Upgraded Ron Davis Radiator
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Torspd, Apr 20, 2017.
  1. Jul 11, 2017 at 9:05 AM
    #81
    TonyDobbs
    TonyDobbs Well-Known Member
    Tony
    Cotati, CA
    2012 LT TRD OR + 2007 TRD Sport
  2. Jul 11, 2017 at 9:43 AM
    #82
    12TRDTacoma
    Rob
    Concordia
    Boosted
    My only issue with the consideration of electric fans is the factor of offroading. From my understanding a clutch style is far more reliable when we are talking about the wheeling world due to the vibration, harshness, and abuse that rigs can take. Especially the way I like the run mine.
  3. Jul 11, 2017 at 9:44 AM
    #83
    TonyDobbs
    Tony
    Cotati, CA
    I believe that is mostly an issue when going through water or mud, as that would burn up the motors. Wiring a simple shut off switch should solve that issue.
    Torspd[OP] likes this.
  4. Jul 11, 2017 at 9:45 AM
    #84
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Were that the case, all sorts of off road rigs wouldn't swap to electric fans. Trophy trucks, baja, etc.
    nfs257, adanfon and MrCrowntown like this.
  5. Jul 11, 2017 at 10:20 AM
    #85
    12TRDTacoma
    Rob
    Concordia
    Boosted
    That IS true... And I'm not an expo/overland rig. I prefer to go fast and break shit rather than turn it into a submarine or mud pool.
    What kind of fans are you guys running and method of controlling on/ off times as well?
    nfs257 likes this.
  6. Jul 11, 2017 at 10:24 AM
    #86
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    The fan is better suited by being mounted to the body of the truck. The engine experiences a lot more vibrations and jarring movements than the body does.
    Also, an electric fan allows you to have 100% fan efficiency at all times, regardless of engine RPM.
  7. Jul 11, 2017 at 10:52 AM
    #87
    Torspd
    Tor
    The Great America!
    Mine is on a thermostatic controller.
    12TRDTacoma[QUOTED] likes this.
  8. Jul 11, 2017 at 10:57 AM
    #88
    MrCrowntown
    Alyn
    Ky
    Flippy switch.
    I've had issues with the thermo switches in the desert before
  9. Jul 12, 2017 at 9:26 AM
    #89
    2big4arunner
    2big4arunner Well-Known Member
    Tyler
    Vernon BC
    2015 tacoma dclb
    3/2 leveling kit, 275/60r20 duratracs on xd128 20x9 rims, AFE stage 2 intake, trd exhaust, duel electric fan w/dakota digital controller
    Inlet and outlets are the wrong size for our trucks. I can confirm that the 620-101 Denso fan is more then capable with a basic shroud on the stock radiator. But the all aluminum units would be much better.
    I ordered one and just need to fit it in with the new motor
  10. Jul 12, 2017 at 10:04 AM
    #90
    TonyDobbs
    Tony
    Cotati, CA
    Yea, I noticed that, but it wouldn't be too hard to change that I don't think. You ordered the Denso fan or the Mitsubishi radiator?
  11. Jul 13, 2017 at 2:38 PM
    #91
    2big4arunner
    Tyler
    Vernon BC
    2015 tacoma dclb
    Mishimoto radiator for the Nissan 300zx. I already have the fan running on the stock Tacoma radiator. It works even under load but very hard to keep even temps.
  12. Jul 13, 2017 at 2:42 PM
    #92
    2big4arunner
    Tyler
    Vernon BC
    2015 tacoma dclb
    Dakota digital pac-2750 to control the fans. Expensive but gives lots of options.
    Also will mention that a simple breaker for me controls on off ATM once I wire in more control I will have a solid on/off/auto switch.
  13. Jul 13, 2017 at 5:08 PM
    #93
    12TRDTacoma
    Rob
    Concordia
    Boosted
    $113 for an external from ECM radiator fan control module is actually not that expensive. It looks pretty nice also!
  14. Jul 13, 2017 at 5:32 PM
    #94
    sasquatch95
    sasquatch95 Well-Known Member
    Hunter
    nanaimo BC
    07 DCLB sport
    Since I don't plan on upgrading my rad and fans to this one till the end of the year. What's a good brand of electric fan to get now??
  15. Jul 13, 2017 at 5:38 PM
    #95
    Deathcure
    Deathcure Well-Known Member
    Wheeling WV
    12 Tacoma Off Road
    sub for later
  16. Jul 13, 2017 at 5:46 PM
    #96
    SonnyBones
    SonnyBones I VOID WARRANTIES
    Jeffery
    2015 TACOMA ACCESS CAB
    SPAL fans
  17. Jul 14, 2017 at 11:00 PM
    #97
    2big4arunner
    Tyler
    Vernon BC
    2015 tacoma dclb
    Grab that Dorman 620-101. Can't get much better and it will flow 2 to 3 times as much as most aftermarket fans.
    The 16" cyclone from flexalite
    620-101 Dorman for a 95 sable 3.8 v6
  18. Aug 21, 2017 at 7:43 PM
    #98
    MrCrowntown
    Alyn
    Ky
  19. Aug 21, 2017 at 9:35 PM
    #99
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    What's a reasonable number for parasitic loss on the stock setup? Is it a noticeable improvement going to an electric fan?
  20. Aug 21, 2017 at 10:11 PM
    #100
    MrCrowntown
    Alyn
    Ky
    Can't speak for the V6, but it was a HUGE improvement on my 4cyl. Easily 10-15% for me
    05Taco4x4, stickyTaco and GT7 like this.
