Upgraded studs for TRD/Magnuson Supercharger tensioner
Discussion in 'Automotive Group Buys' started by Athlaos, Apr 23, 2023.
  1. Apr 24, 2023 at 8:14 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Please add me to the list sir !
    12TRDTacoma and Athlaos[OP] like this.
  2. Apr 24, 2023 at 8:15 AM
    Sterling_vH111
    Sterling
    socal
  3. Apr 24, 2023 at 8:51 AM
    racebug68
    racebug68 Well-Known Member
    Travis
    Chandler, AZ
    05 DCLB 4x4 TRD SPORT SILVER
    I can't leave anything well enough alone
    I have a statement and two questions on this stud issue and the design / manufacturing of the replacements. Please take this as constructive improvement and not criticism.
    This picture leads me to believe the stud bottomed out in the threaded hole of the front engine cover, so there were threads sticking out of the block but inside the spacer before the shank portion starts. And it broke off close to the point that is flush with the engine. If this is the case, the stud is/was threaded too far, and the thread itself is the weak point and the stress riser.
    It would be WAAAAY better to reduce the threaded length (not overall length obviously, but just how far the stud is threaded), so that the shank contacts the engine cover (no threads exposed) instead of the threads bottoming in the hole.
    1) Is there any way in the manufacturing of these to spec that the engine side of the stud has fewer threads cut? Or, you could make the overall length longer on the opposite side, which would allow me to cut the stud down and allow it to thread in all the way without it being too short for the nut on the outside. But really, the potential problem exists on both sides of the stud, the shank fully supporting the spacers or tensioner assembly is far superior to there being threads exposed on the outside of the block or the underside of the tensioner bracket. The best way to make this stud stronger is to reduce the amount of threads to the minimum on both ends to ensure the shear forces are exerted on the shank and not the threads...
    2) Also, and as an aside, with something close to 20 sets of studs purchased... and hopefully more, is there a way to ask if they can send out, or whatever is required to get ROLLED threads instead of CUT threads? From my observation all the problems here are problems with the threads, not the shank of the stud. I'd pay extra for rolled threads here, which is industry standard for ARP and other high performance fastener manufacturers.
  4. Apr 24, 2023 at 9:00 AM
    Athlaos
    Athlaos [OP] Destruction Mode
    Leigh
    Edmonton
    2011 SR5 Manual TRD SC 1.87" pulley
    A flux retro-capacitance encabulator
    These are excellent points, thank you. I am going to look into fitment with fewer threads on each end to make sure that it will work. Or possibly something like 0.25" less threads at the block end or something like that.
    I will also make sure the shop uses rolled threads, and let everyone know if there is any change to the quote, because yes, threads are automatically introducing a crack initiation point.
  5. Apr 24, 2023 at 9:01 AM
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    indeed. Its one of those i dont want it to happen once let alone twice and boutique items need backups.
  6. Apr 24, 2023 at 9:06 AM
    racebug68
    Travis
    Chandler, AZ
    Thank you!
    FYI rolled threads could be a very different quote and timeline, depending on the connections and desire of people doing the work.
    Steves104x4 likes this.
  7. Apr 24, 2023 at 9:09 AM
    nudavinci64
    Robert
    interested to see. rolled thread should be shorter labor times alas reduced cost but well see. Either way great points and great ideas! Thanks @racebug68 and @Athlaos
    SUMOTNK, Athlaos[OP] and Steves104x4 like this.
  8. Apr 24, 2023 at 12:09 PM
    Athlaos
    Leigh
    Edmonton
    So you're down for 2 then?? :D
    BassAckwards and jamesepoop like this.
  9. Apr 24, 2023 at 12:45 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    That’s $180 Canuckistikian pesos?
    12TRDTacoma likes this.
  10. Apr 24, 2023 at 1:25 PM
    Athlaos
    Leigh
    Edmonton
    Yes!
    Well actually, with us now having over 15 participants, it's $160 :)
  11. Apr 24, 2023 at 1:27 PM
    Lucario Runner
    Lucario Runner Resident Truck/SUV racer
    Robert
    San Antonio, TX or nearest race track
    06 Toyota 4Runner
    AFE stage II intake, APR X1, URD 70mm Throttle Valve (ported and knife edged), NST intake manifold spacer, URD spec U headers, Denso IKH20, URD fuel pump, APR fuel rail, URD Y pipe, URD spec u catback, lightweight water pump pulley, Greddy sandwich cooler plate, Earls oil cooler, IPT valve body, FJ TRD shocks, Cusco front and rear sway bars, Energy Suspension rear track rod bushings and rear link bushings, Carbotech pads, Stoptech ss brake lines, Stoptech slotted rotors, Motul 600 rbf, Limited Grill, Painted hatch cover by me, Painted valve covers by me, Cobra CB, TRD rad and oil cap, Escort 8500, Autometer oil psi and temp gauges, AEM wideband afr gauge, Flexpod, Pioneer 400w speakers.
