Upgrades
Discussion in 'Performance and Tuning' started by Brandon D, May 9, 2014.
  1. May 9, 2014 at 2:34 PM
    Brandon D
    Brandon D [OP] New Member
    Brandon
    3" lift
    Have a 2001 4x4 that I want to chip exhaust and put an intake on. What is the best products for this?
  2. May 9, 2014 at 3:08 PM
    CrunchyTaco99
    CrunchyTaco99 Well-Known Member
    Joe
    North Georgia
    99 TRD Tacoma
    33x12.50 Pro Comp M/T's All-Pro Coils, UCA and 3" leafs.
    What engine?
    Can't put a chip in a 3.4L V6 computer. Must send the whole computer off. Not worth it IMHO.
    Headers are a major PITA also. You can do a cat back exhaust for $$. I chose to just weld a Magnaflow. Really just improved the sound.
    Several companies sell intake systems. I had a K&N on my first Tacoma way back when. It improved throttle response but left the intake wide open to suck in water. My second and third Tacoma's had the Deck Plate mod with a K&N stock replacement filter. Improved intake sound but it is a serious debate if it helps or not. Also the oil may screw with your MAF.
    My latest Tacoma now has a completely stock intake with standard filter for reliability.
    I think the cheapest performance "mods" are just making sure it is running clean. Fresh plugs, clean the MAF and throttle body, Seafoam in brake booster vacuum line.
  3. May 10, 2014 at 11:50 AM
    Brandon D
    Brandon
    3" lift
    It is a 3.4 v6
  4. May 12, 2014 at 6:55 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
