Upgraded studs for TRD/Magnuson Supercharger tensioner
Discussion in 'Automotive Group Buys' started by Athlaos, Apr 23, 2023.
  1. Aug 3, 2023 at 10:17 AM
    #201
    Athlaos
    Athlaos [OP] Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    I was... but because I have an after market rad... I was thinking you may need to at least remove the stock fan shroud to get them in if you have the stock rad.
    Edit: I'll be installing these on my friend's truck who still has the stock rad. I guess I will find out how to do it and report back here
    BenMara likes this.
  2. Aug 3, 2023 at 11:43 AM
    #202
    jamesepoop
    jamesepoop Well-Known Member
    California
    2007 Fj Cruiser
    JasonWho? :der:
  3. Aug 3, 2023 at 12:01 PM
    #203
    JasonLee
    JasonLee Hello? I'm a truck.
    Q322+3C Denver, Colorado
    15 TRD OffRoad
    TRD Supercharger and more.
    I currently have the Dobinson’s 112 heavy duty rear springs that give me quite a bit of lift even with the camper on the back. The current T/C Baja rear shocks are acting as limit straps with the extended flex and higher resting height, so I’m wondering if the fox ones will reduce downtravel even more.
  4. Aug 4, 2023 at 9:41 AM
    #204
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    I would think there would be no difference with the TRD pro shocks and the Bilsteins. Although the ride would be better imo.
    JasonLee[QUOTED] and Athlaos[OP] like this.
  5. Aug 4, 2023 at 9:59 AM
    #205
    MuddySquirrel
    MuddySquirrel Well-Known Member
    Will
    Phoenix
    2015 Taco 6-speed Off-Road
    Yup, using the double nut method. The top one is a PITA (ratcheting wrench to the rescue), but still way easier than pulling the radiator. My tensioner back on snuggly, but after finding the sweet spot it slid right in.
  6. Aug 4, 2023 at 10:32 AM
    #206
    JasonLee
    15 TRD OffRoad
    It gets confusing with the 3rd gen fronts producing a 1” lift when installed on a 2nd gen, but the 2nd gen Baja/pro suspension also provide that 1” or 1.5” lift up front, so they are probably the same.
    As for the rear, I think all stock length rear shocks will end up limiting my down travel/flex with the HD Dobinson’s 112 leaf springs.
    Sterling_vH111 likes this.
  7. Aug 4, 2023 at 10:35 AM
    #207
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    SUMOTNK, henryp and Athlaos[OP] like this.
  8. Aug 4, 2023 at 10:36 AM
    #208
    Lucario Runner
    Robert
    06 Toyota 4Runner
    You'll probably need the rear shock relocation as well as the extended travel shocks for your setup. Seems to be a common setup for that application.
  9. Aug 4, 2023 at 1:32 PM
    #209
    suprasonic
    suprasonic Member
    2007 FJ Cruiser
    TRD Supercharger, TRD intake (new design), TRD catback exhaust, URD big fuel pump, HP Tuners flash
    I received my upgraded studs today. Thank you @Athlaos & @SUMOTNK .
    This may be a stupid question, but my Supercharger install is fairly recent, two years ago and I have maybe 3000 miles on it. As I understand it, the studs typically fail after extended mileage and time. Should I swap them in immediately or could I put it off, say when I decide to put a new upgraded radiator and a pulley swap, in a few months?
    SUMOTNK likes this.
  10. Aug 4, 2023 at 1:58 PM
    #210
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    I have close to 20x more miles since my blower install..... I don't plan to swap out the stud until the next big job up front. It's not something thst I would say needs to be replaced asap...
    ....the RIPP coil packs, however.....! Detach asap
  11. Aug 4, 2023 at 2:24 PM
    #211
    suprasonic
    suprasonic Member
    2007 FJ Cruiser
    SUMOTNK: Thanks for your input. I’ve been collecting parts for an “upgrade weekend”, I will add those to my pile. Can you elaborate on your Ripp coil pack comment? They made a big difference?