    What's the conversion to freedom bucks? 13 hamburgers and a hotdog?
  12. Apr 24, 2023 at 1:33 PM
    TodayWasTHeDaY
    TodayWasTHeDaY Hoser
    Russ
    Calgary
    2015 DCSB SC M/T TRD Sport
    That sounds about right:rofl:
  13. Apr 24, 2023 at 3:38 PM
    zerotimeouts
    zerotimeouts Well-Known Member
    Nor Cal
    2011 DCSB 4.0 S/C
    @Athlaos Put me down for 2 sets.
    Anyone want to split the second set with me? I don't anticipate breaking set just wanted a spare/
  14. Apr 24, 2023 at 4:10 PM
    SUMOTNK
    SUMOTNK Pavement Pounder / Mall Crawler
    Eddie
    NorCal/South Bay Area
    Looks like a Gen2.5 TRD Sport, but really an '08 TRD OffRoad
    TRD Supercharged / OTT Tuned
    @Athlaos
    Would it be advantageous (cost benefit) to ship all the US shipments to 1 central US location and then branch out from there?
    I don't mind being the continental US shipping hub.
  15. Apr 24, 2023 at 4:31 PM
    #35
    Athlaos
    Leigh
    Edmonton
    Yeah I like that idea! Less work in packaging for me ;)
  16. Apr 24, 2023 at 4:52 PM
    #36
    racebug68
    Travis
    Chandler, AZ
    That would be great, even two sets of studs would be less than 16oz in a padded envelope, and ship usps first class for cheap (less than $10 even across the country). @SUMOTNK could make some money for his time/effort, and we would also save money at the same time compared to the international shipping costs.
    Steves104x4, SUMOTNK and Athlaos[OP] like this.
  17. Apr 24, 2023 at 8:18 PM
    #37
    brian.gonz
    brian.gonz Well-Known Member
    Brian
    Manor, Texas
    Supercharged 2012 TRD Sport DC
    TRD Supercharger, Relentless Fab Stingray, TRD Pro Wheels, BFG, AMP Research Runners.
    Throw me on the list
    Steves104x4 and Athlaos[OP] like this.
  18. Apr 24, 2023 at 8:39 PM
    #38
    Athlaos
    Leigh
    Edmonton
    So definitely in for 2 sets??
  19. Apr 25, 2023 at 9:40 AM
    #39
    Athlaos
    Leigh
    Edmonton
    A question for confirmed buyers: my shop sent some options for the tensioner bolt. Would the confirmed buyers be interested in that optional add-on to their orders? @12TRDTacoma's opinion is it's not necessary, however I just wanted to let people know I looked into it and gauge interest.
    The fastener is an unusual bolt - it has a non-standard flange diameter, so the shop will quote on a run of off-the-shelf fasteners, grade 10.9 with a recessed washer to match the flange diameter.
    1. @Lucario Runner
    2. @rheath08
    3. @Murphinator
    4. @Murphinator
    5. @MuddySquirrel
    6. @jamesepoop
    7. @TodayWasTHeDaY
    8. @henryp
    9. @blackenblue
    10. @12TRDTacoma
    11. @nudavinci64
    12. @TheFang
    13. @smelly621
    14. @SUMOTNK
    15. @BassAckwards
    16. @racebug68
    17. @Sterling_vH111
    18. @zerotimeouts
    19. @zerotimeouts
    20. @Bfz777
    21. @brian.gonz
  20. Apr 25, 2023 at 9:50 AM
    #40
    12TRDTacoma
    Rob
    Concordia
    Boosted
    It's still my stance that the tensioner bolt will long outlive any other supercharger rotational mass assembly fastener because it only sees the singular duty of maintaining a single belt and not two like the studs do. The whole reason these main studs fail in the first place is because they are overloaded with rotational mass not just for the blower but the engine as well that vibrates like hell all the time. That's a lot to ask of a stud.
