Upgraded Ron Davis Radiator
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Torspd, Apr 20, 2017.
  1. Aug 21, 2017 at 10:15 PM
    #101
    GT7
    GT7 One piece at a time
    Grant
    Phoenix
    2013 DCLB
    You help hurt peoples wallets
  2. Aug 21, 2017 at 10:17 PM
    #102
    MrCrowntown
    MrCrowntown Well-Known Member
    Alyn
    Ky
    06 Extended cab Prerunner 2.7
    Dirt King Mid travel with King 2.5 coilovers, Baja Kits chase SUA with 14in fox smoothies under custom hangars.
    I'm helping you work on those smiles per gallon tho
    :stirthepot:
    05Taco4x4 and Torspd[OP] like this.
  3. Aug 21, 2017 at 10:22 PM
    #103
    GT7
    Grant
    Phoenix
    2013 DCLB
    Haha exactly!
  4. Aug 21, 2017 at 10:22 PM
    #104
    MrCrowntown
    Alyn
    Ky
    :fistbump:
    EDIT: I see phoenix in your sig. Imagine 20 seconds til the air comes out cold when it is 110* outside!!!!!
    GT7 likes this.
  5. Sep 15, 2017 at 3:29 PM
    #105
    kh7nm
    kh7nm Stay Boosted
    Miles
    Ewa Beach, Hawaii
    2011 MGM DC 4x4 TX PRO Off Road
    What have you done to your truck lately
    So can you use the same radiator hoses?l
  6. Sep 15, 2017 at 4:17 PM
    #106
    Torspd
    Torspd [OP] Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Correct you can.
    kh7nm likes this.
  7. Sep 15, 2017 at 4:27 PM
    #107
    Justinlhc
    Justinlhc Not looking for a relationship
    10-15%?? That's a massive gain. How many fans were you spinning??
  8. Sep 15, 2017 at 4:44 PM
    #108
    cosmicfires
    cosmicfires Well-Known Member
    David
    Everett, WA
    2009 Regular Cab SR5 4cyl 5speed 4x4
    Snugtop cab high canopy.
    These look way cool. Almost makes me with I needed a new radiator.
    I'd need one for use with the stock fan however..
  9. Sep 15, 2017 at 4:48 PM
    #109
    cosmicfires
    David
    Everett, WA
    I ran an electric fan in my '78 Toyota pickup. It didn't cool as well as the stock setup going slowly in a hot place (Guatemala and Honduras). We had to turn the cab heat and fan on full. Fortunatly that saved us. I put the stock fan back on when I got home.
  10. Sep 15, 2017 at 5:10 PM
    #110
    Torspd
    Tor
    The Great America!
    They allow that option.
    tacoma16 likes this.
  11. Sep 16, 2017 at 8:00 AM
    #111
    MrCrowntown
    Alyn
    Ky
    One flexalite. You notice just a tad bit of surge when you turn the fan on, but equalizes after it gets spinning. I will never use a mechanical fan ever again, which may be attributed to my willingness to do electrical wiring for fun :laugh:
  12. Sep 16, 2017 at 8:25 AM
    #112
    buyobuyo
    buyobuyo Read The Fucking Manual
    Jeremy
    Camden, AR
    08 PreRunner SR5, I4, Manual, Silver
    A thing or two...
    What do you mean by surge? I think my water pump maybe leaking. If it is, I'll likely ditch the mechanical fan and get an electric setup. Are you still on the stock radiator or did you upgrade to this one? If you're running the Ron Davis radiator, are you running the Flex-a-lite setup for the 2tr-fe with it or an universal Flex-a-lite?
  13. Sep 16, 2017 at 9:17 AM
    #113
    Justinlhc
    Oh, I thought you were saying you got a 10-15% increase in power.
    I had nightmares with my flexalite setup. Random blown fuses and eventually a fried controller(yes, the ~5 wires were hooked up properly) made me swap back to the worry-free mechanical fan.
  14. Sep 16, 2017 at 9:49 AM
    #114
    eon_blue
    Azusa, CA
    I had nightmares with my Flexalite efans as well on my 04. Dual efan setup controlled by a switch and not thermostatic. It never kept my motor cool offroad (on road it was great, off road in 4lo I would overheat going uphill for any length of time).
    Then one day the wiring harness caught fire on my way to work, so I had a stock fan clutch put back in and my overheating woes went away completely. The PO had the Flexalite setup installed by a reputable shop but maybe they botched the install, who knows. Either way I've been very way of efans ever since, esp since the stock fan clutch has done me so well comparatively. Although this thread has me thinking about them again and wondering if maybe my previous setup was a bad egg...
  15. Sep 16, 2017 at 10:04 AM
    #115
    Justinlhc
    I kicked myself in the balls repeatedly for making my reliable truck into an unreliable time bomb..and paying good money to do so. :facepalm:
    On my Tundra the lower radiator hose was routed dangerously close to the flexalite bracket which eventually rubbed through...twice. :frusty: I'm sure I could have remedied that situation, but the electrical issues still existed. It was the dual fan setup so maybe I would have had less issues with a single fan...at the cost of less airflow. :goingcrazy:
    eon_blue[QUOTED] likes this.
  16. Sep 16, 2017 at 10:07 AM
    #116
    gersus
    gersus Well-Known Member
    Missouri
    14 Tacoma DCOR
    Lil lift, bumpers, SC, UCON, headers, etc.
    I had issues as well with my 95. I had two thermo controls go bad before I just went to a manual switch. It surprised me how little the fan really was needed.
    I think the fancy switch mentioned earlier is pretty sweet and very well may be worthwhile. I know for sure there was a noticeable increase in power for my 95 and made it all worth it.
    Torspd[OP] likes this.
  17. Sep 16, 2017 at 5:14 PM
    #117
    MrCrowntown
    Alyn
    Ky
    It's absolutely a noticeable HP increase. And I never trust anyones wiring. I wired in my own switch and relay to avoid exactly what you went through.
  18. Sep 16, 2017 at 5:16 PM
    #118
    MrCrowntown
    Alyn
    Ky
    Surge as in the alternator needing to kick in harder after the initial spin up of the fan. You can see the light dim when you switch it on, and then it equalizes out after a moment. I got my stock radiator with the tacoma flexalite. Bolted right in, and works excellent.
  19. Sep 16, 2017 at 5:47 PM
    #119
    Justinlhc
    No thermostat? I'd rather not have to manually operate the fan. Like I said, it was wired properly, but it wasn't reliable equipment. This was a few years ago so maybe they've upgraded their electronics since then.
  20. Sep 16, 2017 at 7:47 PM
    #120
    buyobuyo
    Jeremy
    Camden, AR
    A thing or two...
    Thanks for the info. Are you running a thermostat? It doesn't sound like you are, but if so, are you running the one that comes with the flex-a-lite kit? Also, where did you install the coolant temp sensor?
