Upgrades fuel pump Inline or replace stock
Discussion in 'Performance and Tuning' started by turbotime, Jul 14, 2014.
  1. Jul 14, 2014 at 3:26 PM
    turbotime
    turbotime [OP] Member
    Hello new to this i have a turboed 2010 tacoma was thinking about putting an inline pump to try and boost my pressure is this a waste of time or just replace the stock one. Also is there any good tuning out there that would help me so far the stock electronics it runs great, any help or advise would be great thanks
    already tried a bully dog GTT tuner but they cant send me the supercharger program
  2. Jul 14, 2014 at 3:40 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Pics of turbo kit?
    Who made the kit?
  3. Jul 14, 2014 at 3:46 PM
    turbotime
    I made the kit i mostly do diesel performance and alot of snowmobiles ,lots of tinkering like that i really dont want to post pics yet. sorry I made 50 horse with stock electronics just wanting a little more or see what other option i have. Even played around with the fuel pressure that didnt seem to help that much.
  4. Jul 14, 2014 at 4:14 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Bully Dog won't have a tune for a turbo kit. There aren't remotely enough 2nd Gen Tacomas with turbo kits .
  5. Jul 14, 2014 at 4:19 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Pretty dang cool. Welcome to the turbo club.
  6. Jul 14, 2014 at 4:24 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    So are you trying to gain extra fueling with more pressure? I am not thoroughly understanding your first post.
    If that is the case, then you could route a vacuum/boost hose to the FPR. That will give you a decent 1:1 rising fuel pressure with boost.
    Otherwise, I sincerely suggest upgrading the in tank fuel pump. As the kits available will get rid of the OEM non replaceable in tank filter, with an external replaceable filter.
    And do the FPR mod with that.
    There are other tuning options available, but they are also wire in, for your year model.
  7. Jul 14, 2014 at 4:50 PM
    turbotime
    Well i have already done that with the fuel pressure regulator i was just hoping to get a little more adjustment and some people are saying replace the pump in the tank. I do this stuff on fuel injection snowmobiles and we add a walbro pump and keep the stock one and it helps because the stock pump runs out but we run a lot of boost on them. Im running 7 pounds now hoping to keep it simple. The truck runs in the 10s on the air fuel ratio gauge when i get on it hard, Im sure the truck is sensing more air and fueling it. like i said the truck runs well with just stock tuning I have a 1000 miles on it with the turbo was hoping the bully dog programmer would work but i have to have my ecm reflashed by the dealer for a supercharger then it will work but I don't thing they can .
  8. Jul 15, 2014 at 7:08 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    The stock pump cannot handle much higher than 280 - 300 whp well. Increasing the fuel pressure like you have done, helps to get that little extra fueling, but it also diminishes the stock pump's output.
    Best recommendation I can give you, and I have a lot of experience on this vehicle, is to upgrade the internal pump.
    Then you can add an adjustable FPR and increase the base fuel pressure to your liking, pre boost reference.
    The s/c reflash will work, and gives your ecu the ability to run a larger injector. As long as you buy/install that injector. We did that on my friend's turbo Tacoma. It only stayed a little lean in the launch, if he tried to drag race.
  9. Jul 16, 2014 at 9:27 AM
    turbotime
    Thanks alot didn't want to drop the tank but i guess i will
  10. Jul 16, 2014 at 9:32 AM
    PLC721
    PLC721 Well-Known Member
    Patrick
    Chandler, Az
    2017 Toyota Tundra Crewmax ProKiller
    Kings, Toyos, Baja Designs, TC, SDHQ
    I have a fuel pump for sale! ;)
  11. Jul 16, 2014 at 11:56 AM
    turbotime
    Thanks I have one from urd i have had it for awhile just didnt want to drop my tank
  12. Jul 16, 2014 at 12:03 PM
    PLC721
    Patrick
    Chandler, Az
    Haha same here
  13. Jul 16, 2014 at 12:20 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Of all the mods.....that is by far one of the easiest. :p
  14. Jul 16, 2014 at 7:44 PM
    Eggbert
    Eggbert Well-Known Member
    PA
    '14 dcsb TRD OR Supercharged
    TRD Supercharger, MBRP DualCatback, DT Shortie Headers, Regeared with 4.56 ECGS 3rd and Clamshell, URD 2.55" Stealth pulley, AEM Methanol 5 gallon kit, URD Perf Thermostat, NST Lightweight crank pulley, URD 61lb injectors, Mishimoto Oil Catch Can, URD Fuel Pump upgrade, AEM Boost and Wideband gauges, OEM FPR Mod, RBP Black Exhaust Tips, Icon Stage 6, Fuel Octane wheels, Nitto Terra Grapplers 285/70/r17, Color match rear bumper, Color match hood with skewp, Color match grill, Color match valance, Derped grill emblem, Derped Tuffbar bullbar, OEM Skidplate, AVS Ventvisors, Bodyside Moldings, RBP RX3 nerf bars, Color Match Bushwacker Pocket Flares/Rivets, Undercover LE Tonneau, Katzkin heated leather, Bel Stir-Plus Radar, Sprint Booster, Dynamat/Hushpad, Polk dxi691 - front, Polk dx1651 - rear, Alpine KTP-445U Power Pack, Front tint 35 percent, Weathertech front mats, Smoked tail lights, LED DRLs, Coupe TRD Battery tie-down, Coupe TRD CAI Cover
    Hey Tor, I upgraded to the URD Walbro 255. I also am planning on upgrading my injectors to the URD 61lbs and swapping from my 2.7" pulley (8 psi at WOT) to a 2.55". Doing this because I,m running way too rich with the FPR mod and so want to go the bigger injector route. Do you think the Walbro is sufficient to handle the new injectors and flow demands to support about 10 psi boost?
