Upgrades for towing
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Kantishna, May 27, 2019.
  1. May 27, 2019 at 9:22 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    The problem is that reverse isn't geared low enough, neither is 1st. This is a common problem with any modern truck with manual transmissions. I've had to resort to low range with multiple trucks and SUV's over the years when backing up inclines. As long as you're only in 4X4 for short distances and don't turn the wheels more than a slight amount you'll be OK. Doing what you've been doing is the best answer.
    A manual can be fun to drive. But on a tow vehicle they suck. An automatic is much easier to get loads moving in either direction.
  2. May 27, 2019 at 9:24 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Right, 1st Gear feels fine but Reverse is a bit of a head scratcher in this truck, it feels like a highway gear.
  3. May 27, 2019 at 9:27 AM
    Hobbs
    Hobbs Anti-Lander from way back…
    Yep…
    Rock Bangen', Desert Tamin', Gold Findin' Machine!
    The term is Crawl Box.
    built-units
  4. May 27, 2019 at 9:27 AM
    ClamIt
    ClamIt Active Member
    I've never had a problem. But then, the only time I've shoved a load backwards is on a boat ramp (down hill) or my driveway (flat).
    shakerhood likes this.
  5. May 27, 2019 at 9:28 AM
    Kantishna
    Kantishna [OP] Well-Known Member
    Interior Alaska
    2019 DCSB TRD OR MT
    Ya, modern vehicles. There are times I really miss my 65 Chevy and 62 Ford. I could put it in first and just crank on the starter, no clutch needed, it would just start driving.
    Big tall dave likes this.
  6. May 27, 2019 at 9:28 AM
    OregontoBajaCA
    OregontoBajaCA 2025 DC OR High Bread
    2025 OR DC iF Max
    I think you meant ‘masochist’ in the general sense of the word for your comment!
  7. May 27, 2019 at 9:28 AM
    ClamIt
    You seem familiar with the situation.
  8. May 27, 2019 at 9:32 AM
    Thegenerik1
    Thegenerik1 Well-Known Member
    Erik
    NorCal
    18 DCLB OR
    I thought OVTune adjusted shift points and raised the Redline. Don’t think it adds any power or torque down low.
  9. May 27, 2019 at 9:33 AM
    Kantishna
    Interior Alaska
    2019 DCSB TRD OR MT
    Have not put 1st to the test yet, I'll see how it does at the boat launch but I'm generally in 4wd anyway because of the mud.
    shakerhood[QUOTED] likes this.
  10. May 27, 2019 at 9:39 AM
    shakerhood
    Southern Ohio
    I believe it does add more power lower in Revs, hadn't read much on the automatic tune but imagine he changed shift points also.
