41 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Pipe down exhaust powerboy
    Torspd[QUOTED] likes this.
  15. Sep 9, 2015 at 7:20 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Xanax
  16. Sep 9, 2015 at 7:42 PM
    smaldo76
    smaldo76 Well-Known Member
    steve
    Clover, SC
    Black Baja
    TRD BOOST afe intake, doug throrley headers, predator step bars
    Sounds good, I think the reservoir could look a lot better.
  17. Sep 10, 2015 at 5:21 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    From a reliability standpoint, an aluminum can will last much longer. As well as look better. That reservoir is an easy build for a shop like them. If ETS can plastic weld, they could weld that nipple which is prone to cracking. Just as a secondary back-up.
    BenMara likes this.
  18. Sep 10, 2015 at 9:43 PM
    TRON
    TRON Well-Known Member
    All Wheel Drive X-runner
    TRD Blower, 2.3 Pulley, NST OverDrive Pulley Kit, B&M Shifter, TR Lowering Kit, Spec Clutch, Xrunner Body Kit
    The Heat exchanger is always cool to the touch even in the hot summer months and I'm running the highest SC pulley ratio you can get. The prize would be a larger intercooler bolt on to the TRD SC FTW!!!
    BenMara likes this.
  19. Sep 22, 2015 at 9:03 PM
    Brianawd
    Brian
    Portland OR,
    2015 Tacoma dclb
    Working on getting a day off so the can take some measurements.
    The problem with a larger air to water intercooler is we don't have the space. But I will see if they have a more efficient core they could use. Also a pump that flows more can really help with the cooling as it could move more water faster
  20. Sep 23, 2015 at 10:09 PM
    TRON
    There is barely a quart of coolant in the TRD SC cooling system. One would think that pump is more than efficient.
