Upgrades you regret
Discussion in '3rd Gen. Tacomas (2016-2023)' started by dcmsideshow, Sep 19, 2024.
  1. Sep 20, 2024 at 12:37 PM
    #141
    Darty03
    Darty03 •‿•
    2021 Tacoma TRD Off-Road V6 AT
    I was wondering the same. I'm on E rated tires and run 33psi year round. Rides smooth and there is only a slight change from stock tires. I can feel cracks and stuff in the road a little more but they are by no means harsher on bumps or anything.
    Only regret is buying red TRD branded valve stem caps. They faded fast and are now a redish silver.
  2. Sep 20, 2024 at 12:39 PM
    #142
    TacoLC
    TacoLC Active Member
    23 Taco TE Fzj80
    33-35psi here as well. Bfg KO3s. Rides and wears great at those pressures
    Tocamo[QUOTED] and Road_Warrior like this.
  3. Sep 20, 2024 at 12:42 PM
    #143
    Jeffch
    Jeffch Well-Known Member
    Jeff
    Vermont
    2018 off road
    Running 285/75/16s
    Not saying it’s an issue.
    I run 37 psi hot 34ish cold.
    A lot of grooves on our roads it likes to follow. I believe the tire width and lift adds to the truck feel. Running the interstate it’s pretty smooth.
    Anywho I’m ok with it!
    Tocamo[QUOTED] likes this.
  4. Sep 20, 2024 at 12:49 PM
    #144
    RIX TUX
    RIX TUX no ducks given
    2022 TRD OR DCSB 4WD..66 MUSTANG V8
    does yours have this?
    pdxTacoSR5[QUOTED] likes this.
  5. Sep 20, 2024 at 12:55 PM
    #145
    RIX TUX
    expensive mistake
  6. Sep 20, 2024 at 1:03 PM
    #146
    FunknNasty
    FunknNasty Well-Known Member
    San Jose
    2022 Pro
    It’s an almost great design if you have the funking key! If you don't, the only way to get to the locking lug is by taking the tire out and the only way to get to tire out is by cutting the hoist chain. Lucky enough for me there was a dealer in the sf Bay Area (shout out Fremont Toyota) that had all the possible keys so I could lower the tire and remove the lock without cutting the chain.
    the lock was a McGard …the folks at McGard were fine btw, but it was going to be at least a week before I could get a replacement key and I was on a scheduled road trip beforehand.
  7. Sep 20, 2024 at 1:15 PM
    #147
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
    I ran 37 psi cold on 265/75R16's. I started at 35 psi cold with 285/75R16's but increased to 37. Steering and handling on pavement was a bit too vague at 35. This site does the conversion, and says I should have been at 41 and 35, but I ended up at 37 on both. I don't think it will suggest less than 35 psi for any E-rated tire.
  8. Sep 20, 2024 at 1:22 PM
    #148
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    @RIX TUX
    Are you not happy with this lock?
    I was considering purchasing it.
  9. Sep 20, 2024 at 1:38 PM
    #149
    RIX TUX
    dont have it and wouldn't use it, looks like it will get dirty and fail, leaving someone stuck
    there is one already on your truck, just needs a pad lock
    i put this in the bed on trips
    TacoTime55[QUOTED] likes this.
  10. Sep 20, 2024 at 1:46 PM
    #150
    pdxTacoSR5
    pdxTacoSR5 Well-Known Member
    PDX area
    2018 Tacoma SR5, V6 Auto, Access Cab, 4x4, Silver Sky Metallic
    lol. that is what a put a padlock on. i believe i remembered putting it thru the chain when i first got the truck.
    then i decided to flip the spare around so valve stem was on bottom....and that is when i discovered the loop for the lock.
    i have never had a flat, and i can air it using the down facing stem, so i never lowered the spare since i flipped it...and so faulty memory remembered using the chain which was abandoned when i discovered the loop.
    you made me go out and lower it to make sure i am not crazy. 1st time in 6 yrs.
    i put some pipe insulation foam around the padlock to insure there is no rattle. it may to work...absolutely no rattle. keeps it clean too.
    Tacosha and RIX TUX[QUOTED] like this.
  11. Sep 20, 2024 at 1:50 PM
    #151
    Southwest Tacoma
    Southwest Tacoma Well-Known Member
    Southwest
    2020 Super White SR DCSB
    Yep. I could always put the brackets back on with the light bar.
  12. Sep 20, 2024 at 2:19 PM
    #152
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    I’ve exclusively run E rated tires on my taco since I upgraded from the stock tires. I usually have them at 35psi cold, they usually wind up around 40psi after driving a bit. I think the truck rides just fine or I wouldn’t be on my 3rd set of E rated tires lol
  13. Sep 20, 2024 at 2:39 PM
    #153
    canuck guy
    canuck guy Well-Known Member
    Alberta
    23TRDOR
    I used to use fancy valve stem caps but one winter 2 of them welded themselves to the stem due to corrosion probably from chemicals on road for ice and snow. Now I just use plastic in black or grey depending on rim color.
    lowmower, Max8 and Taco Egghead like this.
  14. Sep 20, 2024 at 2:45 PM
    #154
    BobLoblawEsq
    BobLoblawEsq It’s all in the reflexes.
    NorCal
    2022 White Tacoma TRD OR
    I have a bed mat and it's great if you don't want things to slide around. It's also great if you're doing anything where you have to put a knee down because those grooves hurt like hell. I bought that flat tailgate insert for that reason and would never go back. But if I'm doing a dump run or transporting anything heavy back there I'll take the mat out so my cargo slides in and out easier. It takes 10 seconds to put it in or take it out, so I think it's a good investment.
  15. Sep 20, 2024 at 2:57 PM
    #155
    RIX TUX
    are you doing search and rescue?
    Malvolio likes this.
  16. Sep 20, 2024 at 3:00 PM
    #156
    Southwest Tacoma
    Southwest
    No. Maybe I need to.
  17. Sep 20, 2024 at 4:06 PM
    #157
    TacoTyusday
    TacoTyusday Well-Known Member
    Zac
    San Diego
    2014 White Tacoma TRD Baja
    I run 40PSI in my 285/75r16 E rated tires...no complaints. I think my suspension helps counteract the stiffness of the rubber.
    but the truck is also a heavy pig with full armor, winch, bumpers, GFC, and so on.
    Road_Warrior and TacoLC like this.
  18. Sep 20, 2024 at 4:17 PM
    #158
    TacoLC
    23 Taco TE Fzj80
    That’s what
    She said :D
    I like all these answers. Makes me want to revisit and play around with tire pressures again
  19. Sep 20, 2024 at 4:31 PM
    #159
    Juspat2
    Juspat2 Well-Known Member
    Justin
    MatSu, Alaska
    2016 Black TRD Sport Access
    Probably taking my CD player out... I love the Alpine iLX-409, but .... old guy here, think I'd like my ability to play CDs if needed. will look into an aux set up probably.
  20. Sep 20, 2024 at 4:59 PM
    #160
    MikefromCT
    MikefromCT Well-Known Member
    CT
    2013 TRD OR DCSB
    OME Bp-51; Relentless Armor