  15. Jul 16, 2014 at 8:04 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Oh yeah. That 255Lph is more than sufficient for your goals. The FPR mod will definitely be needed for the 2.55 pulley. Might be ok with out the FPR mod, for the 2.7. You should try swapping it back to factory and see how it works, before going to the 2.55.
    Also, what are you planning on using to control the larger injectors? I see you have a 2014.
  16. Jul 17, 2014 at 10:42 AM
    Vassily28
    Vassily28 Well-Known Member
    Quebec, Quebec, Canada
    11 TRD SPORT 4x4 Quadcab LB
    TRD supercharger with 2.85" URD stealth pulley and OEM FPR mod. URD fuel pump upgrade, URD TB plate adapter 70mm, FJ/4 runner 70 mm Throttle body, URD exhaust cam gears URD performance thermostat TRD CAI 1st gen. with custom cover (coupe), ProDry S + Filter skin, Doug thorley long tube headers, URD spec U exhaust Icon LT 2.5 front coilover, Timbren front bumpstops, Total Choas UCA, Deaver custom leafpack 3 inch. lift, Icon 2.5 VS series rear resishocks, Timbren rear bumpstops, ARB front bumper with WARN 8500 lbs winch,Hella 500 blackmagic, AVID rear bumper, Allpro front IFS skid + Trans. skid + Transfercase skid. Total chaos LCA skid, SS braided brake line, URD O2 sims, URD MAF controller, Wetokole front seatcovers, Innovate MTX-L, MTX-D AFR and boost gage.
    You were running the 2.7 in. pulley without other mods?
    Do you have a 7th injector? If yes how do you control it?
    Is it possible to run a 2.7 in. pulley with just the TRD SC, the TRD reflash, the upgrade fuel pump and a MAF controller?
  17. Jul 17, 2014 at 6:35 PM
    Eggbert
    PA
    Thanks Tor and Vassily.
    Long story short, i only had the URD fuel pump upgrade and the TRD reflash when I swapped to the 2.7". I followed Tor's advice and made sure I installed a wideband first and good thing since my AFRs at WOT were in the low to mid 12s :eek:
    I immediately installed the OEM FPR mod but then my AFRs were pegged at 10 during WOT
    Decided I needed some better control over fuel and timing so had a MAPECU3 from Gadget installed last week and had the truck dyno and street tuned.
    Here is the dyno
    Sooooo close to 300 rwhp! Was a hot day, but what I really think killed my power was the engine drowning in fuel at WOT.
    So to get over the "hump" (I HOPE), gonna install larger injectors, reverse the FPR Mod, install a 2.55" and get a new tune.
    Do you guys think this is the best approach to eke out the most power? Was also thinking of some methanol injector for cooling since the 2.55" will create some heat!
  18. Jul 17, 2014 at 6:40 PM
    Eggbert
    PA
    Sorry OP, didn't mean to hijack your thread :)
  19. Jul 18, 2014 at 6:21 AM
    Vassily28
    ^ +1 but it's still about fuel delivery.
  20. Jul 18, 2014 at 10:27 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    What AFR's are you running since the tune, in boost? With the Map-Ecu3, the tuner should be able to get the AFR's between 11.1 - 11.5, with or without the FPR mod. That in itself should give you a nice bump in power, if it is still to rich?
    Which other mods does your truck have besides the s/c, 2.7, and shorties?
