Upgraded tires before & after
Discussion in '2nd Gen. Tacomas (2005-2015)' started by russperry20, Sep 27, 2016.
  1. Sep 28, 2016 at 5:42 PM
    gainman
    gainman Semper Fi
    SW Florida
    2012 TRD Sport Supercharged Manual
    Stuff
    I'm well aware of the miniscule percentage of duratracs owners in the world that posted their problems on here. A good shop can balance the tire no problem.
  2. Sep 28, 2016 at 5:43 PM
    Casper66
    Casper66 grumpy ass
    Culpeper, Va.
    '15 DCSB TRD Sport 4wd super white (sold) '13 access cab SR5 4wd
    piddly stuff
    you shouldn't have to retorque your steel wheels but it doesn't hurt
  3. Sep 28, 2016 at 5:44 PM
    moondeath
    moondeath Well-Known Member
    Pa, Gardners
    2013 TRD Sport DCLB 4x4
    5100 @ 0” w/ 2.5” Eibach spring, 1.5" Icon Progressive 3 leaf + 1” block, Procomp Wheels, Grill Thin Lip (Custom Car Grills Mod), Access Tonneau Cover, Pop & Lock Tailgate Electronic Lock PL8521
    Not if theyre junk tires.
  4. Sep 28, 2016 at 5:53 PM
    gainman
    gainman Semper Fi
    SW Florida
    Stuff
    If you consider one of the highest rated tires out there junk, then yeah I guess you are right
  5. Sep 28, 2016 at 6:17 PM
    JaxJim
    JaxJim Well-Known Member
    Jim
    Jacksonville, FL
    13 TRD Sport, DCSB, 4x4, JBL, NAV
    Exterior: Duratrac 265/70/17, SpiderTrax 1.25" wheel spacers, BAMF sliders, DiamondBack SE Tonneau Cover, Pop&Lock, Tail Gate guard, Bed Mat, Bullaculla Trailer Harness bracket, Front Side Windows tinted to match rear, Removed all chrome and dealer badges, Toyota OEM Roof Rack/Rails, SOS Concepts Front Recovery bracket Under Hood: Redline Tuning Quicklift Hood Struts, Foglight anytime mod, UniFilter for Secondary Air Pump Interior: Seat bell Chime disable (TechStream), WeatherTech floor liners, ImMrYo rearview mirror relocation bracket, 12v Always-on Power port in console Radios/Comms: AntennaX 14", Escort Passport MAX Radar Detector, Yaesu 2900 Ham Radio, Uniden 980SSB CB Radio, Relentless Fabrication hood antenna mount, BAMF tailgate antenna mount, FireStik 2m and CB antennas, FireRing coax
    Mine have 26k and they are getting louder and louder. I don't really mind but the wife complains. I have one that cannot be balanced now too and it causes some vibes.
    They are still awesome offroad both in sand and mud without going full-on mud tires.
  6. Sep 28, 2016 at 6:36 PM
    JaxJim
    Jim
    Jacksonville, FL
    Whenever I have wheel or tire work done I always recheck the torque when I get home, then after about 200 miles. Even on steel wheels I do this.
  7. Sep 29, 2016 at 9:14 AM
    russperry20
    russperry20 [OP] Well-Known Member
    Russ
    I got 4 new tires for my truck on Monday and guy said they inflated them all to 35 PSI when they installed them. After installation they did an alignment and everything seems to be going OK.
    So I check my tire pressure this morning - everything was cold, hadn't driven it for 15 + hours. The front driver's side tire is at 35 PSI while the other three tires are at 40 PSI. This puzzled me because the day before I got the new tires, my tire pressure warning light came on and I had to add air to the front driver's side tire (so same situation with the old tires). Could this just be a coincidence? Or do you think there is a reason my front driver's side tire is consistently lower than the rest?
    After driving for a while I checked the pressures again and the front driver's side came up to 37 PSI and the other tires went up to 42 PSI.
    I brought the truck back to the tire place today to have the lugs re-tourqued (they recommend doing so after 50 miles) and I had them check the front left tire for leaks and had them even out the pressure.. Everything seemed to be fine. But after getting home the front left is still 3 PSI lower than the others.
    I'm not too worried about a slight difference in PSI but it's strange I'm having the same problem with two different sets of tires.
