Upgraded Ron Davis Radiator
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Torspd, Apr 20, 2017.
  1. May 13, 2017 at 11:44 AM
    #61
    SonnyBones
    SonnyBones I VOID WARRANTIES
    Jeffery
    2015 TACOMA ACCESS CAB
    Gonna need someone that has a SC to be the guinea pig :) I'll probably order race version to compliment SC install in the coming months.
    Another question. Were your SPAL's wired to factory harness? If so, how'd it handle the current draw as these fans take some juice. I would think alternator would need to be upgraded as well.
    Skootter14 likes this.
  2. May 13, 2017 at 1:58 PM
    #62
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I had upgraded to the 130 amp Denso alternator, some time ago. Originally, my factory equiped 90 Amp, showed signs of too much draw, when the fans kicked on.
    I purchased their fan harness, and wired it in. Well, had Kozmic wire it in. It is not wired to the factory harness though. Only thing is that once the fans are turned on by its t-stat, they stay on until the truck is turned off.
    mav and SonnyBones like this.
  3. May 14, 2017 at 10:35 AM
    #63
    2big4arunner
    2big4arunner Well-Known Member
    Tyler
    Vernon BC
    2015 tacoma dclb
    3/2 leveling kit, 275/60r20 duratracs on xd128 20x9 rims, AFE stage 2 intake, trd exhaust, duel electric fan w/dakota digital controller
    I use a dakota digital pac-2750 controller with my duel efans. you have options on how you want to run the fans as well as being able to adjust the on and off temperatures. I run an inline temp sensor using a basic ebay inline housing. I would imagine that the fans should be turning off for you but I am thinking that they aren't reaching their off temp that is needed on the relay unit.
    #63
  4. May 14, 2017 at 11:29 AM
    #64
    SonnyBones
    Jeffery
    Interesting that they stay in till your vehicle is shut off.
  5. May 14, 2017 at 12:54 PM
    #65
    Torspd
    Tor
    The Great America!
    Better solution than my current one. I could tie it into my Haltech ECU, and have it control them. Was not an option before. The confounded ProEFI was just cumbersome.
    #65
  6. May 14, 2017 at 3:54 PM
    #66
    crashnburn80
    Kirkland, WA
    2003 DCSB TRD OR
    Any comments on fan noise or current draw? I've converted to electric fans on previous modified trucks, and it sounded like a loud hair dryer when running under the hood. Granted your truck is pushing the envelope, but while I advocate for function over form, it was obnoxious on a daily driver.
    12TRDTacoma likes this.
  7. May 14, 2017 at 4:01 PM
    #67
    TACORIDER
    TACORIDER Just another statistic
    JAKE
    EAST TAWAKONI TEXAS
    12 TACO and some other Toyota’s
    Looks good, wonder when the prices will be revealed
  8. May 14, 2017 at 4:10 PM
    #68
    Large
    Large Red
    Much like the newer chevy pickups I imagine
  9. May 14, 2017 at 5:03 PM
    #69
    2big4arunner
    Tyler
    Vernon BC
    2015 tacoma dclb
    My twin 12" are barely able to be heard when both are running. Under 20amps max draw. About 1/10th of the mechanical fan I removed in power consumption due to how I wired it in.
    Torspd[OP] likes this.
  10. May 14, 2017 at 5:31 PM
    #70
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    Can we see the upgraded one now?????? not the race one
  11. May 14, 2017 at 7:49 PM
    #71
    gersus
    gersus Well-Known Member
    Missouri
    14 Tacoma DCOR
    Lil lift, bumpers, SC, UCON, headers, etc.
    That radiator is kick ass!
    I dont need a radiator. I dont need a radiator. I dont need a radiator.
  12. May 16, 2017 at 7:35 AM
    #72
    Torspd
    Tor
    The Great America!
    I will see about getting a short video. The phone video won't be as accurate as quality sound equipment, but hey, they work for exhaust video clips. :rimshot:
    Call them up! Just make sure to ask for the price of each.
    Hmmmm. Maybe?
    Don't know if they have one made? You're close. Stop by!
  13. May 16, 2017 at 11:40 AM
    #73
    MrCrowntown
    Alyn
    Ky
    You said they shipped you two radiators??
  14. May 16, 2017 at 11:57 AM
    #74
    Torspd
    Tor
    The Great America!
    That was the core radiator that I had originally shipped them, for mock-up.
    SonnyBones and MrCrowntown like this.
  15. May 16, 2017 at 12:32 PM
    #75
    SonnyBones
    Jeffery
    Whats was the total wait time for it to be built? I'm assuming this is not something they stock from looking at the website
  16. May 16, 2017 at 7:56 PM
    #76
    Torspd
    Tor
    The Great America!
    Being that they have all of their required specifications, I imagine a couple weeks. Whereas before it was a few months.
  17. May 19, 2017 at 5:05 PM
    #77
    Boring
    Boring This space unintentionally left blank.
    Arizona
    5-lug regular cab
    yarp
    I emailed and asked for prices. Torspd's setup is about $1700. The cheaper one (no fans) is closer to $1100. 6 weeks to make it. I guessed about 1/2 that much. Swing and a miss.
    Torspd[OP] and MrCrowntown like this.
  18. May 19, 2017 at 5:12 PM
    #78
    MrCrowntown
    Alyn
    Ky
    Dang 1700, it's super important for maxing out these motors though...
    Time to start saving? Maybe my fabricator can weld me up one for cheaper lol
  19. May 20, 2017 at 7:54 PM
    #79
    gersus
    Missouri
    14 Tacoma DCOR
    Yeah, thats pretty pricey. High up on the cool factor though! Worth it for someone whos kickin some serious hp or horrible conditions.
    I think I'll just look into switching to electric fan.
    I had a chevelle once and switched from a flex fan to electric. There was a distinct difference noticed on the butt dyno.
    I switched to electric on my old 95 taco, mainly because the fan clutch went out anyway.
  20. May 20, 2017 at 11:10 PM
    #80
    2big4arunner
    Tyler
    Vernon BC
    2015 tacoma dclb
    Well hopefully I can find a more budget related solution with how I am doing mine. your radiator looks super sweet though Torspd