    Also- I don’t mean to hijack this thread, but is there a write up somewhere on replacing 02 sensors on supercharged trucks?
    Athlaos[OP] likes this.
  12. Aug 4, 2023 at 8:54 PM
    #212
    BenMara
    BenMara That Asian RedNeck
    Ben
    Belton, SC
    2011 DC 4x4 SCed
    TRD Blower, Ham Radio, DBA T2 Rotors
    Thank You @Athlaos @SUMOTNK
    Studs are glorious
    Now need time to get Evo X back on the road, and put Taco in the air to replace Radiator and few engine bay goodies..... 120k Miles SCed time for some maint other then the snout...
    SUMOTNK likes this.
  13. Aug 6, 2023 at 3:00 PM
    #213
    Dawglb44
    Dawglb44 Well-Known Member
    Spenser
    Independence Township, MI
    1994 Pickup SR5 5spd, 2013 Tacoma Baja 6spd
    Dang! Guessing I’m too late to the party? All studs spoken for? I need this in my life lol
  14. Aug 6, 2023 at 6:21 PM
    #214
    Athlaos
    Leigh
    Edmonton
    Yes, unfortunately all sets have been sold!!
  15. Aug 6, 2023 at 7:13 PM
    #215
    Dawglb44
    Spenser
    I totally understand.
    Anyone on here that was looking to break up their “backup” set? Looking for 2 of y’all who are okay offloading 1 each hopefully!
  16. Aug 8, 2023 at 6:42 AM
    #216
    NLMOOmar
    NLMOOmar Well-Known Member
    13 DCSB TRD OFFROAD SC
    Shrockwork Sliders, ICON (C/0, Tube UCA and 2.0 Rear), Dakars, US OFFROAD winch mount bumper. 2014 Nav Radio, SOS rear bumper and shackle flip, Pelfreybilt Skids. BAMF Bar mount and CMC, SCS-F5, Magnuson SC
    Studs are fantastic Thanks you Athlaos for doing the leg work and Sumotnk for getting it to us in the lower 48!
    They came in at just the right time since my alternator went bad,
    I do want to warn you guys about something I experienced it might behoove us to apply some removable thread locker sealant to the block side of the stud. I installed it with no thread locker and they went in “super easy” and I butted both studs tight to the block and torqued down the tensioner pulley assembly to 29ft/lbs actually did it twice since I screwed up the routing of the sc serpentine. Drove around the hood all was good. Then got on the turnpike and 60 miles later it threw both belts, flatbed ride home 18 hrs later AAA sucks in FL. Found the lower stud had come all the way loose and upper one I could spin with my fingers. I was lucky and belts are still whole no visible damage to any pulleys but I will replace since who knows they were a bit twisted. So it may be a tolerance difference between the thread or some different harmonic happening between these studs and the block vs the original studs. Cheers!
    Athlaos[OP] and SUMOTNK like this.
  17. Aug 8, 2023 at 7:01 AM
    #217
    Athlaos
    Leigh
    Edmonton
    Wow... perhaps some thread locker could be in order as a safety factor... I have been running mine for 3 months myself, so this is a bit surprising.
  18. Aug 8, 2023 at 9:41 AM
    #218
    jamesepoop
    California
    2007 Fj Cruiser
    Thanks for the heads up. I know it's probably an obvious answer but I don't want to assume. On the 2nd go around did you snug up the stud again? Just curious as it wasn't clear. Only that you had torqued bolt twice.
  19. Aug 8, 2023 at 9:57 AM
    #219
    NLMOOmar
    I believe I did, but the slot deforms real easily on the new studs so hard to say how snug they were, this time around they got medium/blue thread locker and I double nutted the stud tight to the block
    Athlaos[OP] and jamesepoop like this.
  20. Aug 8, 2023 at 6:09 PM
    #220
    JuanitoBonito
    JuanitoBonito Que Pasa
    Juan
    CHI-TOWN
    2024 Raptor
    What’s up?!!
