Upgrades on an '07 Tacoma
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Awesman23, Apr 5, 2009.
  1. Apr 5, 2009 at 10:42 AM
    Awesman23
    Awesman23 [OP] New Member
    Germany
    2007 Tacoma TRD 4X4
    Volant CAI, Volant scoop, AFE Throttle Body spacer, Tornado, MBRP dual exhaust
    Does anyone have the following items on their 2nd Gen. Tacoma:
    - AFE Throttle Body Spacer
    - Volant Cold Air Intake
    - Volant Front Air Scoop
    - MBRP Dual Exhaust
    - Unichip
    The reason I ask is because has anyone else with any of these parts had problems installing/operating your vehicle afterwards?
  2. Apr 5, 2009 at 11:15 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2013 Rubicon Unlimited,
    Welcome to TW! Any TB spacer is useless on our trucks. Just makes it wistle, and gives no gain......none.......nada..........zipp.
  3. Apr 5, 2009 at 11:16 AM
    DanGer
    DanGer Avatar approved by 98tacomav6
    Northern Virginia & Blacksburg
    07 Base 4Cyl 4x4 Manual
    White Head Light mod, White shorty antennae, Doug Thorley Long Tube headers, AFE Drop in air filter, Secondary Air Filter Removed,
    As for the throttle body spacer, they do absolutely nothing for our trucks. Cold air intakes are debatable but I never put one on because I have not seen any dyno readings to back them up. Its your truck so put one on if you want!
    As for what I recommend, take out the charcoal, secondary air filter, and install a scangauge. The scangauge monitors how you are driving and makes you improve over all. It is a great investment.
  4. Apr 5, 2009 at 11:25 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Umm....I wouldnt take out the charcoal filter. Neither Gaget or me found any difference with it removed. FWIW, the TRD and AFE intakes do give a gain. I have seen about 5 h.p. from them. The K&N ones either showed no gain, or a loss. :)
  5. Apr 5, 2009 at 11:28 AM
    DanGer
    shit i forgot to check if he was a 4banger or not. I stand corrected!
  6. Apr 5, 2009 at 11:31 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I have wondered about that happening. I never thought that they had enough play in the rubber to handle repeted torque loads on the engine. Good to know!
  7. Apr 5, 2009 at 12:15 PM
    DeeKay21
    DeeKay21 Lieutenant Dan.
    Nevada/Utah
    06' TRD Sport 4x4
    Damn that sucks!! I also have the TRD CAI but then again, I don't go off-roading. Thanks for the info. I'm going to keep my eye open on that now.;)
  8. Apr 5, 2009 at 4:11 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    just courious, but how do your motor mounts look?
  9. Apr 5, 2009 at 4:29 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Me too, but they "could" be loose......:confused:
  10. Apr 5, 2009 at 4:51 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    Good. Poor design on TRD (Afe) part. They should use an accordian type connector.
  11. Apr 5, 2009 at 6:16 PM
    DeeKay21
    Nevada/Utah
    06' TRD Sport 4x4
    Yeah you should definetaly get your stock one back just in case.:eek:
  12. Apr 5, 2009 at 6:59 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    I was just thinking. It wouldnt be that hard to trim back the plastic tube a little bit. Maybe an inch and a half. Get some accordian tube of the correct diameter, and redo that junction...........
